POV-Ray : Newsgroups : povray.advanced-users : using multiple versions of POV-ray-- library_paths question Server Time
30 Apr 2026 04:57:21 EDT (-0400)
  using multiple versions of POV-ray-- library_paths question (Message 1 to 10 of 11)
Subject: using multiple versions of POV-ray-- library_paths question
Date: 13 Sep 2020 14:30:01
Message: <web.5f5e626e70a2f4a4d98418910@news.povray.org>
In Windows 7, I currently run two different 'stand-alone' versions of POV-Ray
(although not at the same time): v3.7.0, and v3.7.1 beta 9. I like to switch
between these versions at will-- to experiment, to compare renders, etc.  (I
also run various 3.8 alpha versions, but they run from 'within' v3.7.0. )
I originally installed the two main versions the 'standard' way-- which placed
two main folders in 'Documents', one named '3.7' and one named '3.7-beta' (plus
their two associated and separate folders in C:\Program Files\POV-ray\ , of
course.)
EACH of these stand-alone versions has its own exclusive(?) set of the four
necessary sub-folders in its repective 'Documents' folder, each with its own set
of files--
include
ini
Insert Menu
scenes
But if I want to edit one of those files in, say, v3.7.0, I then have to
duplicate the changes in the 3.7-beta folder to retain consistency across
versions...which seems redundant. For editing purposes and ease of use, it would
be nice to have ONE 'master' set of at least the following files:
povray.inc
quickres.ini
include
Insert Menu
Is there any way to place a SINGLE set of these files somewhere, that can be
used by *multiple* versions of POV-ray? I've tried various ways of doing it,
with no success.
For example, I moved only the 'Insert Menu' folder out of '3.7' and into an
outer folder within 'Documents\POV-Ray' called 'common_files_experiment'. I
then edited 3.7.0's 'povray.ini' file with a new library path...
Library_Path=C:\Users\Computer\Documents\POV-Ray\common_files_experiment\
I thought this would be the appropriate way to do the trick-- but launching
v3.7.0 results in no 'Insert Menu' contents showing up. I tried re-writing the
path in different ways, but still no luck...
Library_Path=C:\Users\Computer\Documents\POV-Ray\common_files_experiment\"Insert
Menu"\
and...
Library_Path="C:\Users\Computer\Documents\POV-Ray\common_files_experiment\Insert
menu\"
It seems obvious that I'm going about this the wrong way. I suspect that POV-ray
tries to load these special(?) kinds of files/folders *before* looking in
povray.ini for any further library paths-- and consequently does not find what
it is looking for. (BTW, the standard Windows installation procedure produces
povray.ini files that do not have any library paths listed *at all*, except what
I choose to add later; the default 'automatic' paths are probably written
*somewhere*, but I haven't been able to find them. I also looked in the Windows
registry, in the various 'POV-ray' folders there. )
Subject: Re: using multiple versions of POV-ray-- library_paths question
Date: 13 Sep 2020 15:00:00
Message: <web.5f5e6b456c1a673f1f9dae300@news.povray.org>
> it is looking for.
I don't mess with these (much), but I will speculate, and see if I'm correct.
The locations of those "special" folders are hard-coded somewhere, or in some
..ini file that you haven't found yet.
The library paths have nothing to do with those.
What I think you want to do is create a central folder, and then in the place
where those folders are normally found, add a symbolic link that points to the
central folder.
In windows that might be a "shortcut" or something similar.
Date: 13 Sep 2020 16:10:00
Message: <web.5f5e7a766c1a673fd98418910@news.povray.org>
hey!
Thanks for the insights and for thinking about this.
I've looked in all(?) the various .ini files and other 'human-readable' files,
in both 'Documents' and in C:\Program Files\POV-Ray... but no luck. Perhaps the
'hidden' library paths are coded somewhere in the DLLs? Not that I know
*anything* about DLLs!
> central folder.
I actually did try that (in one form), for another of my 'Insert Menu' tests:
After moving that folder outside of its standard location, I tried placing a
Windows shortcut to it inside the original 'v3.7' folder-- but again, no luck.
No Insert Menu contents appear in POV-ray's menu.  :-(
I've tried to think of a way to combine BOTH the 'v3.7 and 'v3.7-beta' main
folders (in 'Documents') into a single folder, then simply eliminate the
redundant sets of files/folders... but I think it would royally screw things up,
if only because C:\Program Files... has them as separate entities, with some
'exclusive' files there for the various versions. It could end up being being a
bad experiment, with possibly unforseen problems.
Date: 13 Sep 2020 16:20:03
Message: <web.5f5e7e9b6c1a673fd98418910@news.povray.org>
BTW, I do have my own separate 'scenes' folder, plus some others; their
locations (library_paths) were easily written into each of my TWO povray.ini
files. But again, having TWO of those seperate files seems redundant.
Date: 13 Sep 2020 16:25:06
Message: <web.5f5e7f5a6c1a673f4d00143e0@news.povray.org>
hi,
> in both 'Documents' and in C:\Program Files\POV-Ray... but no luck. ...
never used a POV-Ray Windows version, but wonder whether there's information
kept in the (in)famous Windows Registry?
regards, jr.
Date: 13 Sep 2020 16:45:01
Message: <web.5f5e83a56c1a673fd98418910@news.povray.org>
Alas, I've tried looking there-- but all I see are dynamically-changing entries
for library paths... like 'last scene rendered', etc etc. I don't see any
entries (so far) that look like they are 'set' to an unchanging library path
(i.e., something that *I* could then change and that would retain the changes.)
But I'm *certainly* no genius when it comes to understanding the Windows
registry!
Date: 13 Sep 2020 19:58:15
Message: <5f5eb217$1@news.povray.org>
> registry!
Try this location in the registry :
\HKEY_CURRENT_USER\SOFTWARE\POV-Ray\v3.7\Windows
There should be a \HKEY_CURRENT_USER\SOFTWARE\POV-Ray\v3.7-beta\Windows
entry, or something similar, if version 3.7 beta is installed.
And a \HKEY_CURRENT_USER\SOFTWARE\POV-Ray\v3.6\Windows
if version 3.6 is also installed.
The key entry could be the «Home» value.
Try setting the «Home» value with the same path for both installs.
To be safe, start by renaming the «home» value to something like
«Home-back» before you change anything else. Then, right click and
select «New string value» from the contextual menu and type «Home». That
way, if it don't work, you just delete the edited key and rename the
backed up one to it's original name.
The worst that can happen here is that the version with the altered
entry won't start properly and throw some errors.
NOT all edition of the registry are benign. DO NOT EVER edit anything
that you are not sure about.
Never edit anything within \HKEY_CLASSES_ROOT unless you have clear
instructions. (may screw your associations or make some application
unstable)
Same for \HKEY_LOCAL_MACHINE\HARDWARE (may disable some component of the
computer, even prevent it from booting) and \HKEY_USERS (may corrupt a
user's account).
Keys with names similar to «{0ce4991b-e6b3-4b16-b23c-5e0d9250e5d9}» can
render some functionalities or feature unusable if altered. DO NOT touch !
Date: 14 Sep 2020 11:05:16
Message: <5f5f86ac$1@news.povray.org>
A regular shortcut will not work in this case. You must create a
directory junction or soft link via the mklink command with the "/j" option.
Date: 15 Sep 2020 03:40:00
Message: <web.5f606cfc6c1a673fd98418910@news.povray.org>
> [snip]
Thanks, Anthony and Alain. I get what you're both suggesting. It looks like
creating 'symbolic links' will be the solution to my idea. The concept is
completely new to me, as are the the Windows 'tools' of  mklink  and the "j\"
option etc.-- but I've already started researching at least the basics of it
all. From what I've read so far, creating a 'hard link' seems to be more
appropriate for my idea than a 'soft link'-- but I'm not yet smart enough to
decide!
For others who are interested, this page looks like a good place to begin...
https://www.howtogeek.com/howto/16226/complete-guide-to-symbolic-links-symlinks-on-windows-or-linux/
(BTW, being a newbie at this, I even had to look up the meaning of 'directory',
to find out how it might differ from the typical 'folder' concept. They're
*essentially* the same-- with some caveats-- but used in different contexts.)
I hope to get this idea to work; if I succeed, I'll post my method here later.
Date: 15 Sep 2020 14:10:00
Message: <web.5f6102476c1a673fd98418910@news.povray.org>
Sorry, for some unknown reason that link doesn't *reliably* connect to its page,
from here in the newsgroups' web portal-- even though the URL is correct. Try
cutting-and-pasting the link into your browser; that worked for me.
