POV-Ray : Newsgroups : povray.beta-test : Round_Box #macro (in shapes.inc) and negative values Server Time
21 Mar 2026 05:10:02 EDT (-0400)
  Round_Box #macro (in shapes.inc) and negative values (Message 11 to 14 of 14)
Subject: Re: Round_Box #macro (in shapes.inc) and negative values
Date: 22 Apr 2002 08:48:08
Message: <tu01aa.722.ln@wiemann.my-fqdn.de>
Christoph Hormann wrote:
> If you have code automatically generating such objects you can always
> catch those special situations yourself, just write a wrapper macro
> and usage would not be much more difficult.
Do you want to use a macro for 20000 objects (e.g. generated by a
modeller) ? That would be *really* slow.
Felix Wiemann
Date: 22 Apr 2002 08:48:09
Message: <k211aa.822.ln@wiemann.my-fqdn.de>
Fabien Mosen wrote:
> I guess that the degenerate triangle doesn't stop parsing because
> it would be a PITA to manually remove one or two triangles from
> a several thousand triangles externally generated mesh.  If an
> external utility generated a net of cylinders, for example, to
> represent a mesh as a wireframe, it would still be a PITA to
> catch the degenerate ones.  That's why POV-Ray should remove
> them with a simple warning, and not stop.
You're right, that's a good idea.
Felix Wiemann
Date: 22 Apr 2002 12:01:35
Message: <3CC433DE.2FEB8B6@gmx.de>
The modeller should take care of this itself.
In fact i even think a box with two identical points should generate an
error or warning since it is not very clear if this results in no object
or a single point.  Equally it's not clear what to make of a cylinder with
identical end and base point (you could expect nothing, a point or a
sphere), just dropping it would be incorrect.
Last updated 20 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 23 Apr 2002 10:08:30
Message: <3cc56ade@news.povray.org>
And if the modeller doesn't? :)
> an error or warning since it is not very clear if this results in no
> object or a single point.
A single point, I think. But you're right, a warning would be a good
idea.
> with identical end and base point (you could expect nothing, a point
> or a sphere), just dropping it would be incorrect.
I expect a disc. :)
Of course dropping would be incorrect, but I think that generating a
warning (so the user is noticed that something may go wrong) is a
better and more flexible solution than stopping with an error.
Felix Wiemann
