POV-Ray : Newsgroups : povray.beta-test : Function image type mirrored vertically Server Time
16 Oct 2026 17:02:53 EDT (-0400)
  Function image type mirrored vertically (Message 16 to 35 of 35)
<<< Previous 15 Messages Goto Initial 35 Messages
Subject: Re: Function image type mirrored vertically
Date: 7 Apr 2002 05:17:23
Message: <3cb00ea3@news.povray.org>
In article <3caf823a@news.povray.org> , "Rune" <run### [at] mobilixnetdk>
wrote:
> Right, then one coordinate system is reversed vertically compared to the
> other. Why do you say it isn't reversed when obviously everyone can see that
> it is indeed reversed, no matter what you choose to call it?
It isn't reversed. It is in exactly in the same coordinate system as in all
other images!
>> When generating the image the origin and coordiante
>> system of an image is used.  This means that the
>> upper left is (0,0) and the lower right of the image
>> generated is function value (1,1).
> Yet, strangely, when using an image map the upper left corner is at (0,1)
> and the lower right corner is at (1,0). This is because POV-Ray takes care
> of the correction for the user.
> Why can't POV-Ray correct the alignment for the user when using the function
> image type, so that the user won't see any hint of reversed coordinates?
It is correct just like for all other image map types.  As I pointed out, try
to substitute the function image by a plain image map.  You will notice that
the origin of the image is of course still at (0,0) in image coordinates,
which equals (0,1,0) in POV-Ray coordinates.  The function is also at exactly
this place, (0,0) in image coordinates and (0,1,0) in POV-Ray coordinates.
So you generate an image using a function inside the image coordinate system,
which goes from (0,0) to (1,1) where (0,0) is defined as the upper left and
(1,1) as the lower right.  The (0,0) is then mapped to (0,1,0) and the (1,1)
is mapped to (1,0,0) like for all other image formats.
    Thorsten
e-mail: tho### [at] trfde
Date: 7 Apr 2002 06:43:42
Message: <3cb022de$1@news.povray.org>
> coordinate system as in all other images!
Please see my other reply to you in this thread where I have better
explained my point.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Mar 19)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 7 Apr 2002 09:10:23
Message: <3cb0453f@news.povray.org>
It will be interesting to see how many more of these Rune vs. Thorsten
fights will we see before the final release... ;)
Date: 7 Apr 2002 10:52:59
Message: <3cb05d4b@news.povray.org>
> Rune vs. Thorsten fights will we see before the final
> release... ;)
I consider a discussion to be an attempt at obtaining mutual understanding.
I don't care if Thorsten convinces me or I convince him, I just don't like
when one part quit the discussion before mutual understanding has been
reached...
Rune
Date: 7 Apr 2002 11:31:13
Message: <3cb06640@news.povray.org>
> reached...
  Sometimes just stopping is the only solution if the other one just refuses
or is incapable of understanding.
Date: 7 Apr 2002 11:53:24
Message: <3cb06b74@news.povray.org>
> other one just refuses or is incapable of understanding.
But I don't think Thorsten is incapable of understanding... ;)
Seriously, I don't think Thorsten have responded to my argument yet, so I
think it would be fair to keep the discussion running as long as we keep
getting closer to mutual understanding, as I think we are.
Rune
Date: 7 Apr 2002 12:36:24
Message: <vqs0bu03i34uou7ek8b0e6qre8q6t680cu@4ax.com>
On Sat, 6 Apr 2002 00:23:15 +0200, "Rune" <run### [at] mobilixnetdk> wrote:
> The function image type is mirrored vertically.
As I understand all those discussion (with my poor language):
When function 100, 100 {...} is performed it means that engine samples space
from <0,0,0> to <1,1,0> and makes grid of values. After sampling it isn't
coordinate system at all. It is internally flat grid/array[100][100] of values
just like grid with values of pixels/colors in images. Then it is passed to the
same procedure as typical image. This is separated procedure and it doesn't
metter what grid is. Grid is a grid, it is placed/mapped from <0,1,0> to <1,0,0>
becouse general rule for images is that first line of grid makes top line of
image. Right ?
ABX
Date: 7 Apr 2002 13:01:07
Message: <seu0bu45o99vgvg0cn804nrckdd3p1bs6h@4ax.com>
On Sun, 07 Apr 2002 18:50:23 +0200, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> No, a real image is generated internally, there is no special traetment for
> function images at all.
so, at parse time internal grid (as image) is generated by sampling content of
function, and rest about mapping rules is right in my post ?
ABX
Date: 7 Apr 2002 13:12:08
Message: <3cb07de8$1@news.povray.org>
In article <seu0bu45o99vgvg0cn804nrckdd3p1bs6h@4ax.com> , W„odzimierz ABX
Yes.
    Thorsten
Date: 8 Apr 2002 10:52:54
Message: <3cb1aec6@news.povray.org>
> Yes.
The problem is that POV-Ray assumes the pattern function to have the origin
in the upper left corner like all the other image types, when in fact
patterns have the origin in the lower left corner *unlike* all the other
image types. So just because all the other image types are reversed, it
doesn't mean that the function image type should be too. Thorsten, I haven't
yet heard your argument against this.
In POV-Ray x is defined as right and y is defined as up. Thus, when
considering the square from <0,0,0> to <1,1,0>, which is the square POV-Ray
use for the pattern image type, the origin is in the lower left corner, not
the upper left corner. If you refuse to change the feature, could you please
explain why?
Rune
Date: 8 Apr 2002 11:40:53
Message: <abc3bugoeos5kvl7j8fb3t15t9ttjk4l4g@4ax.com>
here is my imagination of internal behaviour :
// get dimensions from script
#declare GridX=100;
#declare GridY=100;
// get function from script
#declare Content = function (x,y,z) { ... };
// create internal image as grid of values like other images
#local Image=array[GridX][GridY];
// run loop over function - array coordinates are coordinates on xy plane
#local Z=0;
#local X=0;
#while ( X/(GridX-1) <= 1 )
  #local Y=0;
  #while ( Y/(GridY-1) <= 1 )
    #local Image[X][Y] = Content(X,Y,Z); // nothing is reversed in grid
    #local Y=Y+1;
  #local X=X+1;
// now content is array with image/grid of values
// put it to general procedure for all image types
// this is unified procedure for all images
// no internal handling for function images
#macro CreateFunctionFromImage(x,y,z,Image)
  #local ImageX = X;
  #local ImageY = 1-Y // becouse first line of image is top line on screen
  function{ Image( ImageX , ImageY, 0 ) }
ABX
Date: 8 Apr 2002 12:31:00
Message: <3cb1c5c4@news.povray.org>
Sorry, but the internal behavior really isn't the issue here. Technically
I'm sure it would be no problem to change the pattern image type if it was
desired. The issue is if the current behavior is right or wrong.
Rune
Date: 8 Apr 2002 13:03:38
Message: <kai3bu8povci61bchrs06cuoebe63s7hq4@4ax.com>
For me as user it is just automatic behaviour. If I know this behaviour (I know
it becouse of You, thanks btw) I can control it. Your problem is kind of:
why function{pattern{checker}} is different than
function{pigment{checker}.gray}}
ABX
Date: 8 Apr 2002 13:15:16
Message: <ncj3buke8fr0fo325dc2p43o9abefmv0sk@4ax.com>
I don't think You have answered to my argument about better kerning handling in
standard include files, btw. Feel free to send me ANY answer.
ABX
Date: 8 Apr 2002 14:14:43
Message: <3cb1de13@news.povray.org>
In article <3cb1aec6@news.povray.org> , "Rune" <run### [at] mobilixnetdk>
The function is evaluated as if (actually is) an image was generated from it.
Thus the evaluation takes place in the image space, not the scene space.
    Thorsten
Date: 8 Apr 2002 14:58:01
Message: <3cb1e839$1@news.povray.org>
> better kerning handling in standard include files, btw.
Sorry, I haven't had time to investigate it yet and there are still several
things that needs to be done that I consider of higher priority. But when I
get time I'll look into it and come back to you on this. As I haven't looked
into it yet, I'm not saying that your arguments are wrong.
Rune
Date: 8 Apr 2002 14:58:11
Message: <3cb1e843@news.povray.org>
> was generated from it. Thus the evaluation takes place
Image space doesn't have to be the same for all image types. For most image
types the origin is defined as being in the upper right corner. Because this
is a standard in those image types, the user can be sure that up will always
remain up and down will remain down. What corner of the image is the origin
doesn't really matter, but one corner had to be chosen so that the user can
count on the alignment always being the same.
Now, when choosing what corner should be the origin in the function image
type, one should choose the best solution for *this* image type, not just
use the same as for all the other image types. So what is the best solution
for the pattern image type?
Well, naturally it is to use the same coordinate definition as used
everywhere else in POV-Ray, i.e. the corner being in the lower right corner.
That is what users expect both logically and intuitively.
It's important for me to point out that what you call "image space" can be
whatever you make it to, so you have to choose the image space that is the
*best* solution. I have argued that having the origin in the lower left
corner is the image space that is easiest to understand for users. What is
your argument for using a different image space)?
To me it seems like you keep assuming that there is only one possible
definition of image space and that is the one the other image types use.
Rune
Date: 8 Apr 2002 15:16:26
Message: <3cb1ec8a$3@news.povray.org>
Rune, I think I get your point, but don't you think you have beaten this
horse enough?
Isn't the solution as easy as using image_map {function 100, 100
{F(x,1-y,z)}} in your code? One additional sentence in the docs could point
this out to everyone who is not able to work it out him/herself.
I know, that's not your point, but if the solution is that simple, that even
I can work it out in no-time, I don't think it's worth to discuss this in
such extend. In another eight days it's time for the next beta and afaik
there are quite some bugs left to work on.
Just my opinion,
Marc-Hendrik
Date: 9 Apr 2002 17:02:56
Message: <3cb35700$1@news.povray.org>
> think you have beaten this horse enough?
I think the behavior is wrong and if it isn't fixed before the final release
of POV-Ray 3.5, then we will be stuck with this annoyance forever to ensure
backwards compatibility.
I just don't get it. I make an image in a paint program. It's correctly
aligned (the image is not upside down). I use this image as an image_map.
It's still correctly aligned.
I use this image in a function and use the function as a pattern in a
pigment. It's still correctly aligned.
Now I use the image in a function in an image_map. Now it's upside down! And
*that* is consistency???
Thorsten keeps saying that the function image type use "image space"
coordinates, but he has not yet explained why the function image type has to
use the same definition of image space, when the concept of up and down is
the opposite in function coordinates than it is in all external image
formats.
But no, I can't get any explanation despite of how long this thread has been
running by now...
I also would have liked to hear other people's thoughts on what would be the
correct behavior, but apparently no one have anything to say about it.
Rune
Date: 10 Apr 2002 22:45:32
Message: <chrishuff-6F5B10.22471710042002@netplex.aussie.org>
In article <3cb35700$1@news.povray.org>,
I agree. POV should make sure the *upper left corner* is at < 1, 0>, not
the internal image coordinates < 0, 0>. I highly doubt anybody thinks in
terms of these "image space" coordinates when writing a function. The
upper left corner is at < 1, 0>, there is no obvious reason for that to
suddenly be treated as < 0, 0>, and for the y coordinate to be negated.
It is also an annoying inconsistency when using a function both directly
and as a function image. When no special warping or mapping is done, the
function image should have the same orientaion as the function.
I can only see this causing confusion and frustration, no matter how
well documented it is.
