POV-Ray : Newsgroups : povray.advanced-users : Vector handling Server Time
30 Mar 2026 07:57:32 EDT (-0400)
  Vector handling (Message 1 to 10 of 10)
Subject: Vector handling
Date: 3 Jun 2025 21:05:00
Message: <web.683f9ab13a0722be1f9dae3025979125@news.povray.org>
In light of the fact that I was able to solve the scalar / vector typing
problem,  I wanted to do a test of the macro with a full complement of vectors
that are composed of all permutations of negative, zero, and positive values, so
that I can test anything that might trigger some edge case and cause the macro
to fail and misidentify an argument.
To do that, I wrote a macro to generate all of the permutations for any given
vector size, however it quickly became apparent that actually outputting vectors
of any given size is a challenge.
There's no way to really assign a value to the individual vector component
Vector.z, so I'm coming up against an interesting limitation of SDL.  It's not a
trivial task to take an array of values and convert it to a vector.
Nor can I (that I know) diminish the size of a vector from 5 to 3.
(Can we have 1-component vectors?)
I don't want to use ParseString () to generate 4,000 vectors.
I also don't want to individually verify every test case, so I'll probably make
the output of the macro a scalar/vector plus the type (1, 2, 3, 4, 5) and have
the identification macro compare, and sum any errors.
Can anyone suggest a robust method for composing vectors of sizes 2 through 5
with a single, general purpose macro?
Thanks
- BE
Subject: Re: Vector handling
Date: 3 Jun 2025 23:30:00
Message: <web.683fbcb92f29ff143a63f5189db30a9@news.povray.org>
Hi Bill
Could this be something to work with?
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.7;
global_settings { assumed_gamma 1.0 }
#macro PrintSCalarOrVector(Dim, SV)
    #switch (Dim)
        #case (1)
            #debug str(SV, 0, -1)
            #break
        #case (2)
            #debug concat("<", vstr(2, SV, ", ", 0, -1), ">")
            #break
        #case (3)
            #debug concat("<", vstr(3, SV, ", ", 0, -1), ">")
            #break
        #case (4)
            #debug concat("<", vstr(4, SV, ", ", 0, -1), ">")
            #break
        #case (5)
            #debug concat("<", vstr(5, SV, ", ", 0, -1), ">")
            #break
        #else
            #error "Not a valid vector dimension"
    #end // switch
#end // macro PrintSCalarOrVector
#debug "\n"
PrintSCalarOrVector(1, 1.0)
#debug "\n"
PrintSCalarOrVector(2, <2.0, 3.0>)
#debug "\n"
PrintSCalarOrVector(3, <3.0, 4.0, 5.0>)
#debug "\n"
PrintSCalarOrVector(4, <4.0, 5.0, 6.0, 7.0>)
#debug "\n"
PrintSCalarOrVector(5, <5.0, 6.0, 7.0, 8.0, 9.0>)
#debug "\n"
#macro CreateScalarOrVector(ValueArray)
    #local Dim = dimension_size(ValueArray, 1);
    #switch (Dim)
        #case (1)
            #local SV =
                ValueArray[0]
            #break
        #case (2)
            #local SV =
                    ValueArray[0],
                    ValueArray[1]
            #break
        #case (3)
            #local SV =
                    ValueArray[0],
                    ValueArray[1],
                    ValueArray[2]
            #break
        #case (4)
            #local SV =
                    ValueArray[0],
                    ValueArray[1],
                    ValueArray[2],
                    ValueArray[3]
            #break
        #case (5)
            #local SV =
                    ValueArray[0],
                    ValueArray[1],
                    ValueArray[2],
                    ValueArray[3],
                    ValueArray[4]
            #break
        #else
    #end // switch
    SV
#end // macro CreateScalarOrVector
#debug "\n"
#declare VS =
        array[1] { 1.0 }
PrintSCalarOrVector(1, VS)
#debug "\n"
#declare VS =
        array[2] { 2.0, 3.0 }
PrintSCalarOrVector(2, VS)
#debug "\n"
#declare VS =
        array[3] { 3.0, 4.0, 5.0 }
PrintSCalarOrVector(3, VS)
#debug "\n"
#declare VS =
        array[4] { 4.0, 5.0, 6.0, 7.0 }
PrintSCalarOrVector(4, VS)
#debug "\n"
#declare VS =
        array[5] { 5.0, 6.0, 7.0, 8.0, 9.0 }
PrintSCalarOrVector(5, VS)
#debug "\n"
#debug "\n"
#error "No error, just finished"
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 4 Jun 2025 00:20:00
Message: <web.683fc8652f29ff143a63f5189db30a9@news.povray.org>
> Vector.z, ...
I'm not sure if I understand what you mean.
I just tried this - and it seems to work like I expected.
#declare v2D = <2, 3>;
#declare NewV = -33;
#declare v2D = <v2D.u, NewV>;
PrintSCalarOrVector(2, v2D)
#debug "\n"
#declare v2D = v2D*u + NewV*v;
#debug "\n"
#declare v2D = v2D*<1, 0> + <0, NewV>;
#debug "\n"
#declare v3D = <3, 4, 5>;
#declare NewZ = -55;
#declare v3D = <v3D.x, v3D.y, NewZ>;
PrintSCalarOrVector(3, v3D)
#debug "\n"
#declare v3D = v3D*(x + y) + NewZ*z;
#debug "\n"
#declare v3D = v3D*<1, 1, 0> + <0, 0, NewZ>;
#debug "\n"
#declare v4D = <4, 5, 6, 7>;
#declare NewT = -77;
#declare v4D = <v4D.x, v4D.y, v4D.z, NewT>;
PrintSCalarOrVector(4, v4D)
#debug "\n"
#declare v4D = v4D*(x + y + z) + NewT*t;
#debug "\n"
#declare v4D = v4D*<1, 1, 1, 0> + <0, 0, 0, NewT>;
#debug "\n"
#declare v5D = <5, 6, 7, 8, 9>;
#declare NewTransmit = -99;
#declare v5D = <v5D.red, v5D.green, v5D.blue, v5D.filter, NewTransmit>;
PrintSCalarOrVector(5, v5D)
#debug "\n"
#declare v5D = v5D*<1, 1, 1, 1, 0> + <0, 0, 0, 0, NewTransmit>;
#debug "\n"
Tor Olav
http://subcube.com
Date: 4 Jun 2025 06:45:00
Message: <web.6840237b2f29ff11f9dae3025979125@news.povray.org>
Long time, no see, Mr. K   :)
I hope you are personally well, and professionally successful.
Now with
https://news.povray.org/povray.general/message/%3Cweb.682bc388985098ff1f9dae3025979125%40news.povray.org%3E/#%3Cweb.682
You don't need the whole #switch block below to handle individual vector sizes.
just
#declare SV = VectorDimTest (v0);
>     #switch (Dim)
>         #case (1)
>             #break
>         #case (2)
>             #break
>         #case (3)
>             #break
>         #case (4)
>             #break
>         #case (5)
>             #break
>         #else
>     #end // switch
Also, when I stated that i couldn't change Vector.z, I meant by directly
addressing it, like you're doing below with array elements.
I can't say #declare Vector.z = NewValue.
And the awkwardness really kicks in when I'm trying to create a macro like
#macro PermuteVector (SV)
where I just want to make any size vector on the fly and have the result of the
macro be a vector of size SV.   Because it is NOT like working with arrays.
I started off by doing
#local V = array {<1, 0, 0, 0, 0>, <0, 1, 0, 0, 0>, <0, 0, 1, 0, 0>, <0, 0, 0,
1, 0>, <0, 0, 0, 0, 1>};
#local Vector = <0, 0, 0, 0, 0>;
to "address" the individual components (in)directly, but now I'm stuck not
knowing how to take <1, 2, 3, 0, 0> and convert it to <1, 2, 3>.
I would like a simple method to MAKE vectors of an arbitrary (allowed) size,
just like vstr () PRINTS vectors of an arbitrary size.
#declare MyVector = mstr (...)
This sort of hearkens back to the epic dot notation thread where I suggested
vec.n where n = 1...5 as a valid syntax (though that still wouldn't solve the
problem, given the inability to use those as an LValue)
Making a vector from array elements requires a lot of hands-on, fussy, one-off
coding for specially constructing each individual size of vector.  POV-Ray
should be better than that.
- BW
>     #switch (Dim)
>         #case (1)
>             #local SV =
>                 ValueArray[0]
>             #break
>         #case (2)
>             #local SV =
>                     ValueArray[0],
>                     ValueArray[1]
>             #break
>         #case (3)
>             #local SV =
>                     ValueArray[0],
>                     ValueArray[1],
>                     ValueArray[2]
>             #break
>         #case (4)
>             #local SV =
>                     ValueArray[0],
>                     ValueArray[1],
>                     ValueArray[2],
>                     ValueArray[3]
>             #break
>         #case (5)
>             #local SV =
>                     ValueArray[0],
>                     ValueArray[1],
>                     ValueArray[2],
>                     ValueArray[3],
>                     ValueArray[4]
>             #break
>         #else
>     #end // switch
>     SV
Date: 4 Jun 2025 08:25:00
Message: <web.684039f82f29ff18becbc4525979125@news.povray.org>
OK, there was nary a drop of coffee in my veins, my eyes were blurry, and I was
fielding questions about an interstate flight while trying to process this.
After re-reading after Second Coffee, I can probably use a #for loop to plug the
appropriate number of array elements into a vector to get what I want.
Will try that after I get home 8h from now ... <eyeroll>
Anyway, try the type-identifying macro and see what you think.
Sorry for the confusion.
- BW
Date: 4 Jun 2025 20:20:00
Message: <web.6840e19e2f29ff11f9dae3025979125@news.povray.org>
Ugggggggh.
I got the vector-creating to work, plugged that into the permutation macro, and
got everything written to a file.
Got an error in my scalar part of the #if block, which led me to believe that
there was a misidentification.
So I made a few modifications, and this is what I presently have:
3904 vectors written to TestedValues.txt.
3204 identified correctly.
700 misidentified.
So there is some combination of values that sabotage my algorithm (which is
exactly why I wanted to test 3904 vectors).
I will modify to output the offending vectors to a separate file, and then get
on with seeing if there's a way to "win".
- BW
Date: 9 Jun 2025 18:30:00
Message: <web.6847601a2f29ff11f9dae3025979125@news.povray.org>
> 700 misidentified.
And there seems to be (at the moment)!
3904 identified correctly.
0 misidentified.
CPU time used: kernel 2.59 seconds, user 1.34 seconds, total 3.93 seconds.
Elapsed time 3.98 seconds.
NOW see if you can break it!
- BW
Download 'vectorpermutations.pov.txt' (7 KB)
Date: 9 Jun 2025 19:10:01
Message: <web.684769482f29ff11f9dae3025979125@news.povray.org>
I added 2 more bracketing values to be randomized between -100 and 100, then ran
it again.
19604 identified correctly.
0 misidentified.
Then I ran everything again plus had the the macro generate 5-component vectors
(the former problem) 5 times in a row (randomized).
86836 vectors written to TestedValues.txt.
86836 identified correctly.
0 misidentified.
It's looking good.   :)
-BW
Date: 9 Jun 2025 19:25:00
Message: <web.68476cd52f29ff11f9dae3025979125@news.povray.org>
Looped PermuteVectorComponents (5) fifty times.
Commented out the fopen-write-fclose since I don't need the output in the
absence of misindentifications.
run time
4m 42s
843196 vectors written to TestedValues.txt.
843196 identified correctly.
0 misidentified.
In the absence of a vector triggering a misidentification, I'm going to call
this 30+ year stumbling block solved.
It would be great if I didn't clog the warning stream with 843,000+ "suspicious
expression after rgb" messages . . .      :\
- BW
P.S. I'm also thinking that maybe the folks over on one of the math / statistics
fora could come up with a better / more efficient way.
Date: 9 Jun 2025 21:50:00
Message: <web.68478f382f29ff11f9dae3025979125@news.povray.org>
OK, I spoke too soon - I was lazy and was leaving out the testing of the
scalars.
Somehow _1_ broke it.
I modified, then _0_ broke it.
I modified again, looked good, tested with sizes 1-5, and all looked well.
IIRC, what brought me back to this was an annoyance with needing to test all
vector sizes separately with size-dependent macros.  And I think I needed a
general solution for . . . something.
I also vaguely recall that sometimes I wanted to compare vectors of unequal
sizes - only comparing the number of components of the smallest vector.
So I added a Boolean flag to do a partial comparison.
And this is what I have so far.  Ugly development code, warts and all.
Needs more testing, since there's probably something else lurking in there.
- BW
Download 'newvectorequalitymacro.pov.txt' (5 KB)
