![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
While working on a new version of the IsoCSG library, i came across
several problems in beta 16.
(Beta 16 icl, WinNT4, K6)
1) The following code generates an error about recursive function calls
(in both versions for '#declare fn_A...'):
#declare IC_Arr=array[4]
#macro IC_Merge4(fn_A, fn_B, fn_C, fn_D)
function {
min(fn_A(x, y, z),
fn_B(x, y, z),
fn_C(x, y, z),
fn_D(x, y, z))
#declare IC_Arr[0]=function(x, y, z) { x }
#declare IC_Arr[1]=function(x, y, z) { y }
#declare IC_Arr[2]=function(x, y, z) { z }
#declare IC_Arr[3]=function(x, y, z) { x+y }
//#declare fn_A= IC_Merge4(function { IC_Arr[0](x, y, z) }, function {
IC_Arr[1](x, y, z) }, function { IC_Arr[2](x, y, z) }, function {
IC_Arr[3](x, y, z) })
#declare fn_A= IC_Merge4(IC_Arr[0], IC_Arr[1], IC_Arr[2], IC_Arr[3])
2) The following code crashes Povray during render (requires iso_csg 0.3)
I tried to simplify this, but came across the problem mentioned above and
therefore had difficulties making a simple example.
#version 3.5;
global_settings {
assumed_gamma 1.0
background { color <0.750,0.500,0.300> }
location <0.2,0.2,-1>
look_at <0,0,0>
right (4/3)*x
light_source {
<1000, 2500, -5000>
color rgb 1.2
#include "iso_csg.inc"
#declare IC_Arr=array[12]
#macro IC_Merge_Array(Array)
#local Size=dimension_size(Array,1);
function {
min(
#local Counter=0;
#while (Counter<Size)
#if (Counter>0) , #end
Array[Counter] (x,y,z)
#local Counter=Counter+1;
#declare IC_Arr[0]=IC_Cone(0, 0, x+y, 1)
#declare IC_Arr[1]=IC_Rotate(IC_Arr[0], 30*z)
#declare IC_Arr[2]=IC_Rotate(IC_Arr[1], 60*z)
#declare IC_Arr[3]=IC_Rotate(IC_Arr[2], 90*z)
#declare IC_Arr[4]=IC_Rotate(IC_Arr[3], 120*z)
#declare IC_Arr[5]=IC_Rotate(IC_Arr[4], 150*z)
#declare IC_Arr[6]=IC_Rotate(IC_Arr[5], 180*z)
#declare IC_Arr[7]=IC_Rotate(IC_Arr[6], 210*z)
#declare IC_Arr[8]=IC_Rotate(IC_Arr[7], 240*z)
#declare IC_Arr[9]=IC_Rotate(IC_Arr[8], 270*z)
#declare IC_Arr[10]=IC_Rotate(IC_Arr[9], 300*z)
#declare IC_Arr[11]=IC_Rotate(IC_Arr[10], 330*z)
#declare fn_XX= IC_Merge_Array(IC_Arr)
isosurface
function { fn_XX(x, y, z) }
max_gradient 1.6
contained_by { box { -2, 2 } }
pigment { rgb <0, 0.2, 1.1> }
finish { specular 0.3 }
scale 0.1
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 08 Apr 2002 17:13:30 +0200, Christoph Hormann <chr### [at] gmx de>
POV 3.5 b 16 icl on WinNT4 Sp 6 PII 233 with 128 MB
POV 3.5 b 16 icl on Win2K PIII ~700 with 64 MB
IC_Merges works fine in my modified version of your isocsg (changes are probably
the same as in your file)
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Problems with functions in beta 16
Date: 8 Apr 2002 12:55:09
Message: <3CB1CB6D.7E9209F5@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You mean both samples work on your machines? Note that it isn't a general
problem of IC_Merge, all samples form the IsoCSG package work correctly.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 08 Apr 2002 18:55:09 +0200, Christoph Hormann <chr### [at] gmx de>
I see, I said in general. Now here is result from your example:
1)
File: K:\test\test.pov Line: 18
IC_Arr[1] <----ERROR
Parse Error: Expected 'object or directive', function identifier found instead
2)
Started at 800x600. Stop button press when rendering slowed down on object
caused good old Dr. Watson.
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Apr 2002 13:49:33
Message: <3CB1D82D.5A3ECBB7@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You should remove the additional line breaks before rendering.
> 2)
I got a program error message 'Internal Error' 'The Povray core rendering
code caused an access violation exception...' without pressing stop
(rendering at 160x120 no aa)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 08 Apr 2002 19:49:33 +0200, Christoph Hormann <chr### [at] gmx de>
ok. everything confirmed.
ABX
disc{z,-z#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;5pigment{#local g=function(_){ceil(_)-_}function#local
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e)<O(),O()//35
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 10 Apr 2002 06:13:56
Message: <3CB4105D.D03EA180@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> function {
> min(fn_A(x, y, z),
> fn_B(x, y, z),
> fn_C(x, y, z),
> fn_D(x, y, z))
> #end
This seems to be a problem related to the duplicated name 'fn_A', when
using different identifiers inside and outside the macro it works.
I have no idea about the reason for the other problem, but it could be
some function size limit, the resulting function is fairly long and the
crash does not occur when only merging 8 functions.
Both problems already occur in beta 15 BTW.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 15 Apr 2002 04:58:23
Message: <3CBA962F.4E9318C0@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And still in RC1.
Last updated 14 Apr. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 18 Apr 2002 16:17:22
Message: <3cbf29d2@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3CB1B39A.3F70A85A@gmx.de> , Christoph Hormann
Yes, because the detection of recursive calls has to rely on the function
name. Due to the way declares are parsed other information to handle scope
better is not available. Consequently this will not be fixed in 3.5 as it
requires a redesign of the POV-Ray parser (or some really ugly hacks in 3.5).
The solution for this particular bug is to not insert functions with the same
name in a function that is being declared also those are accepted by the
parser.
Where can I get "iso_csg 0.3"?
As far as the problem is concerned (which I could not verify due to the
missing file), as mentioned above the name check is not really perfect and
with some skill one can probably create a recursive function call using macros
and by exploiting various parser loopholes. Your problem may or may not be
related to this. I can say more once I can parse the scene...
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 18 Apr 2002 16:26:46
Message: <3CBF2C05.3C5826FA@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/index.html
(current version already includes the IC_Merge_Array() macro )
To me it seems this problem is related to the length of the function (or
to the depth of nested declarations).
Last updated 16 Apr. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
