POV-Ray : Newsgroups : povray.advanced-users : Radiosity scenes tinted? Server Time
20 Apr 2026 05:33:50 EDT (-0400)
  Radiosity scenes tinted? (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Radiosity scenes tinted?
Date: 10 Dec 2000 09:36:51
Message: <chrishuff-705491.09374410122000@news.povray.org>
In article <3A2FAB0A.D4918A9A@peak.edu.ee>, Margus Ramst
<mar### [at] peakeduee> wrote:
> Well, in MegaPOV the default gray_threshold is 0, which  in most
> cases makes the radiosity lighting look too saturated IMHO. In
> regular POV the default is 0.5, but perhaps people still set it too
> low to make the rad effects more conspicuous.
I think gray_threshold 0 is supposed to be the most realistic, it is a
way to artificially limit the saturation of the color blending in the
image.
Christopher James Huff
Date: 10 Dec 2000 11:15:27
Message: <3A33ACA9.9C226F3@peak.edu.ee>
> image.
Perhaps, although it should also help counteract the effects of a limited number
of samples and recursion levels.
And for example radiosity lit "blue sky" outdoor scenes do tend to look
unrealistically blue IMO, so despite my limited knowledge of physics I must
assume there is some aspect of natural light behaviour not provided for here.
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 10 Dec 2000 11:41:58
Message: <3A33B241.3AE39D72@gmx.de>
It's probably right that a blue sphere/sky_sphere is not a good physical
representation of a real sky.  NTL, don't forget that the sunlight is
usually far from being 'white' so there is some kind of compensation.
Date: 10 Dec 2000 11:46:40
Message: <Xns9006BCC6Fseed7@povray.org>
>must assume there is some aspect of natural light behaviour not
>provided for here.
In the real world there is no direct "colour-bleeding" from the blue sky.
It where nice if it was possible to switch off the lolour of the bleeding
from the "sky_sphere" in POV.
Photorealism: these blue pictures look as if an outdoor scene was
photographed with a film suitable for artificial light.
Ingo
Date: 10 Dec 2000 13:18:10
Message: <chrishuff-09094A.13190210122000@news.povray.org>
In article <3A3### [at] peakeduee>, Margus Ramst
> limited number of samples and recursion levels.
This is true for some cases...
The human eye can compensate for color casts...try messing with the
color temperature of your monitor, for example. At first it will look
red or blue, but after a while it looks white again. POV doesn't do
this, it simulates the effect of a "perfect" film camera. If someone did
a post_process filter to simulate different types of film, you could set
it up to use an outdoor film and lessen that effect while still using
accurate radiosity settings.
Date: 10 Dec 2000 13:20:16
Message: <chrishuff-9B9F56.13210910122000@news.povray.org>
In article <Xns### [at] povrayorg>, ing### [at] homenl (ingo)
I believe you are mistaken...most of the illumination in the shade comes
from scattered light. And things lit with sky light *do* have a blue
cast, but your eyes usually adjust to it.
Date: 10 Dec 2000 14:06:05
Message: <slrn937im1.8eg.hjp-usenet@teal.h.hjp.at>
>>provided for here.
There is, but see below:
Exactly. Sunlight is a lot more blue (or less red) than artificial
light. The human eye adapts to these differences, but film - or povray -
cannot. Therefore you need different films for indoors and outdoors to
get lighting, which "looks right". Similarly, would need different
settings in povray to simulate the adaptation of the human eye to
different lighting.
	hp
   _  | Peter J. Holzer    | Es war nicht Gegenstand der Abstimmung zu
| |   | hjp### [at] wsracat      | Zahlen neu festzulegen.
__/   | http://www.hjp.at/ |	-- Johannes Schwenke <jby### [at] ginkode>
Date: 10 Dec 2000 14:53:16
Message: <3A33DEA1.C79494AF@videotron.ca>
Agreed.  Look at shadows on fresh snow.
Francois Labreque | Rimmer: "Let's go to red alert!"
    flabreque     | Kryten: "Are you sure, Sir?  You realize it
        @         |          actually means changing the bulb!"
   videotron.ca
Date: 10 Dec 2000 15:28:57
Message: <Xns9006D2204seed7@povray.org>
The snow in the shadows has a bluish tint, the rest of the snow is
"white". The general lightning is white, due to atmospheric scattering the
shadow is blue.
When radiosity rendering with a blue sky_sphere it is as if the light is
blue. The snow and the shadow are blue.
This is why I stated: "In the real world there is no direct "colour-
bleeding" from the blue sky", probably needed to put more emphasis on
"direct".
Ingo
Date: 11 Dec 2000 05:21:22
Message: <3a34aaa2@news.povray.org>
Margus Ramst <mar### [at] peakeduee> wrote:
: And for example radiosity lit "blue sky" outdoor scenes do tend to look
: unrealistically blue IMO
  That's probably because people tend to make their skies unrealistically
blue and bright.
