POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10011104 : Re: POV-Ray v3.8.0-alpha.10011104 Server Time
6 Apr 2026 23:17:09 EDT (-0400)
Date: 13 Jan 2019 12:25:06
Message: <web.5c3b74002cb80e7848892b50@news.povray.org>
hi,
> Am 13.01.2019 um 17:11 schrieb jr:
> > I've tried with two scenes, one crashes, the other does not.  the only
> > difference, afaict, is that the first uses array syntax in both declaration and
> > in one of the function components, while the second has no array stuff.
> Then the recommended workaround probably applies to your system and, by
> extension, presumably Unix systems in general.
ok.  do you have a 'wget'able url for that file, please?
btw, the alpha (also) crashes when there's an "old-style" text primitive, ie
without cmap {}, irrespective of charset present in global_settings.  does the
above workaround fix that too?
regards, jr.
