POV-Ray : Newsgroups : povray.advanced-users : Repeating Patterns Server Time
10 Apr 2026 07:46:15 EDT (-0400)
  Repeating Patterns (Message 1 to 7 of 7)
Subject: Repeating Patterns
Date: 20 Sep 2007 03:55:01
Message: <web.46f226a53f8015ea7a1f45c00@news.povray.org>
I made a simple animation that kind of looks like the sun, using the
following basic method:
camera{location <0,0,-2.25> look_at <0,0,0>}
sphere {<0,0,0>,1 pigment{bumps scale 0.25 translate <0,0,clock>}
finish{ambient 1}}
Initial_Clock=0
Final_Clock=1
Cyclic_Animation=on
The only problem is that I want the animation to loop so that the final
picture is continuous with the initial picture. I thought the "bumps",
"spotted", and "bozo" patterns would do this for me, but apparently they
are not a repeating patterns. Is there any way for POV-Ray to make
repeating patterns that resemble these patterns?
Subject: Re: Repeating Patterns
Date: 20 Sep 2007 04:30:01
Message: <web.46f22f45d8fa0949a9ce4df50@news.povray.org>
> finish{ambient 1}}
> Initial_Clock=0
> Final_Clock=1
> Cyclic_Animation=on
maybe you could use warp{repeat offset z/2 flip z}
Date: 20 Sep 2007 09:30:50
Message: <46f2760a$1@news.povray.org>
bugman nous apporta ses lumieres en ce 2007/09/20 03:52:
> finish{ambient 1}}
> Initial_Clock=0
> Final_Clock=1
> Cyclic_Animation=on
Instead of using translate, use a rotation. If you don't want the rotation to
look like a rotation but a translation, place your object away from the origin
then apply the rotation on the pattern:
#declare Offset = 5;
sphere {Offset*x,1 //put the sphere away from the origin
	pigment{bumps scale 0.25 rotate <0,0,clock*360>//rotate the pattern
// *360 so that it does a full rotation
// you can substitute z for x if you want it to show a lateral movement
	translate -Offset*x //put it back at the origin
bumps = bozo minus the builtin colour_map
leopard is a periodic pattern
You know you've been raytracing too long when you downloaded and printed the
Renderman Interface documentation, so you'd have a little light reading to take
on holiday.
Alex McLeod a.k.a. Giant Robot Messiah
Date: 20 Sep 2007 09:36:13
Message: <46f2774d@news.povray.org>
honnza nous apporta ses lumieres en ce 2007/09/20 04:28:
>> finish{ambient 1}}
>> Initial_Clock=0
>> Final_Clock=1
>> Cyclic_Animation=on
This will give you a banded aspect. The repeat warp will repeat a particular
strip of the pattern with very visible seams. Also, the offset will cause each
strip to use a different part of the pattern, increasing the visibility of the
seams.
You know you've been raytracing too long when you keep a blacklist of people who
ask questions about 3DFX products.
Date: 20 Sep 2007 13:47:15
Message: <46f2b223$1@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:46f2774d@news.povray.org...
>>> finish{ambient 1}}
>>> Initial_Clock=0
>>> Final_Clock=1
>>> Cyclic_Animation=on
> particular strip of the pattern with very visible seams. Also, the offset
> will cause each strip to use a different part of the pattern, increasing
> the visibility of the seams.
> Alain
I was going to suggest rotation as Alain did, but the problem with rotation
is that you need a centre of rotation some way away (e.g. 5 times the
radius) to avoid a sensation of an unbalanced movement in the texture and
with a fairly detailed pattern it then needs a heck of a lot of frames to
get a smooth repeating cycle (with a small bumps scale I reckon it would
need several hundred frames).
I tried fiddling with Honnza's 'warp' and 'flip' idea and you can get rid of
the seams that Alain mentioned, but you still see the reverse in direction,
so it seems to twist back and forth. With the following example you get a
smooth repeat in about 30 frames and with the original, bigger bumps you
could reduce the number of frames further.
#declare depth = 0.175;
sphere {<0,0,0>,1 pigment{bumps scale 0.05 warp{repeat depth*z  flip z}
translate <0,0,2*depth*clock>} finish{ambient 1.5}}
Although a tad more complicated, you can get a better result by 'building' a
repeating pattern using the gradient pattern. The following example uses
displaced copies of the same pattern to create a repeat, avoiding the back
and forth motion caused by the 'warp' and 'flip'. This creates 5x1 unit long
copies of the same repeating pattern, then moves the pigment back so that it
can move forward through the sphere by 1 unit over the animation cycle
without any of the sphere being outside of the repeating pattern. This gives
you a fine-grained control over the frequency of the repeat and the number
of frames in your animation cycle.
#declare Sun_BasePigment = pigment {
  bumps turbulence 0.5
  pigment_map {
    [0.0 color rgb<0.7,0.35,0>]
    [0.5 color rgb<1,0.8,0>]
    [1.0 color rgb<0.7,0.35,0>]
#declare Sun_Pigment = pigment {
  gradient z
  pigment_map {
    [0.0, Sun_BasePigment scale 0.05]
    [0.2, Sun_BasePigment scale 0.05 translate z*0.2]
    [0.4, Sun_BasePigment scale 0.05 translate z*0.4]
    [0.6, Sun_BasePigment scale 0.05 translate z*0.6]
    [0.8, Sun_BasePigment scale 0.05 translate z*0.8]
    [1.0, Sun_BasePigment scale 0.05 translate z*1.0]
  scale 5*z
sphere {<0,0,0>,1
  pigment {Sun_Pigment translate <0,0,-3+clock>}
  finish{ambient 1.2}
Hope this helps.
Chris B.
Date: 21 Sep 2007 10:30:31
Message: <46f3d587@news.povray.org>
Chris B nous apporta ses lumieres en ce 2007/09/20 13:47:
>>>> finish{ambient 1}}
>>>> Initial_Clock=0
>>>> Final_Clock=1
>>>> Cyclic_Animation=on
>> Alain
> Hi,
>   pigment_map {
>   gradient z
>   pigment_map {
>   scale 5*z
> sphere {<0,0,0>,1
>   finish{ambient 1.2}
> Hope this helps.
> Regards,
> Chris B.
Another possibility that I did'nt think immediately:
In cases similar to yours, the use of the phase keyword may be a possible solution.
1 - create your base texture as you want.
2 - ADD in the texture block "phase clock"
You get:
sphere{0,1
	pigment{Sun_Pigment phase clock}
	finish{ambient 1.2}
As the value for phase goes from 0 to 1, the values of the map get shifted in a
circle.
For a people who are free, and who mean to remain so, a well-organized and
armed militia is their best security.
Thomas Jefferson
Date: 22 Sep 2007 18:00:01
Message: <web.46f58fbed8fa0949cafca3fe0@news.povray.org>
Thank you everyone for the suggestions. I decided to use the warp method.
Here are some animations:
http://bugman123.com/Fractals/Sun.gif
http://bugman123.com/Fractals/Sun.m1v
camera{orthographic location <0,0,-2> look_at <0,0,0>}
sphere {0,1
 pigment{bumps
  color_map{[0 rgb 0][1/3 rgb 0.5*x][2/3 rgb <1,0.5,0>][1 rgb 1]}
  scale 0.5 warp{repeat z/2 flip z} turbulence 5 translate <0,0,-clock>
 finish{ambient 1.5}
