POV-Ray : Newsgroups : povray.advanced-users : Making Patterns with functions Server Time
31 Mar 2026 14:06:43 EDT (-0400)
  Making Patterns with functions (Message 39 to 48 of 56)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Making Patterns with functions
Date: 23 Aug 2024 21:20:00
Message: <web.66c93534d81b84791f9dae3025979125@news.povray.org>
> Also of interest would be a metal diamond-plate pattern - the "honeycomb"
> pattern that I posted for jr has that alternating direction / row attribute that
> might be a good starting point for modification.
#declare YY = 0.625;
#declare Plate1 = function {select (1-pow(sin(2*pi*x)*cos(2*pi*YY) +
sin(2*pi*YY)*cos(2*pi*z) + sin(2*pi*z)*cos(2*pi*x), 2), 0, 0, 1)}
Download 'mathpatterns2.png' (237 KB)
Preview of image 'mathpatterns2.png'
Date: 25 Aug 2024 02:50:00
Message: <web.66cad352d81b8479f5bfc9b06cde94f1@news.povray.org>
hi,
> > Kinda looks like a "dog bone" wood patch that alternates in directions like a
> > checkerboard.
> Sometimes these things are a little easier to write using some helper functions.
> #declare S2P = function (V) {sin (tau*V/L)}
> #declare C2P = function (V) {cos (tau*V/L)}
> #declare T = 0.5;
> #declare N = 1;
> #declare Honeycomb = function (X, Y, Z) {pow(S2P(X)*C2P(Z) + S2P(Z) + C2P(X), N)
> - pow(T, N)}
plane with "Honeycomb" pattern, seen through "kaleidoscope".
regards, jr.
Download 'ktpms.png' (440 KB)
Preview of image 'ktpms.png'
Date: 25 Aug 2024 11:45:00
Message: <web.66cb5166d81b84791f9dae3025979125@news.povray.org>
Wheee!   Nice job.  :)
Can you adjust the symmetry?  Have 6-fold, or 7?
After playing with this stuff a bit, it seems like that whole sin*cos xy yz zx
thing has a lot of potential as a base pattern to do all sorts of interesting
things with.  Even just the threshold can change the apparent look quite a bit.
And then you have the orthogonal plane value/slice to vary.
We can square the whole sum, square the terms, take the root, etc.
- BW
Date: 25 Aug 2024 12:20:00
Message: <web.66cb586ad81b8479f5bfc9b06cde94f1@news.povray.org>
hi,
> Wheee!   Nice job.  :)
start on.  :-)
yes, I just discovered that replacing "tau" with "pi * scale_factor" and using
slightly different factors, things get real .. interesting.
re your question, I answer with an Obama quote: "Yes, we can" :-)  below is
excerpted from my WIP code:
/* added bailout & max_trace */
global_settings {adc_bailout (1/254) assumed_gamma 1 max_trace_level 255}
/* #mirrors */
#declare n_ = 3;
#declare angle_ = 360 / n_;
/* epsilon */
#declare eps_ = 1e-3;
/* length of tube */
#declare len_ = 10;
/* prism with hole */
#declare pi_ = <.99,0,0>;
#declare po_ = <1.01,0,0>;
#declare pts_ = array [n_][2];
#for (i_, 0, n_-1)
  #local ta_ = vrotate(po_, <0,(angle_*i_),0>);
  #local tb_ = vrotate(pi_, <0,(angle_*i_),0>);
  #local pts_[i_][0] = <ta_.x,ta_.z>;
  #local pts_[i_][1] = <tb_.x,tb_.z>;
/* rotate to centre on -z */
prism {
  linear_spline eps_, len_, 2*(1+n_),
  #for (i_,n_-1,0,-1) pts_[i_][0], #end pts_[n_-1][0],
  #for (i_,0,n_-1) pts_[i_][1], #end pts_[0][1]
  open
  sturm on
  no_shadow
  finish {ambient 0 reflection {1} specular 0}
  rotate <270,0,0>
regards, jr.
Date: 27 Aug 2024 20:55:00
Message: <web.66ce7468d81b84791f9dae3025979125@news.povray.org>
This one looks like sliced pita bread or hot dogs buns or something.
#declare Pattern3 = function {tan (3*x) * sin (5*x/2) * sin (z) - 0.1}
Download 'mathpatterns2.png' (602 KB)
Date: 28 Aug 2024 15:10:00
Message: <web.66cf754ad81b8479a5a6be6925979125@news.povray.org>
An interesting approach that I'll have to look into further.
https://gcboore.com/pages/trigonometric-functions.html
Might be able to do the same thing with pigment patterns and homebrew function
patterns.
Date: 29 Aug 2024 05:35:15
Message: <66d040d3$1@news.povray.org>
> patterns.
Really interesting, looking forward to the results of your experiments !
YB
Date: 16 Sep 2024 08:35:00
Message: <web.66e824d9d81b8479f5bfc9b06cde94f1@news.povray.org>
> > #declare T = 0.5;
> > #declare N = 1;
> > - pow(T, N)}
a loop-able animation of the pattern.  warning -- weird ;-).
<https://drive.google.com/file/d/1Aet9noapf8SBgX2u62TTYMFYx5NfbckT/view?usp=sharing>
enjoy, jr.
Date: 4 Dec 2024 17:30:00
Message: <web.6750d737d81b84791f9dae3025979125@news.povray.org>
Finally had a moment of clarity, and figured out a fish-scale pattern that I
wanted to make.
Download 'mathpatterns1.png' (64 KB)
Preview of image 'mathpatterns1.png'
Date: 4 Dec 2024 17:35:00
Message: <web.6750d8fdd81b84791f9dae3025979125@news.povray.org>
> wanted to make.
And here's a modification to make it less semi-circular.
Download 'mathpatterns1.png' (45 KB)
