POV-Ray : Newsgroups : povray.advanced-users : Intense Light and semi-transparent paper Server Time
11 Apr 2026 07:08:26 EDT (-0400)
  Intense Light and semi-transparent paper (Message 1 to 3 of 3)
Subject: Intense Light and semi-transparent paper
Date: 20 Dec 2002 20:25:03
Message: <web.3e03c27775f9e51c514daf780@news.povray.org>
Hello
I am Trying to get the same effect one has when holding a
semi-transparent piece of paper (rice paper for example)
into a laser. The Laser passes through but a lot of light
is scattered and an bright Spot apears on the paper.
Right now I am using the following to create the paper:
box{<-2.5e-02,-2.5e+01,-2.5e+01>,<2.5e-02,2.5e+01,2.5e+01>
  interior{fade_power 2 fade_distance 3000}
  texture{pigment{color 1.0*White transmit 0.75}}
  translate <1.6e+02,0,0> }
However I do not get the bright spot due to scattering.
What am I missing?
George
Subject: Re: Intense Light and semi-transparent paper
Date: 20 Dec 2002 21:16:21
Message: <3e03cef5@news.povray.org>
fade power and fade distance don't simulate scattering. To get a fairly accurate
model you should use scattering media.
Though you can probably fake the effect quite cheaply using a completely thin
object (e.g. a triangle) and pov's double_illuminate flag.
Tek
http://www.evilsuperbrain.com
George <nomail@nomail> wrote in message
news:web.3e03c27775f9e51c514daf780@news.povray.org...
> Hello
> What am I missing?
> Regards,
> George
Date: 21 Dec 2002 08:50:03
Message: <web.3e0470d1b305e87cca5b3bef0@news.povray.org>
I did not use them with that intention anyway.
Ok. I will give it a shot :-)
Faking is not an option, in the context I am using povray.
George
>Tek
>George <nomail[at]nomail> wrote in message
>news:web.3e03c27775f9e51c514daf780[at]news.povray.org...
>> Hello
>> What am I missing?
>> Regards,
>> George
