POV-Ray : Newsgroups : povray.advanced-users : function optimization question Server Time
29 Mar 2026 08:55:17 EDT (-0400)
  function optimization question (Message 31 to 40 of 65)
Subject: Re: function optimization question
Date: 19 Mar 2002 10:36:07
Message: <7ime9ukggvcv8thtubar3a94hadk998qn1@4ax.com>
On 19 Mar 2002 10:30:40 -0500, Ron Parker <ron### [at] povrayorg> wrote:
> Loops, too.
Sounds great.
> They're just not part of the syntax.
Is this a bonus pack for patch writers or it will be boundled with Profesional
Edition ? ;-)
ABX
Date: 19 Mar 2002 10:41:16
Message: <slrna9en0s.eie.ron.parker@fwi.com>
>> Loops, too.
> Sounds great.
> Edition ? ;-)
What, assembly-language-like bytecode isn't good enough for you?  Kids these
days...
I think at the moment that it's a bonus pack for patch writers.  I don't know
what the Team's plans are WRT the debugging features, but you can probably
place large bets on the syntax not changing before 3.5.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 19 Mar 2002 11:04:02
Message: <3C976170.93CD802F@gmx.de>
> > Edition ? ;-)
> days...
Anyway it would be great if there was some kind of documentation for such
hidden features.  Not neccessarily in the user docs, but maybe included in
the source code package.
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 19 Mar 2002 11:09:28
Message: <2foe9u0noelccpuqc58519jv8h45lk153b@4ax.com>
> days...
My asked for my daughter. She likes building functions in macros and render in
one pass ;-)
http://news.povray.org/3c2caae6@news.povray.org
it's dream of many people I think
ABX
Date: 19 Mar 2002 11:11:22
Message: <slrna9eopc.ejm.ron.parker@fwi.com>
On Tue, 19 Mar 2002 17:04:00 +0100, Christoph Hormann wrote:
>> > Edition ? ;-)
>> days...
There is no source code package yet, right?  And when there is, there will
be the same documentation I used to find this feature.
That documentation looks something like this:
    else if(Token.Token_Id == STRING_LITERAL_TOKEN)
                FNCode_SetFlag(2, Token.Token_String);
                Get_Token();
                if(Token.Token_Id == COMMA_TOKEN)
                        Get_Token();
                        if(Token.Token_Id != STRING_LITERAL_TOKEN)
                                Expectation_Error("valid function expression");
                        FNCode_SetFlag(1, Token.Token_String);
                else
                        Unget_Token();
                        expression = FNSyntax_ParseExpression();
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 19 Mar 2002 11:20:52
Message: <slrna9epb4.ejm.ron.parker@fwi.com>
>> days...
> one pass ;-)
Well, there ya go then.  Straight from the horse's mouth.  Of course, since
it's just turned off with a compile-time switch, enterprising patch writers
will be able to turn it back on easily.
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 19 Mar 2002 11:21:51
Message: <0ape9uormom5m6kg6v7hn5ld9nm2o92mmk@4ax.com>
and it's very similiar to 6.1.6.6 chapter :-)
ABX
Date: 19 Mar 2002 11:26:13
Message: <slrna9epl7.ejm.ron.parker@fwi.com>
I'm obviously missing something... there is no 6.1.6.6???
Date: 19 Mar 2002 11:29:28
Message: <pnpe9uk2an43j2rvp72b6b8qrominjqgpd@4ax.com>
It was supposed to be a joke since there is also no "else if(Token.Token_Id ==
STRING_LITERAL_TOKEN)" in my installation of documentation ;-)
ABX
Date: 19 Mar 2002 11:32:46
Message: <slrna9eq1g.eln.ron.parker@fwi.com>
That's because you don't have the source code package, and all the
documentation it customarily comes with.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
