POV-Ray : Newsgroups : povray.advanced-users : glowing effect Server Time
7 Mar 2026 20:16:31 EST (-0500)
  glowing effect (Message 1 to 4 of 4)
Subject: glowing effect
Date: 19 Nov 2007 07:10:00
Message: <web.47417cd68a5f5e61c3e1d1b80@news.povray.org>
can someone tell me how I might be able to achieve some type of glowing effect
for a given object?
I try rendering a sphere
sphere { 0, 1.5 pigment { Red  filter 1} finish{specular 1 brilliance 0 diffuse
0}}
I like that the object seems to be glowing while keeping its shape
and achieve the type of effect I'm looking for. However if I try the same
settings against a box, say
box { -1, 1 pigment { Red  filter 1} finish{specular 1 brilliance 0 diffuse 0}}
I don't seem to be getting the same effect. i'd also like the cnter to be more
red than white.
Ultimatley,
I would like to apply this to a mesh2 object defined as a solid using the inside
vector.
any advice how I might achieve the desired effect?
Subject: Re: glowing effect
Date: 19 Nov 2007 07:30:00
Message: <web.4741814ca720d5c3c3e1d1b80@news.povray.org>
> for a given object?
I forgot to add that these will be in a scene with "non-glowing" objects so I'm
not sure if atmospheric/lens effects will work.
Date: 19 Nov 2007 10:42:59
Message: <4741af03$1@news.povray.org>
Woody nous apporta ses lumieres en ce 2007/11/19 07:08:
> for a given object?
> 0}}
> red than white.
> Ultimatley,
> vector.
If you add "ambient 1" in the finish, the object will become luminous. About any
ambient value larger than zero will make the object glow somewhat.
If you want the object to glow from it's "inside", then you can fill it with
some emissive media. You will need to add "hollow" to permit the object to
contain the media. This is the only purpose of the hollow keyword.
If you want the object to be surounded by a glowing haze, you place a larger
copy of the object arount it. That oustide object will have:
texture{pigment{rgbt 1}finish{ambient 0 diffuse 0}}
and an interior filled with emissive media. That media will probably need a high
emission value, as it will not be very thick.
The object will not shed any light on it's surounding unless you use radiosity.
Caught Asleep At Your Work Desk
Just in case your boss catches you asleep at your desk, be ready to blurt out
this excuse #1:  I was working smarter - not harder.
Date: 19 Nov 2007 16:45:00
Message: <web.474203aea720d5c3f0eee6350@news.povray.org>
Thanks !
