POV-Ray : Newsgroups : povray.advanced-users : vector.x is a float, isn't it? Server Time
7 Mar 2026 20:16:35 EST (-0500)
  vector.x is a float, isn't it? (Message 1 to 7 of 7)
Subject: vector.x is a float, isn't it?
Date: 13 Jul 2008 17:35:00
Message: <web.487a73ecc7f877ecf75a90cb0@news.povray.org>
Can someone please explain to me why I ***can't*** do this?
CODE >>>>
  #declare myVector = <1,2>
  atan2(myVector.y,myVector.x)
<<<< CODE
Parse Error: Expected 'operand', uv vector identifier found instead
But why I ***CAN*** do this?
CODE >>>>
  #declare myVector = <1,2>;
  #declare xValue = myVector.x;
  #declare yValue = myVector.y;
  atan2(yValue,xValue)
<<<< CODE
Works just fine!
Isn't myVector.x a plain float value that can be used wherever
a float is required?
  slehar
Subject: Re: vector.x is a float, isn't it?
Date: 13 Jul 2008 18:00:01
Message: <web.487a7a07d340be7bc2684d3b0@news.povray.org>
> CODE >>>>
> <<<< CODE
> CODE >>>>
> <<<< CODE
> Works just fine!
>   slehar
You are correct that it "should" behave that way.  I know there is talk of
overhauling SDL and parsing for version 4.0.  Out of curiosity, have you tried
placing parenthesis? Such as:
atan2( (myVector.y) , (myVector.x) )
or even
atan2( (myVector.y + 0) , (myVector.x + 0) )
just off hand ideas, haven't tried it myself.
-Reactor.
Date: 13 Jul 2008 18:22:14
Message: <487a8016@news.povray.org>
"slehar" <sle### [at] gmailcom> wrote in message
news:web.487a73ecc7f877ecf75a90cb0@news.povray.org...
> CODE >>>>
#debug concat("myAngle: ", str(atan2(myVector.y,myVector.x),3,3),"\n")
writes "myAngle: 1.107" into the message stream for me on 3.6 under Windows.
What version are you running?
Chris B.
Date: 14 Jul 2008 08:15:01
Message: <web.487b42e3d340be7bf75a90cb0@news.povray.org>
> or even
> -Reactor.
Nope, the parentheses don't fix it.
Date: 14 Jul 2008 08:20:01
Message: <web.487b4422d340be7bf75a90cb0@news.povray.org>
> Regards,
> Chris B.
Wow, thats bizarre! That code works for me too! But when I put the atan2( ) in
the density function where I need it, it doesn't work!
I'm running version 3.6.
Date: 14 Jul 2008 09:05:44
Message: <487b4f28$1@news.povray.org>
news:web.487b4422d340be7bf75a90cb0@news.povray.org...
>> Windows.
>> Regards,
>> Chris B.
> atan2( ) in
Ah. I'm not sure it's your problem, but x, y and z are the default parameter
names used with a function, so I'd guess that they have a different meaning
if used in a function definition or within function parameters.  You might
want to try the equivalent colour vector component in your context on the
off-chance that it'll work. It works ok in the following context:
#debug concat("myAngle: ", str(atan2(myVector.green,myVector.red),3,3),"\n")
Chris B.
Date: 15 Jul 2008 01:37:09
Message: <uwTQ+EB2cDfIFwU5@econym.demon.co.uk>
>> Regards,
>> Chris B.
The problem isn't the atan2(), you can't mention vectors inside a
function. You can so this:
#declare mX = myVector.x;
#declare mY = myVector.y;
   function {
     ... atan2(mX,mY) ...
Mike Williams
Gentleman of Leisure
