POV-Ray : Newsgroups : povray.advanced-users : panoramic, cylindrical, spherical Cameras Server Time
15 May 2025 22:34:35 EDT (-0400)
  panoramic, cylindrical, spherical Cameras (Message 1 to 2 of 2)
Subject: panoramic, cylindrical, spherical Cameras
Date: 9 Nov 2004 08:40:01
Message: <web.4190c7a76ad58ae39fc2448a0@news.povray.org>
i've been playing around with different cameras options trying to work with
panoramic views.
i think that the povray's tutorial about it isn't enought, i couldn't really
understand how to set cameras of different types, i just could use
cylindrical 1 and panoramic.
does anyone of us used these funcions and could explain it better ???
tnx
;o)
Subject: Re: panoramic, cylindrical, spherical Cameras
Date: 9 Nov 2004 19:12:36
Message: <41915cf4$1@news.povray.org>
Okay I suppose the easiest to start on is Panoramic.
On a normal camera, the rays originate at one point and shoot out towards
points on a flat grid, the size of which is defined by the up and right
keywords.
Now with a panoramic camera it's sort of the same with the y projection but
the x sweeps around in an arc, as if it's projecting not onto a flat plane
but to points on the inside of a cylinder centred on the camera's location,
around a sweep defined by the angle.
Spherical cameras are similar but now you have 2 angles, so you're getting
the x projection and the y projection as circular sweeps.
Essentially  if you were to use a full 360 spherical camera and pate the
resultant image to the inside of a sphere and place a camera in the middle,
it'd look like you were looking around inside a scene.
This can be used for environment mapping on reflective objects ( do a google
serach for environment mapping for more info on this )
The cylindrical camera is where it gets tricky... To be honest I think I
know how this works but I don't want to shout my mouth off and be proved
wrong or mislead you so I'll let someone else answer that one.
Anyone else??
-Pete
"Spirtu" <nomail@nomail> wrote in message
news:web.4190c7a76ad58ae39fc2448a0@news.povray.org...
> with
> panoramic views.
> really
> tnx
> ;o)
