POV-Ray : Newsgroups : povray.animations : Some frames take forever.... Server Time
24 Mar 2026 04:20:30 EDT (-0400)
  Some frames take forever.... (Message 1 to 10 of 11)
Subject: Some frames take forever....
Date: 25 Jul 2014 08:50:01
Message: <web.53d252358794cadb44617cf60@news.povray.org>
I'm rendering an animation of a somewhat complex landscape based on isosurfaces,
and rendertimes vary between 30 minutes and infinite.
I have taken the usual precautions to limit number of reflections, max_gradient
and so forth, but still a few individual frames appear to never finish, the
parallel povray processes chewing away at the last few tens of pixels.
My problem is now that I do not want to change the scene files since most of the
animation is already done and only 5 frames missing. An easy mitigation would be
to render those 5 as far as one can get, and use gimp or whatever to replace the
missing few pixels from the frames before and after - much like in standard
movie restoration.
The problem is - povray wouldn't let me have those. All it produces is a
pov-state file, and whenever I initiate any kind of abort, no image can be found
on disk (3.7, the version).
So my question is: Is there a way to abort the render such that I have the
partially (almost fully, in fact) rendered image on disk?
What would be even better still - is there a possibility to set a hard limit to
the render time of individual frames in an animation, after which povray would
give up on that frame, put the image to disk as it is, and continue with the
next one?  That would be really useful...
  m.
Subject: Re: Some frames take forever....
Date: 25 Jul 2014 10:26:03
Message: <53d268fb$1@news.povray.org>
> movie restoration.
No. But the pov-state file contains the picture you need... in internal
format. (and with a few missing squares, the ones that have not been
fully rendered)
Is the scene short-enough to be used in a bug report ?
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 25 Jul 2014 10:59:47
Message: <53d270e3$1@news.povray.org>
> fully rendered)
There is an easier format, in another file, if your frame is large
enough to trigger the file-buffered storage.
The setting is Max_Image_Buffer_Memory (MI), default 128 megabytes.
Minimal value to have a file is 1 megabyte (MI1), and
height*width*20/1048576 must then be strictly greather than the value
(so height*width*20 >= 2*1048576 , or h*w >= 104857 for -MI1)
The format is 5 floats per pixel, with the end of the file containing
the height, width and size of pixel. The five floats are the five RGBFT
channel, in that order.
Date: 25 Jul 2014 15:55:01
Message: <web.53d2b55e7498dfad8ae4a24e0@news.povray.org>
> > movie restoration.
> fully rendered)
There is a simple solution: POV-Ray knows nothing about the content of the scene
file. So it is possible to use an empty scene file to continue a trace...
Date: 25 Jul 2014 17:03:03
Message: <53d2c607$1@news.povray.org>
Intriguing! Could you expand on that, please?
When I get a scene that takes ages to finish rendering the last block. I
reduce the block size to the smallest so that I can get more cores
working on it.
Won't help if a pixel refuses to render but does speed up some files.
Regards
Date: 27 Jul 2014 13:45:00
Message: <web.53d53a6c7498dfad497bb7e10@news.povray.org>
> fully rendered)
I'm afraid right now, I cannot really isolate the offending code, especially sic
it only happens in about 3 out of 300 frames.
Date: 27 Jul 2014 13:50:00
Message: <web.53d53af67498dfad497bb7e10@news.povray.org>
> > > movie restoration.
> > fully rendered)
Interesting.  I'll give that a try, even though it still means that the
following frames don't even get started until manually halting the renderer.
Date: 27 Jul 2014 13:50:01
Message: <web.53d53b377498dfad497bb7e10@news.povray.org>
> working on it.
> Regards
>      Stephen
I do the same, but still - if in an animation of 350 frames the 264th hangs, a
lot of CPU power gets wasted.
Date: 4 Aug 2014 04:15:01
Message: <web.53df40ab7498dfad44617cf60@news.povray.org>
BTW, I am now running from an external script that provides a timeout and use
the reconstruction of pov-state files with empty scenes. Works at least.
I also found that getting stuck depends somewhat on the processor type - not all
frames get stuck on all machines.  In my sequence of 275 I only have 2 that
always refuse to render completely, the others hang only on one of three
possible machines... weird!
  m.
Date: 6 Aug 2014 06:50:01
Message: <web.53e207ef7498dfad44617cf60@news.povray.org>
> > > movie restoration.
> > fully rendered)
BTW - using a completely empty scene file is *not* always the best solution, as
apparently pov-state does not contain *all* the information.
If e.g. display_gamma is used in the original scene file, that info does not get
transmitted and the result may actually look completely different!
