POV-Ray : Newsgroups : povray.advanced-users : Optimizing scenes with nested loops. Server Time
10 Apr 2026 16:23:36 EDT (-0400)
  Optimizing scenes with nested loops. (Message 1 to 3 of 3)
Subject: Optimizing scenes with nested loops.
Date: 12 Aug 2005 23:45:01
Message: <web.42fd6be1d1dc40c7f6675d760@news.povray.org>
I am working on some timple functions to make my own grass (I want the
challenge of making my own, I know there are some out there already).  The
way I'm doing it right now gives me the results I want (it looks like I
want it to look), but the parsing process is very slow due to the nested
loops that I use.  I am using splines to calculate the path I want.  With
my spline, I simply draw triangles to make up the grass.  There is a loops
the goes up the spline, while drawing triangles.  This loop is contained in
another loop whose roll it is to create multiple blades.  Heck, here is the
source code:
#declare counter=0;
#declare num_blades=12000;
#declare s_point1=<0,0,0>;
#declare s_point2=<0,0,0>;
#declare s_step=.1;
#declare blade_width = .025;
#while( counter < num_blades)
#declare num1=((rand(R2)-.5)*30) ;//-11 ;
#declare num2=0;
#declare num3=(rand(R2)-.5)*30;//- 11  ;
#declare rot = rand(R2)*360;
#declare ctr = 0;
#declare sway=cosd(clock)*.025;
#declare s = spline {quadratic_spline  0, <0,0,0> .5, <0, .5,0> 1, <0,1,.5>
#while (ctr < 1)
  /*sphere {
    <s(ctr).x,s(ctr).y,s(ctr).z>,.02
    pigment { rgb <1-ctr,ctr,0> }     */
    #declare s_point1=s(ctr);
    #declare s_point2=s(ctr+s_step);
    triangle {<s_point1.x-blade_width,s_point1.y,s_point1.z>
<s_point1.x+blade_width,s_point1.y,s_point1.z>
<s_point1.x-blade_width,s_point2.y,s_point2.z> pigment {color rgb <0,ctr,0>
} finish {diffuse .5} translate <num1,0,num3>   rotate y*rot}
    triangle {<s_point1.x+blade_width,s_point1.y,s_point1.z>
<s_point1.x+blade_width,s_point2.y,s_point2.z>
  #declare ctr = ctr + s_step;
#declare counter = counter + 1;
As already stated, the parsing step is very slow and takes a lot of ram
(once it hits swap, the time required goes through the roof.  Can someone
help me come up with a good optimization scheme?
Subject: Re: Optimizing scenes with nested loops.
Date: 13 Aug 2005 01:18:44
Message: <42fd82b4@news.povray.org>
> source code:
Yes, you want to avoid the swapping out.
What everyone does with this is to take advantage of "instancing"
Basically you want to group some subset of your traingles in a mesh
block with an assigned name.  Then you reuse this mesh object to build
your larger structure.  In the case of grass or hair the best break
point is usually at the "patch" level, so to speak. (ie meaning a
"patch" of grass.)  Instancing individual blades is usually too small a
number of triangles to be efficient so you put some number of blades
into a patch then reuse the patch to produce a grass "lawn"
The last time I did this I believe I made patches of about 75 blades of
grass, each blade with five triangles.  But that number can be quite
flexble according to what you are trying to do and what kind of memory
you have.  I also sometimes produce an array of grass patches each
randomly different, then access the array randomly to get a more
irregular look.
Date: 13 Aug 2005 01:50:19
Message: <mfea4CA4nY$CFwvC@econym.demon.co.uk>
>source code:
I notice that all your blades are actually identical within each frame
of the animation, so it's possible to have two separate loops, one that
#declares a blade as a union of triangles, and the other that places
lots of copies of it.
I then noticed that it's possible to create the blade as a mesh, instead
of a union, since it consists only of triangles.
On my old slow computer it now parses in 7 seconds, using 111 Mb peak
memory.
Here's the resulting code:
#version 3.6;
global_settings {assumed_gamma 1.0}
camera {location  <0,10,-30> look_at <0,0,0> angle 50}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#include "math.inc"
#declare counter=0;
#declare s_step=.1;
#declare R2 = seed(1);
<0,1,.5>}
// Create a single grass blade as a mesh
#declare Blade = mesh {
  #declare ctr=0;
  #while (ctr < 1)
    #declare T = texture {
       pigment {color rgb <0,ctr,0>}
       finish {diffuse .5}
     texture {T}
     texture {T}
// place lots of blades
union {
    #declare num2=0;
    object {Blade
      rotate y*rot
Mike Williams
Gentleman of Leisure
