POV-Ray : Newsgroups : povray.advanced-users : fuctions and uv_mapping Server Time
28 Sep 2024 15:13:45 EDT (-0400)
  fuctions and uv_mapping (Message 1 to 5 of 5)
Subject: fuctions and uv_mapping
Date: 24 Mar 2003 07:21:59
Message: <pan.2003.03.24.12.21.25.112773@ntlworld.com>
Is there a simple way to apply uv_mapping within a function.
I'm looking for something that would work like..
#declare Chladni_uv = function{
        function{Chladni_2d (x,y,z,4,5)}
  	uv_mapping
if it were valid syntax.
Dave
Subject: Re: fuctions and uv_mapping
Date: 24 Mar 2003 07:32:41
Message: <pgut7vg07fe0jcih5mgukk6a8p04870mec@4ax.com>
On Mon, 24 Mar 2003 12:21:25 +0000, "David Burnett" <var### [at] ntlworldcom>
>   pigment {
>     uv_mapping
uv_mapping is always defined in relation to geometry of some shape. There is
lack of shape in above example so no uv_mapping available. But you can always
use own user-defined functions which translates x,y,z coordinates to some 2D
coordinates in your preferred way.
ABX
Date: 24 Mar 2003 07:48:52
Message: <3E7EFEC8.896E7DB3@gmx.de>
None the less it could be useful in some situations if usage of functions
in pigments would allow both 3d and uv coordinates.  You could create
patterns with a structure following the surface (uv coordinates) but this
structure varying with the 3d position.   AFAIK Renderman shader language
has this possibility.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Subject: Re: functions and uv_mapping
Date: 24 Mar 2003 12:13:46
Message: <pan.2003.03.24.17.13.10.896437@ntlworld.com>
On Mon, 24 Mar 2003 13:49:12 +0100, Christoph Hormann wrote:
>> There is lack of shape in above example so no uv_mapping available. But
>> you can always use own user-defined functions which translates x,y,z
>> coordinates to some 2D coordinates in your preferred way.
> functions in pigments would allow both 3d and uv coordinates.
Thats the sort of thing I'd like, if functions where 'extended' so that
they passed x,y,z,u,v when rendering a uv mapped object or just u,v.
All this came from a uv_mapped 2D pigment function that I wanted to try
using as iso_function to 'displace' a sphere, to give that extra inch of
realism over using it as a normal function.
Dave
Date: 24 Mar 2003 12:48:33
Message: <3E7F4506.D82A7B7B@gmx.de>
This has nothing to do with what i mentioned.  You can't use uv-mapping
for a displacement function since UV coordinates are only available on the
surface (i.e. in textures).  You could generalize that to uvw-coordinates
but that would require elementary changes and would only work for certain
very basic objects.
Using angular coordinates for displacing the surface of a sphere is no
problem with the current function syntax.
