POV-Ray : Newsgroups : povray.advanced-users : Parametric metaball? Server Time
8 Dec 2025 10:49:43 EST (-0500)
  Parametric metaball? (Message 1 to 9 of 9)
Subject: Parametric metaball?
Date: 22 Aug 2013 14:05:00
Message: <web.52165299b510e27941a177270@news.povray.org>
Are there parametric equivalents to the implicit metaball functions found here:
http://www.geogebra.org/en/upload/files/english/Michael_Horvath/Metaballs/geogebra_metaballs.htm
I would like to plot random points withing the curves/surfaces.
Thanks!
Subject: Re: Parametric metaball?
Date: 22 Aug 2013 17:54:07
Message: <5216887f$1@news.povray.org>
> Thanks!
Take a look at the blob primitive. The sole difference is that the
strength of the fields decrease in a linear fashion.
Date: 22 Aug 2013 18:50:01
Message: <web.5216950f243bb66641a177270@news.povray.org>
Thanks. How does that help me determine point coordinates?
Mike
> > Thanks!
Date: 22 Aug 2013 21:21:00
Message: <5216b8fc@news.povray.org>
Am 22.08.2013 20:04, schrieb posfan12:
For the special case of two elements, there most certainly /are/
parametric representations; for instance, assuming the elements are both
centered on the X axis, the following mapping will obviously work for
all cases where the surface in question is contiguous and the shape has
a circular y/z cross-section for every x:
   u = x
   sin(v) / cos(v) = y / z
(As a matter of fact it will work for plenty cases with non-circular
cross-sections as well.)
Solving for (x,y,z) for a given field strength may be non-trivial though.
Date: 23 Aug 2013 03:33:08
Message: <52171034$1@news.povray.org>
You could use the original equations in an isosurface object and then
use trace to find points on the surface. Would that do what you want?
Date: 23 Aug 2013 16:46:06
Message: <5217ca0e$1@news.povray.org>
> Mike
>>> Thanks!
Once the object is defined, you can use the trace function to shoot rays
at it from random locations. Be sure to use the trace with the normal
option. If the returned normal vector, that trace totaly missed your
object. For any non-null normal vector, you have a valid point on the
surface.
You also use an isosurface object. It allow you to use any function you
want. For the metaball using values diminishing relative to the
distance, you'll need to use the reciprocal (1/function) to get useable
result. An isosurface assume that values smaller that the thressold are
inside the object.
Date: 24 Aug 2013 16:30:02
Message: <web.521917b1243bb66641a177270@news.povray.org>
The problem is actually not a POVray one. I should have started a thread in off
topic instead.
So I can't make use of the isosurface object or the trace function.
What I ended up doing was placing random points in the blob's bounding box and
then testing whether they were inside the blob or not. A parametric equation
would result in no misses, and might have other desirable properties too such as
creating more points where the blob is densest or where the curvature is
greatest.
Mike
> > Mike
> >>> Thanks!
> surface.
> inside the object.
> Alain
Date: 24 Aug 2013 20:40:03
Message: <web.52195193243bb66641a177270@news.povray.org>
A related question:
I am looking at renders of implicit functions created in other software, such as
here:
http://xahlee.info/surface/cayley_cubic/cayley_cubic.html
How does the software make the nice wireframes gridlines. Is this easy to do?
Mike
Date: 25 Aug 2013 16:57:02
Message: <521a6f9e$1@news.povray.org>
> A related question:
> here:
> Mike
POV-Ray can't make a wireframe because, internaly, it's objects are
never converted into a mesh as most other applications do.
