"Mike" <inf### [at] mydis org> wrote in message
news:web.43d6f47f30dfb549a12b420@news.povray.org...
> Is there a way to using Povvray's SDL to simply instantiate an object X at
> a
> specified moment in time (somewhere between 0.0 and 1.0) and then
> terminate it at a specific moment in time (between 0.0 and 1.0). If so,
> this would really help with an AI Animation I'm working on where I must
> maintain and print out complex multi-demonsional arrays into spline paths.
> All thoughts great appreciated!
> -mike
> http://www.mydis.org
Yes.
You simply add the object to the scene within a clause that is conditional
upon the clock value. Fore example:
#if (clock>0.42 & clock<0.84)
sphere {...}
Chris B.
Wasn't it Mike who wrote:
>Is there a way to using Povvray's SDL to simply instantiate an object X at a
#if ((clock > 0.25) & (clock > 0.75))
object {X}
Mike Williams
Gentleman of Leisure
Subject: Re: Instantiation and terminiation....OOP & Povray?
Date: 25 Jan 2006 11:25:00
Message: <43d7a65c@news.povray.org>
This is why one should never use the > sign in comparisons. :-)
#if ((0.25 < clock) & (clock < 0.75))
Once you get into the habit, it rescues you from pretty much every
single mistake of this form.
Luke, the Force is a powerful ally,
second only to The QuickSave.
Date: 25 Jan 2006 14:30:01
Message: <43d7d1b8@news.povray.org>
The problem with that is that it's hard to understand.
If you say to someone "if 25 is smaller than the amount of money in
your wallet, you can come" he will probably have to stop for a moment
to think about what that means.
People don't say nor think "is 25 smaller than the money I have?" but
they always think the other way around. That's why writing things like
"if (25 < money)" makes code confusing.
Date: 25 Jan 2006 14:46:03
Message: <43d7d57b@news.povray.org>
One you get used to it, you read it as "clock is between 0.25 and 0.75."
Read it "is my money more than 25?" Ignore the < vs >, and read the
order the variables are in. Like the "number line" you learned in grade
school. It's really not any more confusing than starting to count at
zero and continuing while less than your limit. Once you get used to it...
It especially helps when working with time and timestamps, I find.
Whatever's on the right is later, whatever is on the left is earlier.
Date: 25 Jan 2006 14:56:20
Message: <43d7d7e3@news.povray.org>
What if the operator is something else? How fast can you decipher it
with this simple change:
#if ((0.25 < clock) | (clock < 0.75))
Personally I have to mentally swap the first comparison before I can
even grasp it.
I usually read from left to right. I'm not a Chinese.
Besides, it doesn't make sense that sometimes you have to read
comparisons from right to left and sometimes from left to right.
> - Warp
For only one value that is mostly true. However in the case of bracketing
values, it sandwiches the variable nicely so its easy to see ((0.25 <
clock) & (clock < 0.75)) as (0.25 < clock < 0.75).
-tgq
Date: 25 Jan 2006 15:22:44
Message: <43d7de14$1@news.povray.org>
You know it's wrong. :) & goes there if the variable's in the middle, |
goes there if it's on the outside.
Just like if you saw
for (i = 0; i <= count; i++)
you'd know it's probably wrong and you need to look close to make sure.
When the expression gets complex, it's harder, yes. With simple stuff,
you can see both sides of the equation at once. As I say, like counting
starting from zero, it takes seeing it a few times for it to be comfortable.
Of course, Cobol got this bit right, I fear. :-) There's a couple other
languages that let you write
if (x < y < z)
but I don't remember just what they are.
(Chinese goes top to bottom, btw. :-)
Date: 25 Jan 2006 15:38:06
Message: <43d7e1ae@news.povray.org>
If they must write horizontally because of space constraints,
they write from right to left.
if (0.25 < $clock < 0.75)
will be in Perl 6. Even less chance of confusion then.
Always crash crash crash Well come on and let me know
You're happy when I'm running bash Should I play or should I code?
One test is fine, next is black (with apologies to The Clash)
So if you want a dodgy hack worse at http://surreal.istic.org/songs
