POV-Ray : Newsgroups : povray.advanced-users : Creating Circular walls (using prisms ?) Server Time
14 May 2025 11:20:14 EDT (-0400)
  Creating Circular walls (using prisms ?) (Message 1 to 6 of 6)
Subject: Creating Circular walls (using prisms ?)
Date: 17 Sep 2010 16:15:00
Message: <web.4c93cb55eb91d5981dec65700@news.povray.org>
I am trying to create circular walls with radius and diameter values or from
which I can obtain said values. I am trying to stay away from CSG so I am
thinking of cubic_splines in prisms. I have been studying the code from Block
Wall Macros specifically the macro Blockwall_Arc(360,"") but it has been
difficult for me. Is there anybody that can make this code clearer for me...
tried to find a way to contact Chris Bartlett (I think, who wrote the code but
he seems very scarce on the net). Any help will be greatly appreciated. I am
guessing this is OK to include the code here. Perhaps studying it here will make
it easier for somebody to explain it to me.
Basically, I want to be able to plug in radius and/or diameter values to get a
circular wall or I would like to use this method but then be able to extract
radius and/or diameter values from it. Cheers!
//  This macro creates a circular (cylindrical) wall or a segment of a circular
wall.
#macro Blockwall_Arc (Blockwall_ArcDegrees, Blockwall_BlockType)
  #ifndef(Blockwall_Radius) #declare Blockwall_Radius  = 1;    #end
  #declare Blockwall_Spline = spline {
    cubic_spline
    #local Blockwall_I = -0.25;
    #while (Blockwall_I<=1.25)
      Blockwall_I, vrotate(Blockwall_Radius*z,
y*Blockwall_I*Blockwall_ArcDegrees)
      #local Blockwall_I = Blockwall_I + 0.01;
  object {Blockwall_FollowSpline(Blockwall_BlockType)}
Subject: Re: Creating Circular walls (using prisms ?)
Date: 17 Sep 2010 16:53:01
Message: <4c93d52d$1@news.povray.org>
> wall.
>      cubic_spline
>      #end
> #end
That macro is not self contained.
First : It create a spline that follows a circular path. For that, it
use an externaly created variable: Blockwall_Radius.
It also use 2 passed parameters: A value in degrees and a reference
value defining what kind of blocks to use.
Then, once the spline is constructed, it use another macro
(Blockwall_FollowSpline) to place blocks along that spline, surely
binded in an union so that you can place the result anywhere you need it.
What this macro _DON'T DO_: Create a prism.
It /DOES/ use CSG as an union of numerous blocks.
Date: 17 Sep 2010 17:20:00
Message: <web.4c93da964a0086d41dec65700@news.povray.org>
> Alain
I suspected that. OK, is there a way to create a spline path that can be used to
draw a prism of a particular radius or diameter. I can do trial and error and
end up with an approximation but I was wondering if there is a way to get a
mathematically precise method that can generate values for any radius or
diameter.
Date: 17 Sep 2010 17:37:50
Message: <4c93dfae$1@news.povray.org>
Am 17.09.2010 23:16, schrieb Kene:
> diameter.
There's no mathematically /exact/ way whatsoever to represent a circular
arc with a finite sequence of cubic splines (and all splines in POV-Ray
are effectively cubic splines or special cases thereof). Neither for the
general case, nor for any specific case (except maybe pathological ones).
Date: 17 Sep 2010 17:52:24
Message: <4c93e318$1@news.povray.org>
>> Alain
> diameter.
Quick and dirty:
- Remove the call to the other macro.
- Start your prism.
- Call the macro twice: once with the inside radius of your wall and
travel it to create the iner part of the prism. (use a loop)
- SAVE the first point!
- Call the macro a second time with the outside radius and travel the
spline backward to create the outside of the prism.
- Close the prism by adding the last point equal to the first one.
- Add any needed transformation and texturing.
- Finish the prism.
That's for a prism using a linear_spline interpolation.
If you want to use a cubic_spline interpolation, then the last TWO
points must repeat the first two points. The first and last points are
controls, the second and secont to last are real points.
Date: 17 Sep 2010 19:05:00
Message: <web.4c93f3474a0086d4531cc5f00@news.povray.org>
> Quick and dirty:
> - Start your prism.
> - Finish the prism.
> Alain
Interesting! This is what I am looking for. Let me see if I can get it to work.
Thanks...
