POV-Ray : Newsgroups : povray.advanced-users : Parallel (offset) curve - odd behaviour Server Time
8 Dec 2025 06:37:05 EST (-0500)
  Parallel (offset) curve - odd behaviour (Message 1 to 4 of 4)
Subject: Parallel (offset) curve - odd behaviour
Date: 26 May 2017 07:55:00
Message: <web.592816879146df1fc437ac910@news.povray.org>
I needed to work on the sine wave, and after two abysmal attempts at thickening
the curve, I was able to get something that was well-behaved, looked good, and
was fast.
I'm sure I could have gone all Xah Lee on this and differentiated the curve, but
I stuck with "practical" and just used trace() to get the normal vector.
The only issue is that the entire curve for x < 0 is different, and there's a
pronounced "ledge" at x=0.  I'm not sure why.
Perhaps someone with more experience with trace and vectors will spot the
difficulty faster than I can.
(This is currently for a laser-cutter, not a router, so I need to stack thin
lines (0.24 mm) rather than just plug in a wider bit - thus the method used
here.)
Commented-out code at bottom is 2 aborted attempts.
#version 3.7;
global_settings {
 assumed_gamma 1.0
#declare Feet = 12;
#declare PHI = (1+sqrt(5))/2;
#declare phi = (sqrt(5)-1)/2;
#declare Camera_Orthographic = true;
#declare Camera_Position = <0, 0, -300> ;  // front view
#declare Camera_Look_At  = <0, 0,  0> ;
#declare Fraction = 1;     // functions as a zoom for the orthographic view: 4
zooms in 4x, 8 zooms in 8x, etc.
 #if (Camera_Orthographic = true)
  orthographic
  right     x*image_width/(Fraction)
  up   y*image_height/(Fraction)
 #else
  up y
 location  Camera_Position
 look_at   Camera_Look_At}
background {White}
light_source {<0, 10, -500> color White*0.5}
#declare Origin = sphere {0, 1 pigment {Black}}
//object {Origin}
#declare HW = image_width/2;
#declare HH = image_height/2;
#declare F = 4;
#declare Freq = F*tau/image_width;
#declare YScale = 100;
#declare R=0.5;
// Central curve
#declare Curve =
union {
#for (T, -HW, HW)
 #local XX = T;
 #local YY = YScale*sin (XX*Freq);
 sphere {<XX, YY, -1> R pigment {Black}}
 #if (T > 0)
  cylinder {LastPoint, <XX, YY, -1> R pigment {Black}}
 #local LastPoint = <XX, YY, -1>;
object {Curve}
#declare L = 20;
 #declare Current = array [L];
 #declare Last = array [L];
 #declare C = 0;
 #for (T, -HW, HW, 2)
  #local XX = T;
  #local YY = (YScale*sin (XX*Freq))+(L*2*R);
  #declare Norm = <0, 0, 0>;
  #declare Start = <XX, YY, -1>;
  #declare Inter = trace (Curve, Start, <0, -abs(YY), 0>, Norm);
  #if (vlength (Norm) != 0)
   #for (Layer, 0, L-1)
    #declare Current[Layer] = Inter + (Norm*R*Layer);
    sphere {Current[Layer] R pigment {Red}}
    #if (C > 0)
     cylinder {Last[Layer], Current[Layer] R pigment {Red}}
    #end // end if
   #end // end for Layer
  #end // end if vlength
  #declare C = C+1;
   #local Last[Layer] = Current[Layer];
#declare L = 10;
#for (N, 1, L)
 #declare Parallel = union {
 #declare C = 0;
  #local XX = T;
   #declare Current = Inter + Norm;
    sphere {Current R pigment {Red}}
   #if (C > 0)
    cylinder {LastPoint, Current R pigment {Red}}
  #declare C = C+1;
  #local LastPoint = Current;
#declare Curve = union {object {Curve} object {Parallel}}
object {Curve}
#for (N, 1, 5)
 #declare Flag = -1;
 #for (T, -HW, HW)
  #local XX = T;
  #local Skip = 0;
  #if (Flag = -1)
   #local Freq = F*tau/(image_width+(N*4*R));
   #local YY = (YScale+N*R)*sin (XX*Freq);
   #local Pigment = pigment {Red};
   #if (YY > 0)
    #declare Flag = -Flag;
    //#declare T = T -1;
    #declare Skip = 1;
  #else
   #local Freq = F*tau/(image_width-(N*4*R));
   #local YY = (YScale-N*R)*sin (XX*Freq);
   #local Pigment = pigment {Blue};
   #if (YY < 0)
    #declare Skip = 1;
  #if (Skip != 1)
   sphere {<XX, YY, -1> R pigment {Pigment}}
   #if (T > 0)
    cylinder {LastPoint, <XX, YY, -1> R pigment {Pigment}}
Subject: Re: Parallel (offset) curve - odd behaviour
Date: 26 May 2017 08:15:15
Message: <59281c53$1@news.povray.org>
> #version 3.7;
> global_settings {
>  assumed_gamma 1.0
> #declare Feet = 12;
> camera {
>   orthographic
>  #else
>   up y
>  #end
> background {White}
> //object {Origin}
> #declare F = 4;
> #declare R=0.5;
> // Central curve
> #declare Curve =
> union {
> #for (T, -HW, HW)
>  #local XX = T;
>  #if (T > 0)
That line should be
#if (T>-HW)
Otherwise "Curve" is not what I think you meant it to be...
Date: 26 May 2017 10:05:00
Message: <web.592835dbd186edbec437ac910@news.povray.org>
scott <sco### [at] scottcom> wrote:
> That line should be
> #if (T>-HW)
Super!
I just needed to add my C counter in there like I did for the offset curve and
check C instead of T.   That did the trick.  :)
Tired brain and tired eyes.
Glad it was just a coding omission rather than something in the math.
Thanks for catching that.
Date: 19 Jul 2018 21:40:01
Message: <web.5b513d1cd186edbe34baa4ef0@news.povray.org>
> > That line should be
> > #if (T>-HW)
> Super!
Could you post the fixed code please?
Mike
