POV-Ray : Newsgroups : povray.advanced-users : XPM or PPM with Alpha input support Server Time
14 Mar 2026 08:51:29 EDT (-0400)
  XPM or PPM with Alpha input support (Message 1 to 4 of 4)
Subject: XPM or PPM with Alpha input support
Date: 31 Dec 2019 19:40:01
Message: <web.5e0bea2d8f695c92ae8074410@news.povray.org>
Hi, I'm searching for an input image format that would be Ascii based, not
binary, but still support alpha transparency.
I saw PPM as a perfect example if it could bear transparency info, so this is
basically a feature request for POV to support XPM in same places (input images
as images_map or normal) or maybe the info of a workaround, like any format
already supported that would have a, maybe less known, ascii version?
Subject: Re: XPM or PPM with Alpha input support
Date: 5 Jan 2020 07:05:00
Message: <web.5e11d014a8e69d1ab12f626e0@news.povray.org>
(This issue is the blocking point to the creation of a free assets libary)
Date: 5 Jan 2020 07:35:08
Message: <5e11d7fc$1@news.povray.org>
A collection of tools is better than a tool that try to make everything.
Just uses XPM as you want, then use imagemagick's convert to transform
in png, and voilà.
Date: 5 Jan 2020 09:50:01
Message: <web.5e11f71a5d4ebeb1b12f626e0@news.povray.org>
> in png, and voilà.
Hi, though not directly a solution for me, as I cant ship image magick in the
bundle which has to be only text, if python core modules can do the conversion
it would work ! thanks!
