POV-Ray : Newsgroups : povray.advanced-users : Question about Material and documentation Server Time
13 May 2025 18:58:47 EDT (-0400)
  Question about Material and documentation (Message 1 to 5 of 5)
Subject: Question about Material and documentation
Date: 15 May 2017 08:35:01
Message: <web.5919a04cb18151ffc437ac910@news.povray.org>
The POV-Ray documentation states:
"Internally, the "material" is not attached to the object. The material is just
a container that brings the texture and interior to the object. It is the
texture and interior itself that is attached to the object. Users should still
consider texture and interior as separate items attached to the object.
The material is just a "bucket" to carry them.
If the object already has a texture, then the material texture is layered over
it."
I was looking for some way to take a full scene and replace all the texturing in
it with a black & white gradient, and thought this might be the way.
I did a simple experiment with a simple scene, and no textures were "layered
over".
Am I misreading / misinterpreting this, or just doing something wrong?
Thanks.
Subject: Re: Question about Material and documentation
Date: 15 May 2017 10:05:00
Message: <web.5919b4b8ce4acd17883fb31c0@news.povray.org>
> "If the object already has a texture, then the material texture is layered over
> it."
It's always been my understanding that, once an object already has a texture,
that texture can't be replaced or overlayed later with an additional one. I
think the docs are in error.
My own simple code experiment...
#declare MY_MATERIAL =
    material{texture{pigment{rgb 1} finish{emission .2 diffuse .4 phong 1}}}
union{ // to group *all* of the scene objects together
sphere{0,1
    texture{
        pigment{rgb <1,.5,.5>}
        finish{emission .2 diffuse .8}
       translate 1.5*x
sphere{0,1
    texture{
        pigment{rgb <.5,1,.5>}
       translate -1.5*x
       material{MY_MATERIAL} // to try and replace or overlay the
                             // previous textures.
       } // end of union
This doesn't work. (However, commenting-out one of the object's textures shows
that the added 'material' does replace it.)
In past newsgroup posts, I've read that the only way to do this kind of thing is
to pre-write the scene with the added texture or material already in mind--
i.e., to pre-plan for it. One example might be to create a #default texture (in
your case, a pigment with a black-to-white color map), then add #if blocks to
*all* the scene's textures. Then just switch between textures. Not very elegant,
I admit! (BTW, adding this type of feature to POV-Ray has been discussed in the
newsgroups, from time to time, if memory serves me correctly-- and possibly
other workarounds as well.)
Strangely, I have a dim memory of making your original material question
actually work, to a degree (this was years ago)-- although it was some kind of
special arrangement of objects or unions or *something.* Sadly, I can't recall
which old scene I did that in, or how.
Date: 15 May 2017 11:45:00
Message: <web.5919c992ce4acd17883fb31c0@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> > over it."
Sorry, I'm completely mistaken. The 'material' container DOES work, and indeed
overlays the previous texture, like *this* example... (but it has to be added to
each object individually)...
--Change my #declared 'material' texture to this instead (so that its blue
translucent color can be seen to overlay the objects' own texture colors)--
material{
texture{
pigment{rgbt <.1,.1,1,.5>} // change t to see different effects
finish{emission .2 diffuse .8 phong 1}
// NO union-- an added 'material' container doesn't work at the end of a union,
// it seems...
sphere{0,1
    texture{
        translate 1.5*x
sphere{0,1
    texture{
        translate -1.5*x
(BTW, this also works if the 'material' container itself is not used, and just
its texture is #declared. OR, the 2nd texture can be added to the objects
directly, with no previous #declare.) Of course, a 'material' container is made
for combining lots of stuff, like interior etc.
This overlayed-texture effect seems to be different(?) behavior from what I
remember in v3.62 or v3.61; adding a '2nd texture' to an object *completely*
replaced the first texture, IIRC. Not so now, at least using v3.7.1 beta 7.
Unless my eyes are deceiving me!
Date: 16 May 2017 13:22:49
Message: <591b3569$1@news.povray.org>
>>> over it."
This ONLY work on textures applied at the same level.
> material{
> texture{
> // it seems...
> sphere{0,1
>      texture{
>          translate 1.5*x
> sphere{0,1
>      texture{
>          translate -1.5*x
Whenever you apply a pigment, finish, complete texture or material to a
CSG entity, any object that already have any of those are never
affected. ONLY those that don't already have any texture or pigment can
receive the CSG level texture.
If you add a second texture over a previous one, as in a layered
texture, if the second texture don't have any transparency, it will
totally cover and visually replace the underlying one. The underlying
texture is still there, it's just hidden under the top one. Think of it
as a coat of paint over the previous one.
If you add a texture to a CSG, it can overlay previous textures of that
CSG, but never those of it's components.
As an object can have only one ior, only the last one should be used. If
you have an union and some of it's component have an ior, the union
level ior will never affect those. No change with the last versions.
There have been no behaviour change for layered textures since, at
least, version 3.1G. (time when I discovered POV-Ray)
Date: 16 May 2017 17:10:00
Message: <web.591b694bce4acd17883fb31c0@news.povray.org>
Yes, you're correct. Ignore my statement above; I must have been thinking of
multiple PIGMENTS in a single texture. The final pigment does completely
override any previous pigments.
