POV-Ray : Newsgroups : povray.advanced-users : DF3 density file generation for a generic 3D object ? Server Time
10 Apr 2026 07:46:12 EDT (-0400)
  DF3 density file generation for a generic 3D object ? (Message 1 to 7 of 7)
Subject: DF3 density file generation for a generic 3D object ?
Date: 1 Oct 2007 11:10:00
Message: <web.47010cde36c235964e64f15d0@news.povray.org>
Prerequisites:
1) Having a generic closed object O;
2) Being able to apply inside(O,V) operator for a generic vector V
3) Being able to write DF3 files using povray language, maybe applying the
patch "Extended Density File"
What I'm looking for:
I'm looking for a macro for generating a DF3 file in output for the interior
of the object O passed to the macro. I'd like that the density is a function
of the minimal distance of V from the external surface of O: for V internal,
density[V] = density_function(minimal_distance(O,V)). In particular I'd like
a function the make the density greater when moving toward the interior of
O, where the increment could be linear, exponential, logarithmic, etc.
Is there a function for calculating the minimal distance of an internal
point V from the contour of O?
Have you any idea?
Do you think that only a patch could give me the expected result?
Some time ago I had the following idea: calculating the dimensions X, Y and
Z of the box containing O. Subdivide both X, Y and Z into n segments. Use
of 3 innested loops for x, y and z axis in order to cycle the segments and
see if the are or are not part of the interior of O. This is a sort of
sampling method. The greater n is, the more accurate the samples are.
Then I needed an algorithm for finding interior points at first level,
second level, third level, etc. The greater the level, the higher the
density, for example.
Oh these are just ideas. I don't know if I'm on the right way.
Bye,
A.
Subject: Re: DF3 density file generation for a generic 3D object ?
Date: 1 Oct 2007 15:36:59
Message: <47014c5b$1@news.povray.org>
Antonio Ferrari nous apporta ses lumieres en ce 2007/10/01 11:06:
Normaly, you use some external application to generate the DF3 file.
> Prerequisites:
You will have problem writing any non-ASCII characters to the file, POV-Ray only
write text files (ASCII encoded) and image files.
User deffined function.
> Have you any idea?
> Bye,
> A.
Aparently, you already have a function to eveluate the density. Taking that in
acount, it would be easier, and probably faster, to directly use that function
as density for a media.
interior{media{emission 1 density Your_Function}}
To increase the quality, you increase the samples value (default of 3). Don't
touch to intervals, inefficient and very slow.
Just remember - if the world didn't suck, we would all fall off.
Date: 1 Oct 2007 16:39:31
Message: <47015b03$1@news.povray.org>
> Prerequisites:
> interior
> function
> internal,
> like
There isn't a built in function for this, because there isn't a single
answer
to how far a minimal distance point is from the surface. You can use
trace to collect a sample of distances from the surface in random
directions to appoximate the minimal distance of a voxel from the
surface.
#include "rand.inc"
#macro distToSurface(Obj, vec, samp, rsd)
   #local dist = 1000000;
   #local c=0;
   #while (c<samp)
      #local rdir = VRand_On_Sphere(rsd);
      #declare Norm = <0, 0, 0>;
      #local hit = trace(Obj, vec, rdir, Norm);
      #if (vlength(Norm) != 0)
         #local dist = min(dist, vlength(hit - vec));
      #local c=c+1;
> Have you any idea?
This can be done with macros I think, though it would be slow to
calculate the distance data. You could calculate your three dimensional
array of distances on the first frame, scale the data, then write it to file
to reload for the remaining frames.  A slice of voxels could then be
generated from the data with the greyscale voxel colors determined
from the array data.
> and
This might work for simple objects, but will fail for complex objects.
Think of a hollow pipe A, if you scale it smaller then the new smaller
pipe B fits into the void of the first pipe A; the interior of A doesn't
share any points with the interior of B.
Date: 2 Oct 2007 08:05:00
Message: <web.470232d9413da414e64f15d0@news.povray.org>
> Alain
Hi Alain. First of all thank for you reply.
I explain better the problem...
Let suppose that the intersection of the object with a plane is (in 2D) as
follows:
Let's do our considerations in 2D, but they can be extended in 3D easily.
 @111111111@
@12222222221@
@123333333321@
@12222222221@
 @111111111@
What I'd want isn't a generic Your_Function with parameters x, y or z. What
I want is a density function with only a parameter d, where d is the
distance of the vector V=<x,y,z> from the contour of the surface, V inside
the object. It's obvious that there are some preconditions to impose...
Look at the 2D section... Let's consider a linear density function.
Your_Function conincide with the distance. So, for point at distance 1,
density is 1; for points at distance 2, density is 2; and so on.
Does the line "interior{media{emission 1 density Your_Function}}" allow me
to do what I'm expecting? Does it allow me to "follow" the contour of the
object?
Date: 2 Oct 2007 08:15:00
Message: <web.47023516413da414e64f15d0@news.povray.org>
> answer
> surface.
> #include "rand.inc"
>    #local c=0;
>    #while (c<samp)
>       #end
>       #local c=c+1;
>    #end
> #end
Hi Tim thank for this macro... It's very useful to me :)
This just what I'd like. I have only to see if there is the possibility to
write a macro for isolating the more external points, the points nearest to
the surface. Let's call A1 the set of these points. These points have
density=my_func(1). Let's remove A1 point from our array. Let's find the
external points of the new array and call them A2. These points have
density=my_func(2). And so on for other distances.
I have to study better these cases...
Bye.
Date: 2 Oct 2007 10:18:01
Message: <47025319$1@news.povray.org>
Antonio Ferrari nous apporta ses lumieres en ce 2007/10/02 08:00:
>> Alain
> follows:
>  @111111111@
> @12222222221@
> @123333333321@
> @12222222221@
>  @111111111@
> object?
If the object is an isosurface with a threshold of 0 and you use the same
function for the density, the density will start at zero at the surface and go
up as you move in. By exactly how much depends on the gradient of the
function,but some scaling can do the trick. If the function is quadratic, taking
it's square root will return a linear curve.
If you use some primitives, there are some patterns that can help. Those are
spherical, boxed and planar.
spherical start at 1 at the origin and drop to zero at radius = 1.
boxed start at 1 at the origin and drop to zero when reaching 1 unit distance in
any ortogonal direction.
planar start at 1 on the x-z plane and drop to zero at 1 unit along the y axis.
Those can be scaled, receive various wave shapes, be multiplied, divided,
squared,...
You know you've been raytracing too long when you're watching Bay Watch on the
telly, see Pamela A. walking by and shout out "Great bump mapping!"
Date: 3 Oct 2007 05:20:00
Message: <web.47035dca413da414e64f15d0@news.povray.org>
> squared,...
> Alain
Yes. I didn't think to isosurfaces. There many isosurfaces that povray can
handle. The following wonderful tutorial explains them:
http://www.econym.demon.co.uk/isotut/
Furthermore I know that one of Christoph patches can speed up the process
for isosurfaces.
The problem could be for complex CSG objects or if I decide to use meshes,
sor, lathe, etc.
Only one more question: if have two isosurface objects with their own media
and I construct an union, difference or intersection, what happens to
medias? I'll try to esperiments this cases...
