POV-Ray : Newsgroups : povray.advanced-users : function optimization question Server Time
13 Mar 2026 05:34:02 EDT (-0400)
  function optimization question (Message 11 to 20 of 65)
Subject: Re: function optimization question
Date: 16 Mar 2002 14:32:21
Message: <3c939dc5$1@news.povray.org>
>   Naturally if some type of iterative loop is implemented, then recursion
> will not be needed.
And you can't tell if these loops will terminate, if it's turing complete ...
so one could lock up the render, without knowing it ....
probably one have to include something like a "maxiteration" for loops (if they were
available) .. so to cancel an infinite loop
after, maybe, 10000 times going over a specified "label" .... (just an idea) ...
Date: 16 Mar 2002 15:21:55
Message: <MPG.16fdc81e3ce92ec49896ea@news.povray.org>
In article <3c939dc5$1@news.povray.org>, jan### [at] lzernet says...
Whats the problem? A sufficienty complicated object (preferrably with a
glas material and filled with scattering media...) can do practically the
same.
Lutz-Peter
Date: 16 Mar 2002 16:10:46
Message: <3c93b4d6$1@news.povray.org>
Yeah ... but it WILL terminate ...
and even if recursion-depth will be 2^32 .... it WILL terminate ...
you can't tell this for every function if the "machine" is turing-complete
... or better the other way around:
If  a function terminates, then: fine...
but if it is running, there's no algorithmic way, to determine if this function will
ever terminate or not ...
Your only chance is to wait and see ...
of course, there are trivial ones, but for every function you find, that is possible
to tell, there are infinite other functions,
where you can't tell ...
Date: 16 Mar 2002 16:11:03
Message: <3c93b4e7@news.povray.org>
  So can a #while. So what?
  That's not the problem here.
Date: 16 Mar 2002 16:57:45
Message: <3c93bfd9$1@news.povray.org>
but it happens at parse-stage ... there's no image rendered yet, and you can debug it
by using the debug-stream ...
functions can get evaluated at rendertime ...
you can't debug them by writing some intermediate-values to some stream ...
you see my prob ?
Date: 16 Mar 2002 17:30:54
Message: <MPG.16fde65b9dbc8c219896eb@news.povray.org>
In article <3c93b4d6$1@news.povray.org>, jan### [at] lzernet says...
But that's only relevant in theory because you won't wait that long
anyway.
Lutz-Peter
Date: 16 Mar 2002 20:46:08
Message: <3c93f560@news.povray.org>
it by using the debug-stream ...
  You can do the same thing with functions.
  Yes, you can.
> you see my prob ?
  No.
Date: 16 Mar 2002 20:49:30
Message: <chrishuff-5A16DA.20492316032002@netplex.aussie.org>
In article <3c93bfd9$1@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
> debug it by using the debug-stream ...
Why not? Just make an equivalent to #debug that operates at function
evaluation time, whether while parsing or rendering.
If you set an arbitrary limit, it will either be too low and get in
people's way (like the recursion limit for macros), or be too high and
not be useful. Why bother?
Date: 16 Mar 2002 22:22:17
Message: <3c940be9$1@news.povray.org>
>   What you want is simple: Support for defining variables inside
functions.
Hmm, I suppose you're right. Is that difficult? I'd think you'd only need
some sort of array attached to the function internally, holding all the
values and their respective variable names.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 17 Mar 2002 01:49:19
Message: <2re89uo42pdv7nstepkrs12id6b055ukoj@4ax.com>
On Sat, 16 Mar 2002 20:49:23 -0600, Christopher James Huff
Only if you make it built-in. If you can change it in the scene or in
the ini file, there will not be such a problem.
Peter Popov ICQ : 15002700
