POV-Ray : Newsgroups : povray.advanced-users : Shape Request Server Time
7 Mar 2026 05:44:21 EST (-0500)
  Shape Request (Message 1 to 5 of 5)
Subject: Shape Request
Date: 15 May 2017 12:35:00
Message: <web.5919d79a74bd046bc437ac910@news.povray.org>
I have looked into doing some 4D projections into 3D space, but alas, the math
for the moment evades me.
With regard to constant-perceived-width objects, specifically in the present
case of planetary and satellite orbits, the projection of a torus would be a
useful little object to be able to have on-hand.
http://mathforum.org/mathimages/index.php/Projection_of_a_Torus
I'm envisioning 3 parameters for this:  major radius, and 2 minor radii - the
max and the min.
Thanks to anyone taking an interest!  :)
Subject: Re: Shape Request
Date: 15 May 2017 14:13:36
Message: <5919efd0$1@news.povray.org>
> max and the min.
A quick search for 4D torus found me that page:
http://www.dr-mikes-maths.com/4d-torus.html
which seems to make more sense than your link, at least on your link I
did not get the notion of 4D.
Now, if all you need is a classical 3D-donut shape with a hole not at
the center and yet a regular circle as bounding on the equator plane, it
might just be a matter of playing with fourth order polynomial.
So, can you clarify what you want ?
Date: 15 May 2017 14:35:54
Message: <5919f50a$1@news.povray.org>
Am 15.05.2017 um 18:30 schrieb Bald Eagle:
> max and the min.
I suspect that such a torus might not have the necessary numeric
stability to form artifact-free thin lines.
Personally, I'd try a sphere sweep based approximation instead --
provided the newest experimental version turns out to work as I'm hoping.
Date: 15 May 2017 15:20:01
Message: <web.5919feb59d92b94c437ac910@news.povray.org>
To clarify,
I'd just like to have a variable-minimum-radius torus.
Small at "apogee", and wide at "perigee".
Here, the Dupin Cylide - it's exactly what I was thinking of.
https://en.wikipedia.org/wiki/Dupin_cyclide
No idea, but good observation.
I know it's possible to do in POV-Ray (the Dupin Cyclide), because it was done
here:
http://www.dimensions-math.org/Dim_CH7_E.htm
http://www.geometrie.tuwien.ac.at/vis/vis036.html
http://www.geometrie.tuwien.ac.at/vis/vis037.html
That was my immediate idea, but IIRC from my investigations into Bezier splines,
you can't make a circle with a single spline, so it would have to be at least 2
pieces.
Date: 15 May 2017 16:35:01
Message: <591a10f5@news.povray.org>
Le 15/05/2017 à 21:17, Bald Eagle a écrit :
> To clarify,
So, you even found a page with all that is needed:
* for a parametric
* for a polynomial (quartic)
Per your specifications, it's an elliptic cyclide and we have c < d
(ring cyclide).
Remains to be done: mapping your input (3 radii) into a,b,c & d.
