POV-Ray : Newsgroups : povray.beta-test : sphere_sweep and cubic_spline Server Time
29 Jul 2024 10:32:03 EDT (-0400)
  sphere_sweep and cubic_spline (Message 1 to 4 of 4)
Subject: sphere_sweep and cubic_spline
Date: 10 Jun 2002 15:29:37
Message: <3d04fe21$1@news.povray.org>
Pov 3.5 RC6 on Intel 1.7Ghz 512M Ram running Windows 2000
I read in the help that "cubic splines produce the most flexible and smooth
curves" but this does not seem to be the case with sphere sweep. The
linear:spline and b_spline work as advertised but the cubic-spline seems to
curl in on itself and produce a sharp step. This code illustrates this. Is
it supposed to do this?
//pov 3.5 RC6
global_settings { assumed_gamma 1.1 }
#include "stdinc.inc"
  background { color Blue }
    location <0, 2, -10>
    look_at  <0, 0,  0>
light_source { <0, 2, -10> colour White }
  sphere_sweep {
    //linear_spline
    //b_spline
    cubic_spline
    9,
    <0, 10, 0>, 1
    <0, 10, 0>, 1
    <0, 2, 0>, 1
    <0,  1, 0>, 0.5
    <0,  0, 0>, 0.3
    <0, -1, 0>, 0.5
    <0,  -2, 0>, 1
    <0,  -10, 0>, 1
    <0,  -10, 0>, 1
    tolerance 0.000001 //0.2
     pigment { color Yellow }
Richard
Subject: Re: sphere_sweep and cubic_spline
Date: 11 Jun 2002 03:19:34
Message: <9a8bguo643ubbncriskpc1a9pumoqtn6pe@4ax.com>
On Mon, 10 Jun 2002 21:29:52 +0200, "Richard" <pop### [at] iprolinkch> wrote:
Personally I think that's your mistake. Whole sphere_sweep object is NOT
spline. It is object which controls its parameters with splines. The path
where centers of spheres are placed is spline. The radius function in 'time'
is spline. If the max radius is 'bigger' than curvature/run of center spline
then smaller radii with theirs centers are completly hidden inside big radius.
Moreover You took quoted sentence from 'lathe' chapter not from sphere_sweep
one. Lathe is not sphere_sweep either. I hope my answer was understable since
my English limits such explanations.
ABX
Date: 11 Jun 2002 14:06:22
Message: <3d063c1e$1@news.povray.org>
Thanks for the detailed explanation. I know the center path is a spline as I
use this extensively in another scene where it works very well. I then went
on to assume that one could control the outer surface as well. It seemed a
reasonable assumption based on the linear spline and b spline results.Thats
the trouble with making assumptions. I will stick with the b spline - it
works fine for my needs.
Richard
news:9a8bguo643ubbncriskpc1a9pumoqtn6pe@4ax.com...
smooth
to
Is
'time'
spline
radius.
sphere_sweep
since
> ABX
Date: 11 Jun 2002 14:07:28
Message: <3d063c60$1@news.povray.org>
Richard
smooth
to
Is
'time'
spline
radius.
sphere_sweep
since
> ABX
