![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I would like to do the following:
to have a object with media inside, where the density of the
media is controlled by the x,y,z so that the max density is reached
at 0,0,0 and the minimum at the border of the object?
any ideas?
Thor
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For any given object? Not possible. (At least not at any reasonable speed.)
If it were, it would be the holy grail of raytracing.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"McHannemann" <nomail@nomail> wrote:
> Hi,
> any ideas?
> Regards,
> Thor
Well, you could try to make a density file by randomly shooting out rays
from the given point and sampling along that path, writing the density
value to a 3d density file, then reading that back in as a .ds3 file.
Haven't tried that, though, but there is a galaxy.pov file in the samples
which has structure like that.
But, like Warp said, it would be slow. Very. Especially when you first
generate the density file. After that, it depends on your raytracing
quality settings.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
McHannemann nous apporta ses lumieres en ce 30/04/2006 05:19:
> Hi,
> any ideas?
> Regards,
> Thor
If your object is basicaly a sphere, maybe distorted, you can use the spherical
pattern.
If it's close to a box, then you can use the boxed pattern.
In the case of a cylinder, you have the cylindrical pattern.
You also have the planar pattern.
All goes from one in the center and decrease to zero at 1 unit. spherical is relative
to the origin,
cylindrical is along the y axis, planar along the x-z plane and boxed fits an unit
cube. You need to
scale, rotate, translate to place the patterns correctly relative to your container.
If your shape is an isosurface, you may, at least in several cases, use the same
function for your
density. This will take a lot more time to render than the previous patterns.
It will work *IF* your function start high inside the isosurface and decrease when you
mover away
*AND* you use a thresshold value of zero (0).
Utopianism: This shit does not stink.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
