POV-Ray : Newsgroups : povray.beta-test : Buglist 22 Apr 2002 (RC2) Server Time
3 Jul 2026 18:00:52 EDT (-0400)
  Buglist 22 Apr 2002 (RC2) (Message 25 to 34 of 34)
Subject: Re: Buglist 22 Apr 2002 (RC2)
Date: 25 Apr 2002 19:30:04
Message: <3CC890FC.3090007@videotron.ca>
Thorsten Froehlich wrote:
> In article <2oY### [at] econymdemoncouk> , Mike Williams
> <mik### [at] nospamplease>  wrote:
>>Text objects appear to be slightly tilted
>>http://news.povray.org/3C306096.7040705@videotron.ca
> Was explained in the thread.
No.  What was explained was that I had to scale the text object by 10000
to make the problem visible to the naked eye.
It appears that as the truetype font is parsed, a little error is added
to the z component of every control point.  Since this is not reported
with other splines or polygons*, I must assume that it is a problem with
the code that converts the 2D set of control points of a truetype font
to POV 3D points.
*I'm downloading RC2 as we speak, I'll test my theory tonight.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 26 Apr 2002 14:10:12
Message: <3cc99804@news.povray.org>
In article <3CC### [at] videotronca> , Francois Labreque
> to POV 3D points.
But in order to assume this you already assume that (a) text characters are
internally presented by the same primitive as other objects and (b) that
characters are converted to 3d shapes before being rendered.  Both assumptions
are incorrect.
There is no "little error is added to the z component of every control point"
as the source code (of 3.1 for you right now, but nothing changed in 3.5)
clearly shows.
As I have pointed out numerous times before, this is simply a precision error
no matter how much you or others test your "theory", looking at the "fact" -
the source code - easily proves your "theory" wrong.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 26 Apr 2002 20:53:27
Message: <3CC9F5F2.4020303@videotron.ca>
>>to POV 3D points.
> are incorrect.
I didn't mean to say that truetype fonts were converted to meshes or
prism objects, if that's what you think.  I made these "assumptions"
assumption because, as you recommend below, I looked at the source code
before making that reply and misinterpreted what GetZeroOneHits() does.
> clearly shows.
Again, sorry for using the wrong words. but...
You said "precision error", I said "little error addred to the z
component".  Don't you think that amounts to the same thing?
The fact remains that:
- the longer the string, the larger the imprecision.
- this only affects text objects.
- it always increases in a left-to-right, top to bottom fashion.
- By the same amount.
It seemed to me like something that could be fixed.  But if you say it
can't, then I'll drop the issue.
Date: 3 May 2002 22:53:17
Message: <Xns9203E8D451613csbhccse@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3cc34e42@news.povray.org:
From the fixed bugs section:
> * Function namespace problem
>   (Declared function names can't be used as macro parameter names. Might
>   not be possible to be fixed with the current parser. This is being
>   investigated.)
>   Reported in:
> function declaration and namespace
> http://news.povray.org/l2ji3uc2k9su99o2gct3n2thgqoq7f4pd5@4ax.com
This one is still present / back in part in Windows RC3 with regard to
#macro names rather than functions.
Example scene:
#macro Center(obj)
object {obj}
#include "shapes.inc"
Parsing fails on line 248 of shapes.inc when the Spheroid macro attempts to
use 'Center' as a parameter name.
If this can't be fixed in the parser, could the standard includes be
modified so their parameter names are all lower case (like all other Pov
keywords) or otherwise mangled to reduce the chances of collisions with
user macros?  Coming up with macro names that don't collide is a real
headache as long as this bug is in place because so name good names are
already wasted on macro parameters.
Date: 4 May 2002 05:16:38
Message: <3cd3a6f6@news.povray.org>
In article <Xns### [at] 204213191226> , che### [at] sympaticoca
Well, how is a limitation going to be removed if nobody in the past four years
complained about it?
It isn't a new limitation in 3.5 also you seem to give that impression.
Having the same name twice in the same namespace simply cannot work.  It is
definitely not a bug and the documentation explains the namespace rules.
    Thorsten
Thorsten Froehlich
Date: 4 May 2002 18:35:40
Message: <3CD46365.433CEFA3@hotmail.com>
> Example scene:
> #macro Center(obj)
> object {obj}
> #end
> attempts to use 'Center' as a parameter name.
> Pov keywords) or otherwise mangled to reduce the chances of collisions
> with user macros?  Coming up with macro names that don't collide is a
> real headache as long as this bug is in place because so name good
> names are already wasted on macro parameters.
A consistent naming scheme will alleviate this problem.
For instance, I prefix vector names with a v, scalars with s,
index variables with i, and so on.
John
Rusty is rendering!
Date: 5 May 2002 02:51:37
Message: <Xns92051D18BE4E6csbhccse@204.213.191.226>
John VanSickle <evi### [at] hotmailcom> wrote in news:3CD46365.433CEFA3
@hotmail.com:
This is what I'd call putting the cart before the horse.
Given that shapes.inc and the other #macro-laden #includes are a standard
part of the distribution, I tend to think it'd make far more sense for them
to use a consistant naming scheme to stay out of the *users* hair rather
than for the user to go through all kinds of contortions to stay out of the
#include's hair.
I mean, you wouldn't like the idea of prefixing every name in a C program
with an underscore (etc) so it wouldn't collide with names used by the C
RTL, would you?  Of course not.  That's why the component names used by C
RTL are prefixed with underscores: so the user gets virtually the rest of
the non-defined namespace to himself/herself.
Date: 5 May 2002 02:57:30
Message: <Xns92051E17F8CBDcsbhccse@204.213.191.226>
"Thorsten Froehlich" <tho### [at] trfde> wrote in
news:3cd3a6f6@news.povray.org:
Try this on 3.1:
#macro Center(Obj)
object {Obj}
#declare X = sphere {0,1}
Center (X)
It won't choke.  Now try it on 3.5.  Now try to find anything in the
documentation that says this code is no longer valid under 3.5.
(Yes, I know /why/ it won't choke 3.1...  The reason why it won't choke 3.1
is irrelevant; the fact that it *does* choke 3.5 is the problem.)
Please tell that to the RC3 binary.  It copes just fine with #declared/
#localed names that match macro parameters:
#local X = function(x,y,z) {x+y+z}
#macro A(X) #end
Given that there's no valid reason to use the output of a macro to
determine the name of another macro's parameters, not performing macro
expansion during this portion of parsing seems reasonable for consistancy's
sake alone.  For instance, why should the code above work when #macro X()
#end #macro A(X) #end doesn't?
In this specific case, telling the user that he/she can't do #macro A()
#macro B(A, D) is rather pointless when the user doesn't know that #macro B
(A, D) exists in the first place.  The point is that the standard includes
are consuming huge swaths of the namespace without any real documentation
or regard for what they might be stepping all over.  Finding safe names was
not a matter of luck with 3.1; it is very much a matter of luck with 3.5 as
soon as one #includes anything.  I don't think this change is particularly
rational or user friendly.
Again, if the parser cannot practically be fixed at this stage, could the
standard includes at least be modified so their macro parameter names are
all lower case (like all other Pov keywords), mangled to reduce the chances
of collisions with user macros, or added to the reserved keywords list in
docs section 6.1.1?
Date: 5 May 2002 13:39:13
Message: <3cd56e41@news.povray.org>
> #macro A(X) #end
But that is a completely different case!  X is known to be a variable in both
cases and the variable namespace is well-defined.
You would be surprised what one can do (also the above can't be done) inside
macro parameter lists...
Because macros are in a completely different namespace.  In particular are
#macros behaving like macros and not functions (see <http://www.povray.org/
working-docs/id000153.html#6_2_8_3>) here.
As you know, #locals have a scope that is limited to files or the current
block while #macros are in a global namespace not really shareable with
#declares.  As POV-Ray identifiers are typeless there is significantly more
ambiguity when parsing such constructs.
As for the actual problem, by disallowing #declares (and anything that
implicitly declares an identifier) in parameter lists of #macro definitions
one can allow #macro identifiers as parameter names.  Nevertheless, this might
break some old scenes...
    Thorsten
Thorsten Froehlich
Date: 6 May 2002 18:41:35
Message: <3CD707D1.9A1840B7@hotmail.com>
> @hotmail.com:
> standard part of the distribution, I tend to think it'd make far more
> sense for them to use a consistant naming scheme to stay out of the
> *users* hair rather than for the user to go through all kinds of
> contortions to stay out of the #include's hair.
> program with an underscore (etc) so it wouldn't collide with names
> used by the C RTL, would you?  Of course not.  That's why the
> component names used by C RTL are prefixed with underscores: so the
> user gets virtually the rest of the non-defined namespace to
> himself/herself.
But I also use a consistent naming convention to avoid trampling
my own variables as well.
John
Rusty is rendering!
