POV-Ray : Newsgroups : povray.advanced-users : Why don't shadows get blurry after a certain distance? ("Distance Field Sha= Server Time
15 Dec 2025 16:07:29 EST (-0500)
  Why don't shadows get blurry after a certain distance? ("Distance Field Sha= (Message 11 to 12 of 12)
Subject: Re: Why don't shadows get blurry after a certain distance? ("Distance Field=
Date: 6 Jun 2022 10:50:11
Message: <629e1423$1@news.povray.org>
Le 2022-06-06 à 03:46, And a écrit :
> "HackerDaGreat57" <Hac### [at] gmailcom> wrote:
>>>> Is it possible to change the 'Radius' of the point light? Like in Blender's
>>>> Cycles for example, there is an option to change the point light's radius which
>>>> increases the 'amount' of penumbra on my shadows.
>>>> Thanks anyway for the useful reference though.
>>> Not in the way you're asking.
>>> But maybe another way.
>>> If you create a sphere with an emissive finish, then you could make a scene
>>> using radiosity, and that might work in the way you want it to.
>>> You can also add no_image to the object definition so that it doesn't show up in
>>> the scene, if it's in the camera's view frustum.
>> That would, in fact, work like a charm.
>> Do emissive materials count as light sources? (I'm concerned about the 127 light
>> limit)
> You can use an object with texture{ finish{emission 1.0}} instead of regular
> light_source, when the radiosity turn on.
> But, you need very high radiosity quality settings, especially "error_bound", or
> you will get a very blurred shadow without accuracy created by radiosity.
> The accuracy will establish when error_bound is very small. But at this time you
> need high "count" to eliminate spotted result.
> radiosity{
>   pretrace_start 64/image_width
>   pretrace_end   4/image_width
>   count 160
>   nearest_count 2
>   error_bound 0.28      // this should be smaller
>                         // if you use radiosity emission
>                         // as a light source
>   recursion_limit 4
>   low_error_factor 0.5
>   gray_threshold 0.0
>   brightness 1.0         // brightness 1 is natural correct
>   media off
> radiosity {} block place in the global_settings{}
In a case like that, it's very interesting to use the importance feature
of the latest versions.
It's used as follow :
You start by assigning a default importance weight to everything with a
#default statement :
#declare HighSamples = 50000;
#declare AverageSamples = 75;
#default{rediosity{ importance AverageSamples /HighSamples }}
Then, for the objects to be used as light sources, you add :
radiosity{ importance 1 }
usually just before the closing brace or just before the texture definition.
In cases like this, I tend to also use the adaptive nearest_count :
nearest_count 20 3
#default{radiosity{ importance AverageSamples/HighSamples }}
global_settings{ assumed_gamma 1
radiosity{
  minimum_reuse 4/image_width-0.05
  count HighSamples
  nearest_count 20 2
  error_bound 0.2      // this should be smaller
  recursion_limit 4
  low_error_factor 0.35
  media off
<other optional global_settings stuff>}
That cause the average number of samples used to be about 75 for most f
the scene, but to be up to 50000 when sampling the area near the high
emission objects.
Subject: Re: Why don't shadows get blurry after a certain distance? ("DistanceField=
Date: 7 Jun 2022 07:44:31
Message: <629f3a1f$1@news.povray.org>
Op 6-6-2022 om 16:50 schreef Alain Martel:
> definition.
> nearest_count 20 3
> radiosity{
>   count HighSamples
>   nearest_count 20 2
>   recursion_limit 4
>   media off
> emission objects.
This is very good advise! Note that you may have to crank-up your
emission value way beyond 1. For a rapid test, I used emission 1000
together with diffuse 1, for instance.
