POV-Ray : Newsgroups : povray.beta-test : Problems with functions in beta 16 Server Time
1 Apr 2026 11:26:36 EDT (-0400)
  Problems with functions in beta 16 (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Problems with functions in beta 16
Date: 10 Apr 2002 06:13:56
Message: <3CB4105D.D03EA180@gmx.de>
Christoph Hormann wrote:
> #macro IC_Merge4(fn_A, fn_B, fn_C, fn_D)
>   function {
>     min(fn_A(x, y, z),
>         fn_B(x, y, z),
>         fn_C(x, y, z),
>         fn_D(x, y, z))
> #end
> #declare fn_A= IC_Merge4(IC_Arr[0], IC_Arr[1], IC_Arr[2], IC_Arr[3])
This seems to be a problem related to the duplicated name 'fn_A', when
using different identifiers inside and outside the macro it works.
I have no idea about the reason for the other problem, but it could be
some function size limit, the resulting function is fairly long and the
crash does not occur when only merging 8 functions.
Both problems already occur in beta 15 BTW.
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 15 Apr 2002 04:58:23
Message: <3CBA962F.4E9318C0@gmx.de>
And still in RC1.
Last updated 14 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 18 Apr 2002 16:17:22
Message: <3cbf29d2@news.povray.org>
In article <3CB1B39A.3F70A85A@gmx.de> , Christoph Hormann
<chr### [at] gmxde>  wrote:
> 1) The following code generates an error about recursive function calls
> (in both versions for '#declare fn_A...'):
Yes, because the detection of recursive calls has to rely on the function
name.  Due to the way declares are parsed other information to handle scope
better is not available.  Consequently this will not be fixed in 3.5 as it
requires a redesign of the POV-Ray parser (or some really ugly hacks in 3.5).
The solution for this particular bug is to not insert functions with the same
name in a function that is being declared also those are accepted by the
parser.
> 2) The following code crashes Povray during render (requires iso_csg 0.3)
> I tried to simplify this, but came across the problem mentioned above and
> therefore had difficulties making a simple example.
Where can I get "iso_csg 0.3"?
As far as the problem is concerned (which I could not verify due to the
missing file), as mentioned above the name check is not really perfect and
with some skill one can probably create a recursive function call using macros
and by exploiting various parser loopholes.  Your problem may or may not be
related to this.  I can say more once I can parse the scene...
    Thorsten
e-mail: tho### [at] trfde
Date: 18 Apr 2002 16:26:46
Message: <3CBF2C05.3C5826FA@gmx.de>
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/index.html
(current version already includes the IC_Merge_Array() macro )
To me it seems this problem is related to the length of the function (or
to the depth of nested declarations).
Last updated 16 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 22 Apr 2002 11:47:17
Message: <rsb8cukh345qeltb1gj6b786n374v6e076@4ax.com>
On Thu, 18 Apr 2002 22:17:19 +0200, "Thorsten Froehlich" <tho### [at] trfde>
> name.
I'm not sure it can be considered as hole in this checking system but if not
then I have simple workaround for our iso_csg library. It is possible now to
redeclare passed functions as array and array not checks recursive calls.
#declare IC_Arr=array[4]
#declare a=array[4]
  #local a=array[4]{fn_A,fn_B,fn_C,fn_D};
  function {
    min(a[0](x, y, z),
        a[1](x, y, z),
        a[2](x, y, z),
        a[3](x, y, z))
#declare IC_Arr[0]=function(x, y, z) { x }
#declare IC_Arr[1]=function(x, y, z) { y }
#declare IC_Arr[2]=function(x, y, z) { z }
#declare IC_Arr[3]=function(x, y, z) { x+y }
#declare a[0]= IC_Merge4(function { IC_Arr[0](x, y, z) }, function {
IC_Arr[1](x, y, z) }, function { IC_Arr[2](x, y, z) }, function {
IC_Arr[3](x, y, z) })
ABX
Date: 22 Apr 2002 11:53:41
Message: <3CC43204.465F89EA@gmx.de>
Have you checked this for possible performance eating side effects?  If
there aren't any this could be a possible solution although it would
probably be sufficient to use rare identifiers for the parameters.
Last updated 20 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 22 Apr 2002 12:02:53
Message: <kkc8cu02uuas71rut38epkcj1c3d7fm5ar@4ax.com>
On Mon, 22 Apr 2002 17:53:40 +0200, Christoph Hormann <chr### [at] gmxde>
I asked some day in p.a-u what happen when something like
    #local f_a=function(m){ f_b(m) }
is invoked. As answer I recived change 1502 in RC1 :-)
ABX
Date: 22 Apr 2002 13:52:52
Message: <3cc44df4$1@news.povray.org>
Either you misunderstood my very short change note or I am not remembering
correctly what you asked about the above statement...
    Thorsten
Date: 22 Apr 2002 13:57:03
Message: <3cc44eef$1@news.povray.org>
The checking is still done but in a different way.  However, for performance I
strongly recommend not to use an array but unusual variable names, i.e.
__IC_Merge4_fn_A, etc would unlikely be not unique...
    Thorsten
Date: 23 Apr 2002 03:36:27
Message: <6l3acuon0g97onv52l869gm7g39ebja5ic@4ax.com>
On Mon, 22 Apr 2002 19:52:50 +0200, "Thorsten Froehlich" <tho### [at] trfde>
It was a joke that it was answer for my question. You can find my question in
http://news.povray.org/pcojau0tsr5hk9nprsrf38s3t5ae1ht9ro%404ax.com
ABX
