I know I use to do this prior to 3.5, I think in Megapov, I could change the
way an image map was read by giving it it a color_map, but I'm getting
errors now in 3.5.
Perhaps I've just forgotten the syntax?
Can anyone out there help? What is the syntax for changing colors in an
image map so that they can perform double duty?
Can it only be done with grey scale or 8-bit palleted images?
-- normdoering
Subject: Re: replacing colors on an image_map...how?
Date: 27 Nov 2002 03:22:39
Message: <3de480cf@news.povray.org>
"normdoering" <nor### [at] yahoo com> wrote in message
news:web.3de471b9539782556d954fc00@news.povray.org...
the
> errors now in 3.5.
Yes. 256 colors so they are indexable like a color map; but also nonindexed
(unmapped) images where the red component is used (had to look that up)
instead. So... only way I know of to do that directly is with material_map.
It's done like so:
#declare IndexColor = 123;
#declare ReplacementColor = color rgb <1,0,0>;
plane {
z,5
material_map {
sys "any256bitmap.bmp"
#local I=0;
#while (I<IndexColor)
texture {}
#local I=I+1;
pigment {color ReplacementColor}
#local I=IndexColor+1;
#while (I<256)
texture {}
#local I=I+1;
} // material map
} // texture
} //plane
light_source {0,1}
I'm guessing you might have already known of this way, and unfortunately
this example here simply blanks the other indices out requiring an
additional step to add the original image back in. That would be to use a
duplicate plane beneath this one and apply a image_map to that one, then use
100% transparency as filler in the material map one.
Well, that's my thoughts on this anyhow.
Farewell,
Date: 27 Nov 2002 08:22:57
Message: <3de4c731@news.povray.org>
> the way an image map was read by giving it it a color_map, but I'm getting
> errors now in 3.5.
There's the image_pattern, which uses a (internally grayscaled) image as a
pattern. Then it can be used anywhere a pattern can be used with an
appropriate kind of blend map (eg. color_map, texture_map, density_map...).
