POV-Ray : Newsgroups : povray.advanced-users : Installation problem in povray subdivision on server. Server Time
7 Mar 2026 11:04:37 EST (-0500)
  Installation problem in povray subdivision on server. (Message 1 to 5 of 5)
Subject: Installation problem in povray subdivision on server.
Date: 3 Aug 2014 05:05:01
Message: <web.53ddfa253d3a69d449b26730@news.povray.org>
i installed povray with full source on server and moved the files of povray
subdivision(http://www.cise.ufl.edu/~xwu/Pov-Sub/) in source folder. then i
installed povray on centos server. povray is working fine but povray subdivision
is not working.
when i using code below.
mesh2 {
subdivision{     // subdivision
     substeps 2    // subdivide 2 times
vertex_vectors {
its showing error.
Please help me to solve the installation issue.
Thanks
Suman
Subject: Re: Installation problem in povray subdivision on server.
Date: 3 Aug 2014 07:06:03
Message: <53de179b$1@news.povray.org>
Am 03.08.2014 11:00, schrieb Suman:
> Hi,
> is not working.
What version of the POV-Ray source code did you use for this?
The subdivision patch was written for POV-Ray 3.6, and won't work with
POV-Ray 3.7.
Date: 3 Aug 2014 07:25:00
Message: <web.53de1b5c3102494a306240250@news.povray.org>
> > Hi,
> > is not working.
> POV-Ray 3.7.
i downloaded the POV-Ray Source Code from here
http://www.povray.org/download/index-3.6.php
and updated the subdivision files from source folder.
i used following command
../configure COMPILED_BY="your name <email@address>" [options]
  make check
  make install
Thanks
Suman
Date: 3 Aug 2014 07:47:51
Message: <53de2167@news.povray.org>
Am 03.08.2014 13:22, schrieb Suman:
>>> Hi,
>>> is not working.
Hmm... are you sure you put the files in the right folders in the source
tree?
Date: 3 Aug 2014 08:05:01
Message: <web.53de24d63102494a306240250@news.povray.org>
> >>> Hi,
> >>> is not working.
> tree?
yes i put all files of subdivision in source folder of povray. i replaced the
files of mesh.h,etc in source folder.
and then compile and install.
