POV-Ray : Newsgroups : povray.advanced-users : Trouble implementing Axis_Rotate_Trans macro Server Time
8 Dec 2025 08:36:44 EST (-0500)
  Trouble implementing Axis_Rotate_Trans macro (Message 1 to 5 of 5)
Subject: Trouble implementing Axis_Rotate_Trans macro
Date: 31 May 2015 18:20:01
Message: <web.556b88e892bf08245e7df57c0@news.povray.org>
Hi all,
Sorry about dropping off the face of the Earth, and all, but there's all that
real life stuff that happens, and now I'm done whining.  About real life.  ;)
Now let me whine about my inability to get Axis_Rotate_Trans to work.  :D
Background info / goal:
I'm just trying to put a point on a twist drill, but there needs to be "relief"
trailing the cutting edge.  So I difference out a box, but then as I rotate that
box around the axis of the bit, it needs to "roll" back out of the way - and
that would be around an axis described by a vector "from" the origin "to" a
point rotated around the x-axis to the same degree as the cutting edge.
And that's where my brain, and my code craps out.
#declare Cutter2 = box {<-Drill_Size, 0, 0>, <Drill_Size, Radius*2, -1> rotate
-x*Point}
#declare Relief_Axis = vrotate (<0, Radius*2, 0>, <-Point, 0, 0>);
# declare Cone =
union {
#declare theta = 0;
#while (theta < 90)
    object {Cutter2 rotate -y*theta Axis_Rotate_Trans (Relief_Axis,
(12/90)*theta)}
    #declare theta = theta +1;
That spits out the following error and pops up the "transforms.inc" file in a
new tab.
"C:\Documents and Settings\Drew\My
Documents\POV-Ray\v3.7\include\transforms.inc" line 60: Parse Error: Expected
'object or
directive', transform found instead
Render failed
As always, any help clearing this up would be most appreciated!
Subject: Re: Trouble implementing Axis_Rotate_Trans macro
Date: 1 Jun 2015 04:17:54
Message: <556c1532$1@news.povray.org>
> -x*Point}
> # declare Cone =
> union {
> #declare theta = 0;
> #while (theta < 90)
> (12/90)*theta)}
> #end
> new tab.
If I add the following lines at the start then I get no error:
#local Drill_Size = 1;
#local Radius = 1;
#local Point = 1;
#include "transforms.inc"
Do you get the same result?
Date: 1 Jun 2015 22:15:08
Message: <web.556d113ee40c576d5e7df57c0@news.povray.org>
> #local Radius = 1;
> #local Point = 1;
I already checked that I had included transforms.inc - which was also
demonstrated by my SDL crapping out IN the included code.
My setup seemed to be choking on "trasform", and I couldn't dig up any
documentation on that command, so I just cut and pasted the matrix transform
into my SDL, made a few mods, and it works.
So, no idea what the underlying problem is.   :(
Doubly annoying since that wasn't the damned axis I wanted to rotate around
anyway.  (eyeroll)
But the drill bit came out nicely.  :D
Date: 2 Jun 2015 02:59:57
Message: <556d546d$1@news.povray.org>
Well, if you wrote "trasform" like in the text above, I am not surprised ;-)
Maybe use wrote "Transform"? Using capitals is a mistake I often make
and have a hard time to hunt down. You just overlook them.
Date: 2 Jun 2015 03:29:26
Message: <556d5b56@news.povray.org>
>> #local Radius = 1;
>> #local Point = 1;
My point was, if I copy & paste your text exactly as you posted into
POV, add those lines at the beginning then it parses fine. So your
mistake is elsewhere in some code that you haven't posted.
It's far better to post a complete block of code that you think should
run by itself, this allows others to copy&paste into POV rather than
trying to guess what the rest of your code is doing (I had to guess
values for the missing parameters, no idea if changing these would cause
the code not to parse).
