POV-Ray : Newsgroups : povray.advanced-users : Realistic subsurface scattering? Server Time
7 Mar 2026 18:29:15 EST (-0500)
  Realistic subsurface scattering? (Message 1 to 10 of 17)
Subject: Realistic subsurface scattering?
Date: 4 Mar 2009 15:45:00
Message: <web.49aee7c45c51f8d126f6761f0@news.povray.org>
I'm looking for a (free) renderer that does realistic subsurface scattering,
using physical material parameters as input (i.e. absorption and scattering
coefficients) - or a way to do it in POV. Rendering times don't matter, even if
it takes days to render a simple wax sphere on a checkered plane. Main
prerequisite is high physical accuracy.
I had hoped for a combination of scattering and absorbing media in POV to do the
job, but it doesn't seem to work with real physical material properties - unless
someone happens to know a reliable way to convert those properties to POV media
parameters.
The parameters I have available - aside from index of refraction - are
"absorption coefficients" and "reduced scattering coefficients" for red, green
and blue light respectively (computed from measurements under the simplifying
assumption that the "phase function" is isotropic).
Any ideas?
Subject: Re: Realistic subsurface scattering?
Date: 4 Mar 2009 15:59:59
Message: <49aeebcf@news.povray.org>
  Something like this?
http://www.luxrender.net/gallery/main.php?g2_itemId=2294&g2_imageViewsIndex=1
Date: 4 Mar 2009 16:20:01
Message: <web.49aeef7a80e98aa026f6761f0@news.povray.org>
Don't know - it's difficult to tell from a shot whether the materials were
modelled based on actual measured physical properties, or just diligently
tweaked until they looked just right, isn'it it?
I'm after a renderer with a realistic - not only convincing - subsurface
scattering model. And I'm after a renderer, not just some shots.
Date: 4 Mar 2009 16:20:53
Message: <49aef0b5$1@news.povray.org>
http://aqsis.org/ Renderman Compliant, so you should be able to make about
whatever you want.
http://www.indigorenderer.com/joomla/  Indigo rocks too.
http://www.indigorenderer.com/joomla/component/option,com_gallery2/Itemid,26/?g2_itemId=6441
ian
"clipka" <nomail@nomail> wrote in message
news:web.49aee7c45c51f8d126f6761f0@news.povray.org...
> scattering,
> scattering
> even if
> do the
> unless
> media
> parameters.
> green
> simplifying
> Any ideas?
Date: 4 Mar 2009 17:40:00
Message: <web.49af023180e98aa0773c9a3e0@news.povray.org>
This is the thread for that image:
http://www.luxrender.net/forum/viewtopic.php?f=14&t=1431
It uses a predefined material with a few parameters that don't seem to bear much
resemblance to any accurate physical properties.
Aqsis, being a Renderman system, should be even farther away from physical
correctness than unbiased renderers like Lux and Indigo.
Date: 4 Mar 2009 20:18:08
Message: <49af2850$1@news.povray.org>
"nemesis" <nam### [at] gmailcom> wrote in message
news:web.49af023180e98aa0773c9a3e0@news.povray.org...
My understanding of renderman compliant renderers was that you can program
shaders for nearly any behavior, is this incorrect?
ian
Date: 4 Mar 2009 22:50:00
Message: <web.49af4b9180e98aa0b4e1f2a20@news.povray.org>
Yes, but how does that integrate with a biased lighting model?
Date: 4 Mar 2009 22:55:00
Message: <web.49af4ce980e98aa063a1b7c30@news.povray.org>
Renderman is a biased renderer, meaning it is not a good way to achieve the
physical accuracy clipka seeks.  It may technically be possible to implement
it, but it's certainly not a good idea.
http://www.cgafaq.info/wiki/Bias_in_rendering
 - Ricky
Date: 5 Mar 2009 00:12:34
Message: <49af5f42$1@news.povray.org>
I gotcha.
Thanks for the info. ;-D
ian
"triple_r" <nomail@nomail> wrote in message
news:web.49af4ce980e98aa063a1b7c30@news.povray.org...
>> program
> the
> implement
> - Ricky
Date: 5 Mar 2009 03:40:00
Message: <web.49af8f5f80e98aa03ca3a0b90@news.povray.org>
> parameters.
> Any ideas?
Clipka a Sam Benge process may be useful?:
http://news.povray.org/489cc386%40news.povray.org
Clipka, sorry if I did not fully understand your question. :-)
POV info:
For those who do not know, I remember that Mr. Cason is working on:
http://news.povray.org/49688faa%40news.povray.org
Carlo
