POV-Ray : Newsgroups : povray.advanced-users : HF_ macro question. Server Time
17 May 2025 06:00:42 EDT (-0400)
  HF_ macro question. (Message 1 to 6 of 6)
Subject: HF_ macro question.
Date: 7 Nov 2002 23:30:04
Message: <web.3dcb3c88902ebc51ccdab82b0@news.povray.org>
This may be a newbie type question, but here goes:
I'm trying to use the HF_ functions in shapes.inc to generate a mesh from a
small .png file.
I simply added a new funtion to the example file given in the include files
demo. When I did, I got an error.
#declare MyFunction = function{pattern {bumps scale 0.2}}
 // MyFunction above works...
#declare MyTest = function
 { pigment
   { image_map
     {png "testHF.png"
      map_type 0 interpolate 2
  } // <- this replacement produces an error.
    // shapes.inc pops up and marks the bit of code named above
object {
   HF_Square
    ( MyTest, // MyFunction was here, but I replaced it.
      off,
      off,
      <60,60>,
      on,
      <0.0, 0.1, 0.0>,
      <1.5, 0.5, 1.5>
      pigment {color rgb 1}
      finish {ShinyFinish}
   translate <-3.0, 0.0,-3.2>
// The error that happens pops up shapes.inc and a line in the
// HFCreate_() macro gets marked. See note below.
  #local J = 1;
   #while (J<=xRes)
      #local K = 1;
      #while (K<=zRes)
         PArr[J][K],   // <-- this code gets highlited in yellow
         #declare K = K+1;
      #declare J = J+1;
What do I do to get an image file used as a function?
normdoering
Subject: Re: HF_ macro question.
Date: 8 Nov 2002 03:05:12
Message: <3dcb7038@news.povray.org>
"normdoering" <nor### [at] yahoocom> schrieb im Newsbeitrag
news:web.3dcb3c88902ebc51ccdab82b0@news.povray.org...
As a pattern, this function returns a float value.
>  { pigment
>    { image_map
>      {png "testHF.png"
As a pigment, this function returns a vector. Pov can handle
vector-functions only in special cases, therefor you have to convert the
output to a float value.
Try:
#declare MyTest=function{MyTest(x,y,z).hf}
(it's difficult to find but the dot-operators are explained in the docs
somewhere)
Hth,
Marc-Hendrik
Date: 8 Nov 2002 06:05:04
Message: <web.3dcb996edf16341f89ebea3f0@news.povray.org>
>news:web.3dcb3c88902ebc51ccdab82b0[at]news.povray.org...
>>  { pigment
>>    { image_map
>>      {png "testHF.png"
>Try:
>somewhere)
>Hth,
>Marc-Hendrik
Thanks! I never would have figured that one out without help. Don't know
enough about the internal workings of pov yet.
normdoering
Date: 8 Nov 2002 07:20:04
Message: <web.3dcbab07df16341f5c65a5ba0@news.povray.org>
>>>  { pigment
>>>    { image_map
>>>      {png "testHF.png"
>>Try:
>>somewhere)
>>Hth,
>>Marc-Hendrik
>normdoering
I spoke too soon. Adding your line of code got rid of the error, but the
image doesn't appear on the "height field." All I get is a flat rectangle.
normdoering
Date: 8 Nov 2002 10:12:36
Message: <3dcbd464@news.povray.org>
This is at least the fifth place where you ask this same question.
  Posting a question once is usually enough.
Date: 8 Nov 2002 17:10:03
Message: <web.3dcc3593df16341f55d3e9910@news.povray.org>
Sorry, I was frustrated and wanted an answer fast.
At any rate -- some additional information:
Dot operators are mentioned in the section on isosurfaces (at tail end of
section 6.5.4.2) and there's more than .hf -- there's .grey (which works as
well for grey scales) and .red, .green, .blue, and .transmit -- which means
there is even more creative potential for this kind of macro.
normdoering
