hi,
"Bald Eagle" <cre### [at] netscape net> wrote:
> > Kinda looks like a "dog bone" wood patch that alternates in directions like a
> > checkerboard.
> Sometimes these things are a little easier to write using some helper functions.
> #declare S2P = function (V) {sin (tau*V/L)}
> #declare C2P = function (V) {cos (tau*V/L)}
> #declare T = 0.5;
> #declare N = 1;
> #declare Honeycomb = function (X, Y, Z) {pow(S2P(X)*C2P(Z) + S2P(Z) + C2P(X), N)
> - pow(T, N)}
plane with "Honeycomb" pattern, seen through "kaleidoscope".
regards, jr.
Download 'ktpms.png' (440 KB)
Preview of image 'ktpms.png'
Wheee! Nice job. :)
Can you adjust the symmetry? Have 6-fold, or 7?
After playing with this stuff a bit, it seems like that whole sin*cos xy yz zx
thing has a lot of potential as a base pattern to do all sorts of interesting
things with. Even just the threshold can change the apparent look quite a bit.
And then you have the orthogonal plane value/slice to vary.
We can square the whole sum, square the terms, take the root, etc.
- BW
hi,
> Wheee! Nice job. :)
start on. :-)
yes, I just discovered that replacing "tau" with "pi * scale_factor" and using
slightly different factors, things get real .. interesting.
re your question, I answer with an Obama quote: "Yes, we can" :-) below is
excerpted from my WIP code:
/* added bailout & max_trace */
global_settings {adc_bailout (1/254) assumed_gamma 1 max_trace_level 255}
/* #mirrors */
#declare n_ = 3;
#declare angle_ = 360 / n_;
/* epsilon */
#declare eps_ = 1e-3;
/* length of tube */
#declare len_ = 10;
/* prism with hole */
#declare pi_ = <.99,0,0>;
#declare po_ = <1.01,0,0>;
#declare pts_ = array [n_][2];
#for (i_, 0, n_-1)
#local ta_ = vrotate(po_, <0,(angle_*i_),0>);
#local tb_ = vrotate(pi_, <0,(angle_*i_),0>);
#local pts_[i_][0] = <ta_.x,ta_.z>;
#local pts_[i_][1] = <tb_.x,tb_.z>;
/* rotate to centre on -z */
prism {
linear_spline eps_, len_, 2*(1+n_),
#for (i_,n_-1,0,-1) pts_[i_][0], #end pts_[n_-1][0],
#for (i_,0,n_-1) pts_[i_][1], #end pts_[0][1]
open
sturm on
no_shadow
finish {ambient 0 reflection {1} specular 0}
rotate <270,0,0>
regards, jr.
This one looks like sliced pita bread or hot dogs buns or something.
#declare Pattern3 = function {tan (3*x) * sin (5*x/2) * sin (z) - 0.1}
Download 'mathpatterns2.png' (602 KB)
Preview of image 'mathpatterns2.png'
An interesting approach that I'll have to look into further.
https://gcboore.com/pages/trigonometric-functions.html
Might be able to do the same thing with pigment patterns and homebrew function
patterns.
> patterns.
Really interesting, looking forward to the results of your experiments !
YB
> > #declare T = 0.5;
> > #declare N = 1;
> > - pow(T, N)}
a loop-able animation of the pattern. warning -- weird ;-).
<https://drive.google.com/file/d/1Aet9noapf8SBgX2u62TTYMFYx5NfbckT/view?usp=sharing>
enjoy, jr.
Finally had a moment of clarity, and figured out a fish-scale pattern that I
wanted to make.
Download 'mathpatterns1.png' (64 KB)
Preview of image 'mathpatterns1.png'
> wanted to make.
And here's a modification to make it less semi-circular.
Download 'mathpatterns1.png' (45 KB)
I was trying to track down something completely unrelated, and came across this
page:
National Curve Bank
A Collection of Famous Plane Curves
created in POVRAY (Persistence Of Vision RAY tracing)
https://old.nationalcurvebank.org/povray/povray.htm
