POV-Ray : Newsgroups : povray.advanced-users : Invisible Reflecting Object Server Time
10 Apr 2026 11:26:30 EDT (-0400)
  Invisible Reflecting Object (Message 1 to 4 of 4)
Subject: Invisible Reflecting Object
Date: 4 Oct 2006 10:50:01
Message: <web.4523c99ec2682d854f4866300@news.povray.org>
I was wondering (and have experimented and failed) whether you could have a
completely invisible object in the scene that specularly reflects light.
For instance say you have a red sphere of radius 1, an invisible
dodecahedron of radius 1.1, and a few multi-colored spotlights.
Can you make it so the reflections shown on the ground and walls come from
the dodecahedron's surface without actually seeing the dodecahedron, and
all you see is the sphere which seems to be making the dodecahedron
reflections?
Thanks for any help!
Ravious
Subject: Re: Invisible Reflecting Object
Date: 4 Oct 2006 13:55:09
Message: <4523f57d$1@news.povray.org>
> reflections?
Check out no_image, no_shadow and no_reflect.
Also, if you're shining a spotlight on the thing and expecting to see
spots of light all over the place, you'll be needing photons to do that.
What you could do (not sure if it will work properly) is run POV-Ray
once with the object there as normal (to generate the photon map), and
then run POV-Ray again with the same photon map but with the object removed.
Date: 4 Oct 2006 14:15:00
Message: <web.4523f9ce770c1397176347e30@news.povray.org>
I knew about no_shadow, but didn't know about the other two.  I will try out
the photon map as well.  Thanks for your help.
Date: 4 Oct 2006 21:59:25
Message: <452466fd@news.povray.org>
Orchid XP v3 nous apporta ses lumieres en ce 04/10/2006 13:55:
>> have a
>> from
>> reflections?
Have the dodecaedron have no_image to make it invisible. Give it a photons block
with target on reflection on.
Give one or the other no_shadow, depending on what shadow you want.
If you have reflective surfaces showing the sphere, give the dodecaedron
no_reflection to remove it's reflection.
> removed. or replaced.
That trick does work, and have been used to good effect.
Celebrate Hannibal Day this year.  Take an elephant to lunch.
