POV-Ray : Newsgroups : povray.advanced-users : Radiosity rendering depends on camera direction? Server Time
15 May 2024 14:27:39 EDT (-0400)
  Radiosity rendering depends on camera direction? (Message 11 to 11 of 11)
Subject: Re: Radiosity rendering depends on camera direction?
Date: 10 Apr 2019 16:57:32
Message: <5cae58bc$1@news.povray.org>
Le 19-04-10 à 14:34, Tamas Gunda a écrit :
> clipka <ano### [at] anonymousorg> wrote:
>> Am 08.04.2019 um 19:06 schrieb Alain:
>>> Just an idea :
>>> Try rendering it all in one go, then, project onto a box or sphere :
>> That's actually a pretty smart idea.
>> It's important though to use a high enough resolution, or at least use
>> interpolation for the projected image.
>> Alternatively, the image could be rendered directly to a single cube map
>> image using a v3.8.0-alpha user-defined camera (or a v3.7.0 mesh camera,
>> but that's more of a hassle to set up). If 6 separate images are needed,
>> that could then simply be achieved by cutting the output image into
>> pieces in any image processing software.
> Bingo!
> Thanks, Alain. Rendering with 360 deg spherical camera in one go and then
> projecting onto a sphere and cut to cubic images has yielded a seamless
> spherical image. The resolution of the first rendering should be at least twice
> to that of final image.
> http://www.gunda.hu/cube/povray/index3.html
> Tamas
If the individual images are, say, 1000 pixels whide, the spherical
render need to be 4000 pixels whide and 2000 pixels high.
Looking at the darker parts, I think that you may need to increase
recursion_limit by 1 or 2.
Also, it could be good to increase the count value as well as the pool
size (the second parameter of count).
