POV-Ray : Newsgroups : povray.advanced-users : Trying to write new HF_ macros, how to cut the mesh? Server Time
11 Apr 2026 08:57:15 EDT (-0400)
  Trying to write new HF_ macros, how to cut the mesh? (Message 1 to 7 of 7)
Subject: Trying to write new HF_ macros, how to cut the mesh?
Date: 9 Nov 2002 13:15:06
Message: <web.3dcd4ff566ca52347efeba520@news.povray.org>
I'm trying to write my first new HF_ macro (as in shapes.inc) and the first
thing I want to do is rewrite the HF_Square (as HF_pressmold()) so that you
don't get excess mesh where you don't want it. That is, not a square, but a
cut out shape. What seems to be offered are these dot operators.
There are five possible components and the supported dot types to access
these components -- from the isosurface section of POV help:
F( ).x | F( ).u | F( ).red
to get the red value of the color vector
F( ).y | F( ).v | F( ).green
to get the green value of the color vector
F( ).z | F( ).blue
to get the blue value of the color vector
F( ).filter | F( ).t
to get the filter value of the color vector
F( ).transmit
to get the transmit value of the color vector
F( ).gray
to get the gray value of the color vector
gray value = Red*29.7% + Green*58.9% + Blue*11.4%
F( ).hf
to get the height_field value of the color vector
hf value = (Red + Green/255)*0.996093
If another function is declared and used by a new HF_ macro in order to get
another color channel that channel might tell the macro where to cut off
excess mesh to get the shape desired. I don't know if transmit and filter
channels can be easily made by all paint programs or if theres a way the
masks corel draw can make for .png files can be accessed (is transmit a
mask channel?).
All the colors make white, that shows up on all color channels, I think. So,
you'd have to do some sort of compare...
#if (red_component < blue_component + green_component)
--make a mesh point on the grid--
#else
--skip this part of the grid--
I think the above code would cut out all elements of a picture with a strong
red tinge.
However, how does one express that cutting so that HFCreate_() can read it?
Will HFCreate have to be rewritten too?
And if so... what's a good way to do it? make another array grid just to
tell the create macro where to cut? There should be a better way...
Just thinking out loud here, maybe someone out there has ideas.
normdoering
Subject: Re: Trying to write new HF_ macros, how to cut the mesh?
Date: 9 Nov 2002 13:43:09
Message: <chrishuff-BF0503.13425509112002@netplex.aussie.org>
In article <web.3dcd4ff566ca52347efeba520@news.povray.org>,
> mask channel?).
I think the best way would be a separate mask function. That way, you
aren't limited to an image with an alpha channel. You could then use a
user defined function to mask out parts of the image. (I don't even know
how POV image maps handle alpha channels, I've never used it.)
Now I just couldn't figure out this sentence...the colors of a height
field image are not shades of gray. The red and green channels are
combined to get 16 bit precision out of 2 8-bit channels, the blue
channel is ignored. You could probably use the blue channel for mask
information, if that's what you are asking...it won't work if you then
use a grayscale image, and it will limit you to image files unless you
do some extra work to encode the mask into a pigment function.
Probably. For this you should probably write your own version, not
modify the height field macros in shapes.inc, which could cause problems
parsing other people's code.
http://tag.povray.org/
Date: 9 Nov 2002 19:45:04
Message: <web.3dcda89c6f496618178f7f9c0@news.povray.org>
Christopher James Huff wrote:
>In article <web.3dcd4ff566ca52347efeba520[at]news.povray.org>,
>> mask channel?).
In my Corel photopaint I can separate the red, green and blue channels and
each each channel becomes a separate grey scale kind of picture. White and
black are the same on all channels and the difference in colors shows up
only in subtle variations in grey shades. A strongly red color is whiter in
the red channel and darker in the blue and green channels. If the red is
pure enough it's twice as bright as either blue or green.
>the colors of a height field image are not shades of gray.
I found out that you don't need to use the .hf dot operator, you can use
either .red, .green, .blue or .grey operators on color images and the HF_
macros work.
> The red and green channels are combined to get 16 bit precision out
> of 2 8-bit channels, the blue channel is ignored.
> You could probably use the blue channel for mask information,
Ah, I picked the wrong color.
> it won't work if you then use a grayscale image, and it will limit
> you to image files unless you do some extra work to encode the mask
Maybe the best way would be to let the user decide what they want to use.
Since the dot operator is chosen outside the HF_ macro it wouldn't matter
what the macro thought the channel was. That is, you could write any of
these:
#declare MeshCut = function {MyCutImage(x,z,y).red}
#declare MeshCut = function {MyCutImage(x,z,y).blue}
#declare MeshCut = function {MyCutImage(x,z,y).transmit}
#declare MeshCut = function {MyCutImage(x,z,y).grey}
to get a working function.
>Probably.
I was afraid of that. This is getting more complicated the more I think
about it.
Right. But that's not really what I meant. When I talking about "rewriting"
it has to do with the way I write code, I find other code that's close to
what I want and copy it to a new file, rename the function/macro/whatever,
and start making changes. Less typing, less re-inventing all the little
wheels that make it work.
The HF_macros may not actually be the closest to what I want, they're just
what I found and what people here know about (thanks to help from you
guys here I know that is). They can take a hand drawn image that was scanned
in and make a limited type of mesh. However, it's not exactly the
"sculpting with a pencil" idea I'm trying to implement. Warp may have
turned me on to some great "close" code, The Subdivision Surface Suite.
http://enphilistor.users4.50megs.com/sss.zip
normdoering
Date: 9 Nov 2002 20:13:48
Message: <chrishuff-2817F4.20132909112002@netplex.aussie.org>
In article <web.3dcda89c6f496618178f7f9c0@news.povray.org>,
Right, images are represented with red, green, and blue channels.
> macros work.
Right, .red, .green, and .blue return the values of specific color
components, .grey returns the grayscale value, and .hf returns a height
value using the same technique the height_field object uses.
> about it.
Heh, well, it looks like the height field macros were rewritten to use a
rectangular patch of triangles, and it would take some big changes to
handle other geometries. My original version wrote the triangles more
directly, which would have made this modification easier, but my version
didn't output in mesh2 format. Looks like the tetrahedron subdivision
spherical height field is gone too...I liked that one, it didn't have
the pinching problems at the poles, and spread out the triangles better.
Someone else gave some code that might be easier to modify than the
height field macros.
Date: 10 Nov 2002 01:10:03
Message: <web.3dcdf5256f496618178f7f9c0@news.povray.org>
>.... looks like the height field macros were rewritten to use
> a rectangular patch of triangles, and it would take some big
> changes to handle other geometries. My original version wrote
> the triangles more directly,...
I may have a copy already, I've downloaded more stuff from these newsgroups
than I recall, but I think I want to see your method. I don't want the
triangles in rectangular patches.
> ... which would have made this modification easier, but my version
That'a okay. Outputting different formats isn't that big a deal. You just
need a understanding of the format.
>... Looks like the tetrahedron subdivision spherical height field is
> gone too...
The what? I never saw any early versions (yet) so I don't know what you're
talking about. I only found out the HF_ macros existed a day or so ago when
you guys told me they were there.
> I liked that one, it didn't have the pinching problems at the poles,
> and spread out the triangles better. Someone else gave some code that
> might be easier to modify than the height field macros.
I may have this, but I'll have to check on what I downloaded tonight. If
not, I'll be looking for them.
normdoering
Date: 10 Nov 2002 12:55:22
Message: <chrishuff-07B2B1.12550310112002@netplex.aussie.org>
In article <web.3dcdf5256f496618178f7f9c0@news.povray.org>,
Well, it just calculated the undisplaced positions of each point,
calculated the displacement for those points, and then wrote a triangle
with those points. Not well optimized at all, but not limited to a
rectangular sheet.
BTW, just leaving out triangles will produce ragged edges, you will
probably need to smooth that out somehow, which would probably be
easiest if you had an array of vertices and another of validity flags.
It was a version of the spherical height field that didn't use a
rectangular sheet wrapped around the sphere. When you do that, the top
and bottom get pinched together at the poles, wasting triangles and
potentially causing visible artifacts. An alternative method is to
repeatedly subdivide a polyhedron, usually a tetrahedron or octahedron.
Each level of subdivision increases the number of triangles by 4, so you
don't get as tight control of the resolution, but the triangles are all
more or less of equal size and equally spread out, and without the
obvious patterns leadinging towards the poles. Looks like it disappeared
when the macros were updated for mesh2.
Date: 10 Nov 2002 17:30:07
Message: <web.3dcedcb46f4966181dffbb4f0@news.povray.org>
>In article <web.3dcdf5256f496618178f7f9c0[at]news.povray.org>,
>rectangular sheet.
Still, I'm looking for better starter material to work from. My macros will
probably be complex so I'm looking for more complexable tools. For example,
Ingo Janssen wrote "makemesh.inc" It has the macros and functions for
builing mesh2 objects. It looks like I'll be able to use that one rather
than the one in shapes.inc.
http://members.home.nl/seedseven/makemesh.html
His  BuildWriteMesh2() macro has options to write Wavefront *.obj files,
*.pcm files, for Chris Colefax' Compressed Mesh Macros, and *.arr files,
which writes only the arrays to a file. This last one is a great advantage
as it's the best mode for reading arrays back later for further mesh
manipulations. Another advantage, the array used by BuildWriteMesh2()
looks, at my first glance here, to be one dimensional, not thought of as a
rectangular grid.
Janssen's macro is called this way:
#include "makemesh.inc"
      BuildWriteMesh2
      ( VecArr,     //  The array that contains the vertices of the mesh.
        NormArr,    //   normal vectors that go with the vertices.
        UVArr,      //   uv_vectors
        U,          //   # of subdivisions of the surface in the
u-direction.
        V,          //   # of subdivisions in the v-direction.
        FileName    //  file, "" or .obj or .pcm or .arr that's written to.
Valadity flags?
Right now I'm not even sure how this bit of code works:
 #while (J<xRes+1+Smooth)
 #local K = 1-Smooth;
    #while (K<zRes+1+Smooth)
         #local UV = <(J-1)/(xRes-1),0,(K-1)/(zRes-1)>;
         #local P  = (UV*Ext*<1,0,1> + MnExt);
         #if (UVheight)
            #local H = Function(UV.x, UV.z, 0);
         #else
            #local H = Function(P.x, P.y, P.z);
// What kind of data is the Function that reads the picture data here
// assigning to H? Does the picture reading function read a 2D array
// of data and assign a 3D point to H or just the height value?
// I've only used these picture reading functions in isosurfaces and
// never learned to use them in a pixel by pixel read.
         #declare PArr[J][K] = P + H*Ext*y;
         #declare K = K+1;
      #declare J = J+1;
   HFCreate_()
Hmmm, right now what I want is to is learn how the picture reading function
works in a pixel by pixel loop and then create a one dimensional array of
vertices, what BuildWriteMesh2() seems to use.
--normdoering
