POV-Ray : Newsgroups : povray.advanced-users : Announce: SkyPOV 0.1 Server Time
6 Nov 2026 03:27:30 EST (-0500)
  Announce: SkyPOV 0.1 (Message 1 to 1 of 1)
Subject: Announce: SkyPOV 0.1
Date: 2 Nov 2000 01:45:23
Message: <8FE01D1B3markwagner17gtenet@204.213.191.228>
Announcing.....SkyPOV 0.1!
SkyPOV is an unofficial version of POV-Ray designed to do atmospheric
effects.  It is based on MegaPOV 0.6a.  Due to computer problems beyond my
control, it is currently available only as source code.  If I can find
time, I will upload a Windows binary tomorrow.  If I can't, it will be
available next Tuesday.
To compile, download the SkyPOV and MegaPOV 0.6a source code, copy the
SkyPOV source over the MegaPOV source, and compile.
Source is available at
http://www.geocities.com/rengaw03/download/wskypovs.zip
Features:
 * Wavelength-dependant Rayleigh scattering
 * Infinite-light hack -- needed to make wavelength-dependant scattering
   look good
 * A few notes on how to use the program.
 * Two or three demo scenes
Features that might make a future version:
 * Colour curve post-processing to replace the infinite-light hack
 * Random rendering order
 * A polynomial parser to allow polys to be written as "3x^5+2xy+z-1" etc.
 * Assorted minor optimizations
 * Improved "quality" command-line options
 * Improved splines
 * Render time prediction
 * Fixed memory leaks
Might make it into version 99999
 * Variable IOR
 * Non-linear transforms
 * Spectral ray-tracing
Mark Wagner
Subject: Re: Announce: SkyPOV 0.1
Date: 2 Nov 2000 03:46:54
Message: <3A0129E2.7E9B9FCE@alpharay.de>
> Features:
>    look good
>  * Improved splines
>  * Variable IOR
> Mark Wagner
Sounds good!
Go hell, TerraGen  ;-)
Can someone upload a compiled version? (maybe on your homepage, Nathan?)
Paul
Date: 2 Nov 2000 08:02:58
Message: <chrishuff-32B9DD.08060502112000@news.povray.org>
In article <8FE01D1B3markwagner17gtenet@204.213.191.228>,
I am going to make a post_process filter which uses a spline to adjust
color values...is this what you are talking about?
You mean it picks a random pixel each time? Another thing that might be
nice: some kind of "progressive" antialiasing, that renders the image
without antialiasing and then makes several "refinement" passes.
>  etc.
Couldn't you use isosurface functions? I haven't had a look at your
patch yet, so I don't really know what this is for...
I hope command line options aren't necessary for this...you should be
able to specify all options in the scene file. Or are you talking about
changing the "Render Quality" option syntax?
>  * Improved splines
I would suggest using one of the spline patches...less duplicate code,
more standardized, etc...
Christopher James Huff
Date: 2 Nov 2000 11:13:29
Message: <3a0192a8@news.povray.org>
In povray.general Mark Wagner <mar### [at] gtenet> wrote:
:  * A polynomial parser to allow polys to be written as "3x^5+2xy+z-1" etc.
  Why, when we have isosurface functions already?
  Isosurfaces even render faster than polys (I had a hard time admitting this
at the beginning, but currently I'm quite happy about this).
Date: 2 Nov 2000 15:47:16
Message: <3A01D3E8.8C98EF92@unforgettable.com>
OH YEAH, BABY!! XD
So to those of you out there concerned with such things.. how long until
someone churns out a Mac binary? What are the odds that any of this will
be added to the next version of the Ultra-Giganto Patch?
-Xplo
Date: 3 Nov 2000 01:04:09
Message: <3a025559$1@news.povray.org>
Chris Huff wrote in message ...
Yes.
That's going to be part of the system, since I can't do antialiasing with
just one pixel.
>>  etc.
I don't have it implemented yet, but this will be for the "poly" object
type.  It's much easier to enter a formula for a 7th-order polynomial as a
formula than as a string of a hundred coefficients.
Yes, render quality options.  I'm going to make it possible to turn specific
things on and off -- specifically, these will be available in version 0.2:
 +QQ = use quick colors
 +QA = use area lights -- cancels +QF
 +QF = use ambient only -- cancels +QA, +QM
 +QS = calculate shadows
 +QM = use reflection -- cancels +QF
 +QL = use refraction
 +QN = use normals
 +QV = use media?
>>  * Improved splines
This is going to be an improvement on the spline{} syntax.
Mark
Date: 3 Nov 2000 01:14:03
Message: <3a0257ab@news.povray.org>
Mark Wagner wrote in message
<8FE01D1B3markwagner17gtenet@204.213.191.228>...
A Windows binary is available at:
http://www.geocities.com/rengaw03/download/wskypov.zip
Mark
Date: 3 Nov 2000 04:06:42
Message: <3A02B82F.1A446F24@chesapeake.net>
I tried to use the link provided but geocities said
that page was not available. I tried .../rengaw03/download/
and HAL invited me to go back.
sniff..... I so wanted to see this version.... sniff
> Mark
Date: 3 Nov 2000 09:46:00
Message: <chrishuff-AE6B1C.09490803112000@news.povray.org>
In article <3a025559$1@news.povray.org>, "Mark Wagner"
> Yes.
I will send you the code as soon as it is tested.
> just one pixel.
Good. :-)
> object type.  It's much easier to enter a formula for a 7th-order
> polynomial as a formula than as a string of a hundred coefficients.
Oh, I thought this was for something else...this seems rather redundant,
since you can just use isosurfaces to do the same thing, and
often(usually?) with faster rendering.
Oh...
Ok, what improvements are you thinking of? More spline types, the
ability to choose what kind of spline to use at evaluation time?
By the second, I mean something like this:
#declare Spline = spline {...the usual spline stuff...}
#declare Val1 = Spline(XVal);
#declare Val2 = Spline(XVal, cubic_spline);
#declare Val3 = Spline(XVal, linear_spline);
Another wild idea that might be useful: allow splines to be used as
color maps. :-)
Date: 4 Nov 2000 00:41:54
Message: <3A03A18D.FDFBCBF0@peak.edu.ee>
Ditto
Margus Ramst
Date: 4 Nov 2000 01:23:16
Message: <3a03ab54$1@news.povray.org>
>> Yes.
Thanks!
>Oh...
I'm going to be removing the limit on the number of points in a spline, and
making it possible to use the points from one spline as the basis for
another spline, like:
#declare Spline2 = spline{ Spline 1,<2,2,2> etc.}
Right now you can't do that.
Mark
Date: 4 Nov 2000 01:27:25
Message: <3a03ac4d@news.povray.org>
Margus Ramst wrote in message <3A03A18D.FDFBCBF0@peak.edu.ee>...
>Ditto
How odd.  I just downloaded it successfully from that address.  Was it
giving you a "file not found" error, or some other error message?
Mark
Date: 4 Nov 2000 01:43:29
Message: <3a03b011$1@news.povray.org>
Try the links from my POV-Ray downloads page to see if they work for you.
http://www.geocities.com/rengaw03/povray.html
Mark
Date: 4 Nov 2000 02:54:44
Message: <3A03C0CC.E0F7CBFC@peak.edu.ee>
Got it.
As far as I know Geocities doesn't like direct download links originating from
non-geocities addresses. Since your home page is also at Geocities, a link from
there will work.
Margus Ramst
Date: 4 Nov 2000 06:10:59
Message: <chrishuff-DDBC53.06140904112000@news.povray.org>
In article <3a03ab54$1@news.povray.org>, "Mark Wagner"
> Thanks!
I'm having a hard time getting it to work though...I suspect the problem
is in my parsing code, though I'm not sure why it is misbehaving.
Anyway, this is the syntax I am planning to use(I am currently working
on the first form):
curves {rgb RED_SPLINE, GREEN_SPLINE, BLUE_SPLINE}
curves {red RED_SPLINE}
curves {green GREEN_SPLINE}
curves {blue BLUE_SPLINE}
curves {gray GRAY_SPLINE}
(got a better name for the last one? "all"?)
When I add color space conversion filters, you will be able to adjust
other types with these filters(convert to another color space, modify
the correct channel, convert back to rgb).
There is a limit? I hadn't noticed...
> and making it possible to use the points from one spline as the basis
> for another spline, like:
I noticed the Parse_Spline() function had the ability to take an
identifier to create a copy of the spline, but also had a bug which made
that useless when no new points were defined. I think it was intended to
work the way you describe, allowing new points to be inserted.
Also, it would be useful if you could access the control points, with
functions that behave similar to the array functions and an array-like
syntax.
Date: 4 Nov 2000 07:26:41
Message: <chrishuff-5D700A.07295104112000@news.povray.org>
In article <chrishuff-DDBC53.06140904112000@news.povray.org>, Chris
I found the problem, a rather nasty bug in Copy_Spline(). It allocates
room for the spline data, but doesn't copy the old data to the new
spline. I have no idea how this wasn't noticed before...the fixed
version is below(all that was needed was the addition of one line, the
call to memcpy()). I am still not sure it is right, I have never used
memcpy() before, but it works. :-)
SPLINE2 * Copy_Spline(SPLINE2 * se)
    SPLINE2 * New;
    New = (SPLINE2 *)POV_MALLOC(sizeof(SPLINE2), "spline");
    New->SplineEntries =
POV_MALLOC(se->Number_Of_Entries*sizeof(SPLINE_ENTRY), "spline entry");
    memcpy(New->SplineEntries, se->SplineEntries,
se->Number_Of_Entries*sizeof(SPLINE_ENTRY));
    New->Number_Of_Entries = se->Number_Of_Entries;
    New->Type = se->Type;
    return New;
Date: 5 Nov 2000 00:13:50
Message: <3a04ec8e@news.povray.org>
Thanks!
Mark
Date: 5 Nov 2000 00:16:17
Message: <3a04ed21@news.povray.org>
"all" makes more sense than "grey".
The limit is 256 points -- enough for most uses, but why have a limit when
there doesn't need to be one?
>syntax.
This might be very difficult to implement -- there are enough problems with
the spline syntax as it is.
Mark
Date: 5 Nov 2000 06:57:59
Message: <3A058301.484E3EB7@chesapeake.net>
That worked much better. Thanks for the assist.
> Mark
Date: 5 Nov 2000 07:19:56
Message: <chrishuff-2C509F.07230805112000@news.povray.org>
In article <3a04ed21@news.povray.org>, "Mark Wagner"
That is what I finally implemented it as. It took me a while to figure
out how to allow rgb, red, green, and blue to be used, though.
> when there doesn't need to be one?
It looks to me like that was just a stopgap measure...it looks like you
could implement it mostly by adding code to the Insert_Spline_Entry()
function.
I don't have any experience with growing dynamically allocated
arrays...I tend to use linked lists for everything.
> >syntax.
> problems with the spline syntax as it is.
I think could get it working with functions, but I have no idea how to
do the array like syntax...
INT spline_points(SPLINE_IDENT) Retrieves the number of points in the
spline.
EXPRESS get_spline_point(INT_INDEX) Returns the corresponding point on
the spline.
BTW, I implemented the SPLINE_IDENT(T, TYPE) syntax. You can now do
#declare Spl = spline {linear_spline ...}
#declare Val1 = Spl(T);
#declare Val2 = Spl(T, cubic_spline);
#declare Val3 = Spl(T, quadratic_spline);
I will send you the code soon.
Date: 5 Nov 2000 09:20:30
Message: <chrishuff-8FE4AE.09234205112000@news.povray.org>
In article <chrishuff-AE6B1C.09490803112000@news.povray.org>, Chris
I've found a couple more bugs, for example, Insert_Spline_Entry() took a
vector and tried to pass 5 float values through it. I changed that to an
expression... However, it might be a good idea to have separate
Insert_Spline_Vector_Entry() and maybe Insert_Spline_Float_Entry()
functions for ease of use in other code.
I also cleaned up a lot of the code, mostly just reformatting it, but
partly rewriting some functions. And I fixed some typos in the
comments...:-)
I plan on doing more, but I thought you would like to have what I have
done so far. I hope this is helpful in the work you are doing.
The spline code changes are here:
http://homepage.mac.com/chrishuff/mpovplus/splines.zip
I will upload the curves post_process patch soon.
Date: 5 Nov 2000 11:56:55
Message: <3A059156.6903634A@enst.fr>
	I think it depends on what the spline does exactly: is it the same as:
rgb SPLINE, SPLINE, SPLINE
	Or does it only change the brightness? A good thing to add too:
spline-based manipulations on hue and saturation...
		Jérôme
********************************* Jérôme M. BERGER
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 5 Nov 2000 12:35:37
Message: <chrishuff-2DD880.12353405112000@news.povray.org>
In article <3A059156.6903634A@enst.fr>, Jérôme M. Berger
It uses the same spline to adjust each channel. The current value of the
channel is taken as the "t" value of the spline, and the result of the
spline is used as the new value for the channel.
> A good thing to add too: spline-based manipulations on hue and
> saturation...
Not as a special feature of the spline patch...just use a rgb_to_hsl
filter, then use the ordinary curves filter to adjust hue or saturation,
then use hsl_to_rgb to get the corrected image back. More flexible, less
complicated, and you can combine it with other things to get special
effects. And I *am* planning to write these conversion filters...as soon
as I figure out the math. I've found lots of information about
converting between color spaces, but little or nothing about the actual
equations used to convert between rgb and hsl. That, or I'm just not
recognizing it when I see it...
Date: 5 Nov 2000 21:40:13
Message: <chrishuff-D7CD9A.21401305112000@news.povray.org>
In article <chrishuff-2DD880.12353405112000@news.povray.org>, Chris
> ...as soon as I figure out the math. I've found lots of information
> about converting between color spaces, but little or nothing about
> the actual equations used to convert between rgb and hsl. That, or
> I'm just not recognizing it when I see it...
Never mind, I just came across a couple files Nathan sent me which
should do everything that I need. I had set them aside and completely
forgotten about them...
Date: 6 Nov 2000 00:46:07
Message: <3a06459f$1@news.povray.org>
>function.
I've already got the code for this written -- it's just a matter of copying
it from my personal version to SkyPOV.
>> >syntax.
>spline.
>the spline.
I think that, usage-wise, it would be better to use the array syntax.  This
would allow points to be changed and read using a single syntax.
Thanks!
Subject: color definition (Re: Announce: SkyPOV 0.1)
Date: 6 Nov 2000 04:15:53
Message: <3a0676c9@news.povray.org>
> on the first form):
don't you like pov schema for color definition ?
curves {red RED_SPLINE green GREEN_SPLINE blue BLUE_SPLINE}
ok.
curves {rgb GRAY_SPLINE}
ABX
Subject: Re: color definition (Re: Announce: SkyPOV 0.1)
Date: 6 Nov 2000 07:04:15
Message: <chrishuff-44E1AE.07041506112000@news.povray.org>
In article <3a0676c9@news.povray.org>, "Wlodzimierz ABX Skiba"
> > on the first form):
Uh, POV doesn't let you specify colors with splines. And you don't
specify colors in the curves patch, it simply reuses the keywords as
names for color channels.
Some of those would be pretty easy to do, but they would just be
confusing...since you are not specifying a color. Would you like it
better if it required the "type" keyword before the type?
And anyway, the syntax I use is better suited for expansion to other
color spaces. I plan to allow other color spaces to be manipulated by
adding a filter to convert to those spaces, but a future version of the
curves patch may allow a shortcut for modifying those spaces. Your
syntax will cause confusion("I can modify red and green at the same
time, but not blue and saturation?").
Date: 6 Nov 2000 08:21:02
Message: <3a06b03e@news.povray.org>
yes, I know
but this could be useful - color curves like color_map
#declare Curve=curve{red Spline1 green Spline2 filter Spline3}
#declare Pigment=pigment{pattern color_map{curve Curve}}
therefore I thought about similiar syntax
this also allow extension to other color spaces I think
>color spaces.
but you put sign "=" between meaning of "all" and "gray"
is it true in other color spaces ?
>Your
it depends of implementation in your planned patch :-)
ABX
Date: 6 Nov 2000 16:40:15
Message: <chrishuff-3C7AB3.16401506112000@news.povray.org>
In article <3a06459f$1@news.povray.org>, "Mark Wagner"
> copying it from my personal version to SkyPOV.
>  This would allow points to be changed and read using a single
> syntax.
Arrays don't have any special syntax for insertion...and I don't think
reading the points with [] brackets will be very easy. As for changing
existing points...what would this do?
#declare Spl[2] = 0.4;
Would this set the t value of the third point to 0.4, or would it set
the x value? Also, this syntax would be a problem for using arrays of
splines.
I would suggest using functions for most of these:
Getting number of control points:
Reading a point:
FLOAT get_spline_t(SPLINE_IDENT, INDEX)
Returns the "distance" of the point at INDEX.
EXPRESS get_spline_value(SPLINE_IDENT, INDEX)
Returns the value of the spline at INDEX. I'm not sure how to handle
floats, vectors, and colors...maybe this function will work for all of
them.
Modifying a point:
set_spline_t(SPLINE_IDENT, INT_INDEX, FLOAT_NEW_T)
Changes the "distance" of the point at INDEX.
set_spline_value(SPLINE_IDENT, INT_INDEX, EXPRESS_VALUE)
Changes the value of the spline at INDEX. You can specify a float,
vector, color...
Adding a point should be possible already, it should work fine with the
modifications I made(mainly the fix to Copy_Spline()). Just do something
like this:
#declare Spline = spline {Spline NEW_POINTS}
And one other thing that should probably be taken care of: multiple
points with the same t value should probably not be allowed. New points
with the same t value of an existing point should replace that point. I
don't remember seeing anything about this in the source code...
Date: 6 Nov 2000 19:09:19
Message: <chrishuff-C07E8A.19092006112000@news.povray.org>
In article <3a06b03e@news.povray.org>, "Wlodzimierz ABX Skiba"
I have been thinking the possibility of something like this...I think it
might be useful. But I don't think it applies to the curves patch...
No, it won't. See explanation below.
The "=" operator isn't used in this patch...I don't know what you mean.
> >Your
No, it doesn't. For example, you can't manipulate red and hue
simultaneously, you can only manipulate one color space at a time. This
is because saturation and hue affect red, green, and blue, and the same
goes for the reverse. My syntax will allow the addition of hsl, hue and
saturation modes, yours won't, at least not in a way that makes sense.
However, those shouldn't be necessary anyway, since you can just use
other conversion filters before and after the curves filter to get the
same result. So we are back to whether or not to use the color syntax
for splines.
What exactly is deficient in the syntax I chose? Why do you think
specifying splines representing color channel curves with a color-like
syntax is a better idea than specifying a channel and a spline to go
with it?
Date: 7 Nov 2000 00:43:56
Message: <3a07969c@news.povray.org>
Update: I implemented it today.  For unknown reasons, POV_REALLOC doesn't
work properly for this.  I'm using Borland C++ Builder 4.0, if that makes
any difference.
>> syntax.
The obvious fix would be to do something like
#declare Spl[2].x = 0.4; // Sets the x value at the fourth item
#declare Spl[2].y = 0.4; // Sets the y value at the fourth item
#declare Spl[2].z = 0.4; // Sets the z value at the fourth item
#declare Spl[2].red = 0.4; // Sets the red value at the fourth item (same as
.x)
#declare Spl[2].green = 0.4; // Sets the green value at the fourth item
(same as .y)
#declare Spl[2].blue = 0.4; // Sets the blue value at the fourth item (same
as .z)
#declare Spl[2].filter = 0.4; // Sets the filter value at the fourth item
#declare Spl[2].transmit = 0.4; // Sets the transmit value at the fourth
item
#declare Spl[2].t = 0.4; // Sets the t value
Arrays of splines would be treated as multi-dimensional arrays, with the
last dimension being the spline index.
>like this:
It does.
The source code doesn't do anything about this right now.  I'll add that to
my list of things to do.
On the lines of splines and the problems with them:
1) Parse_Spline() will accept "quadratic_spline", but quadratic splines does
not exist.  They are treated as cubic splines.
2) Cubic interpolation is not done properly.  It appears that the "cubic
interpolation" is actually done by averaging two quadratic interpolations of
the spline data.  Fixing this will result in minor changes to all scenes
that use cubic splines.
Mark
Date: 7 Nov 2000 04:48:23
Message: <3a07cfe7@news.povray.org>
my english may be poor sometimes :-(
I mean that in your first post you don't know what is better
name - "all" or "gray" - but you don't precise what "all" should
represent - if the same as gray than what should be used for
all curves in other color spaces ?
>> >Your
This
same
yes I know this
> for splines.
> with it?
I don't think that your syntax is wrong
but I think that there should be first discussion
about implement other color spaces in all ways where old colors
can be use, than how to extend it to use curves and than
use this curves syntax in post-processes
your way is to implement it to one usage but
perhaps it is hardly to extend in the future for rest of pov syntax
perhaps:
COLOR_DEFINITION:
  color SPACE_NAME value_for_all | SPACE_COORDINATES
SPACE_NAME:
  rgb | hsl | hue | etc ...
SPACE_COORDINATES:
  vector | COORDINATES_SPECIFICATION
COORDINATES_SPECIFICATION:
  COORDINATE_IN_SPACE value_of_coordinate
  [COORDINATE_IN_SPACE value_of_coordinate ...]
COORDINATE_IN_SPACE:
  red | green | blue | cyan | magenta | filter | transmit | saturation
as you see this is nearly the same like old definition
and not to much to change in old scripts
COLOR_MAP:
  color_map {
    curve { SPACE_NAME curve_identifier } /* for all coordinates in
space */
    curve { SPACE_NAME
      COORDINATE_IN_SPACE curve_identifier
      [COORDINATE_IN_SPACE value_of coordinate ...]
    } /* for specification */
i'm not specialist, forgive me than if i'm wrong with something
and what's more important - since year I slowly but carefully
read archiv of news.povray.org, but still I have
46205 messages to read - perhaps there is discussion of our problem
ABX
Date: 7 Nov 2000 14:58:58
Message: <3a085f02$1@news.povray.org>
> my  control, it is currently available only as source code.  If I can
> find  time, I will upload a Windows binary tomorrow.  If I can't, it
> will be  available next Tuesday.
  Out of curiousity, have you looked at possibly just integrating your
changes into MegaPOV for a 0.7 release?  I'm only asking, becouse with
all of the 'sub releases' of different things, it could get confusing
over time..  This really also applies for 'MegaPOVPlus' as well.
Date: 7 Nov 2000 15:28:23
Message: <chrishuff-AF79D1.15282507112000@news.povray.org>
In article <3a07969c@news.povray.org>, "Mark Wagner"
> any difference.
I've never used POV_REALLOC()(or realloc())...maybe it is a bug in the
pov_realloc() function. Did you get it working with realloc(), or did
you try some other way?
I think f and t are already reserved for filter and transmit...you would
have to use something else.
This probably would work...it certainly looks simpler and cleaner than
my syntax, though a bit less clear in some rare circumstances.
How about a similar syntax for getting textures, pigments, colors, etc.
from blend maps?
> "cubic interpolation" is actually done by averaging two quadratic
> interpolations of the spline data.  Fixing this will result in minor
> changes to all scenes that use cubic splines.
These definitely need fixing...
Hmm, another thing that would be nice is a larger assortment of spline
types. Catmull-rom, b-splines, etc...
Keep up the good work.
Date: 7 Nov 2000 15:38:11
Message: <chrishuff-DB1E2A.15381407112000@news.povray.org>
In article <3a085f02$1@news.povray.org>, "Thomas Charron"
SkyPOV and MegaPOVPlus are based on MegaPOV, so their features are
already integrated into MegaPOV. And whether or not features in them get
into the next release of MegaPOV depends mostly on Nathan(who is also
busy working on POV 3.5) and the Smellenberghs...I just use MegaPOVPlus
as a way to develop my patches to a point where they are complete enough
to be added to MegaPOV and to play around with patches by other people
before they have a chance to get into MegaPOV.
Date: 7 Nov 2000 16:03:33
Message: <chrishuff-B53C1B.16033407112000@news.povray.org>
In article <3a07cfe7@news.povray.org>, "Wlodzimierz ABX Skiba"
Oh, I see what you mean, "all" will mean something different in other
color spaces...I will probably change it to use "rgb" instead of "all".
> > > >Your syntax will cause confusion("I can modify red and green at
> > > >the same time, but not blue and saturation?").
> > simultaneously... yes I know this
But your syntax would allow something like:
red SPLINE hue SPLINE
which doesn't make sense.
(interesting stuff about color syntax)
I have been thinking about new ways of specifying colors(which I still
think is a separate issue from the curves filter), but I would use a
slightly different syntax:
color           (tells POV a color is coming)
rgb|hsl|cmy|    (color space name)
< c1, c2, c3>   (A 3 component vector specifying the color values)
Keywords red, green, and blue wouldn't be used any more, at least not
for specifying colors. You wouldn't need hue, saturation, magenta,
yellow, etc. either. This would be less backwards compatible, but
simpler and better for future syntax. It would be easier for new users
to learn, and doesn't have the problem of someone specifying something
like "red Something hue SomethingElse".
Filter and transmit wouldn't be specified as part of the color, they
would be part of a separate "transparency" block in the pigment. Layered
textures would also have a way to specify different transparency effects
that would only affect the texture layering.
Splines would be able to directly replace color maps:
    PATTERN
    color_spline rgb|hsl|cmy spline {...}
    color_spline rgb|hsl|cmy spline {...}, spline {...}, spline {...}
This is something that should be easy to add while keeping the current
syntax.
Or maybe just use one spline that interpolates between colors...that
would be very easy to do, since splines can already interpolate between
5-dimensional vectors. However, it would make modifying one color a bit
more difficult.
Date: 8 Nov 2000 00:53:31
Message: <3a08ea5b$1@news.povray.org>
POV_REALLOC() is just a wrapper for pov_realloc(), which itself calls
realloc().  My solution is to call POV_MALLOC() to create a larger array,
followed by memcpy() to copy the old array to the new, and POV_FREE() to get
rid of the old array.
As of POV 3.1g, t is only used for referring to the fourth component of a
four-dimensional vector.  Thus, it is available for using here, since all
splines are technically 5-dimensional vectors.
>from blend maps?
Possible.  I don't know how difficult it will be to implement.
I'll do so if someone can point out some references for these, preferably
with C code examples.  I'm having enough trouble trying to decipher the
cryptic pseudo-code from my Numerical Analysis textbook to want to deal with
Fortran.
Mark
Date: 8 Nov 2000 00:57:06
Message: <3a08eb32@news.povray.org>
This is the same thing I'm doing with SkyPOV.
Mark
Date: 8 Nov 2000 01:12:54
Message: <3A08EF4A.796C7CCA@aetec.ee>
> Fortran.
( NB! Shameless self-promotion follows ;o)
If You can read _my_ C code, then download source code for POVMan and
look file shdrexec.c, it contains implementation for Catmull-Rom,
Hermite, Bezier and B-splines.
(Or alternatively mail me and I'll send You only this file...)
HTH
Date: 8 Nov 2000 06:02:24
Message: <3A0932BE.240AA5C@enst.fr>
	Why not? Actually, red SOMETHING hue SOMETHING does make sense: first
work in rgb color-space and change red without touching green and blue,
then work in hsl and change hue without touching saturation or
brightness...
	This would make for an easy way to get the grayscale equivalent of a
color for example (color rgb <whatever> saturation 0) or other effects
of the kind...
	I prefer to have the color and transparency defined together (the way
they are now) since they usually follow the same pattern. Needing to
specify the pattern twice would be redundant, more difficult and
error-prone...
	Just my 2 copecks,
		Jérôme
Date: 8 Nov 2000 16:28:36
Message: <chrishuff-30B854.16283908112000@news.povray.org>
In article <3a08ea5b$1@news.povray.org>, "Mark Wagner"
> realloc().
But it isn't a direct call to realloc(). There is still room for a bug
in there...it seems strange that you couldn't get it to work.
> to get rid of the old array.
I thought realloc() was supposed to make it so you didn't have to do
this. :-(
I was wondering if calling realloc() directly might bypass something
POV's functions are breaking.
> preferably with C code examples.  I'm having enough trouble trying to
> decipher the cryptic pseudo-code from my Numerical Analysis textbook
> to want to deal with Fortran.
Hmm, my copy of "3D Graphics Programming" has some explanations of
cubic, Hermite, and Bezier splines...not that I can make much sense of
it. Not much in the way of examples either...mostly just the math.
Date: 8 Nov 2000 16:48:32
Message: <chrishuff-B36316.16483608112000@news.povray.org>
In article <3A0### [at] enstfr>, Jérôme M. Berger
> brightness...
But what would the resulting vector be? Would it be a rgb vector, or a
hsl, etc...
#declare Color = color red 0.6 hue 0.75;
Is Color.x red or hue? Is Color.y green or saturation?
"color rgb" should only accept red, green, and blue...
> of the kind...
I think this would be better done with color conversion functions, not
the color specification. The idea is that you pick a color space and
then set each component, when you try to set a component that isn't part
of the color space things get messy. To get the grayscale of a color, it
would be something like:
#declare Color = color rgb rgb_to_hsl(<whatever>).z;
> error-prone...
It could be done so you don't have to specify the pattern twice, and it
would give much more flexibility. And I never have understood why
transparency was considered part of the color...the only explanation I
can think of is that it developed from the use of alpha channels in
images. It seems more of an interior feature to me, or a separate
texture attribute.
And they usually follow the same pattern because it would be very
difficult (impossible?) to get them to do otherwise with the current
syntax. If it was easily possible to do it differently that might not be
the case.
Date: 8 Nov 2000 17:45:44
Message: <chrishuff-DBF9D8.17454808112000@news.povray.org>
In article <3A01D3E8.8C98EF92@unforgettable.com>,
I plan on including these features in MegaPOVPlus, but probably not
until the next version of SkyPOV is released.
Date: 9 Nov 2000 01:01:28
Message: <3a0a3db8$1@news.povray.org>
The next version of SkyPOV will be released when I've managed to get the
splines working properly.
Mark
Date: 9 Nov 2000 01:26:35
Message: <3a0a439b@news.povray.org>
>this. :-(
There's a very good reason for using POV_REALLOC etc.: garbage tracking and
collection.  By using the POV_*ALLOC functions, it is much easier to track
down memory leaks.
I'll see what Vahur Krouverk's code is like for this.
Mark
Date: 9 Nov 2000 04:50:25
Message: <3A0A735E.A48E843C@tapasmail.net>
> hsl, etc...
	Whatever you do, you'll need a unique internal representation (which
should probably be rgb to avoid breaking something elsewhere in the
code). If Color.(x/y/z) is to make any sense, it would be with relation
to this internal representation. I personnally would favor using
Color.red or Color.hue...
	This makes for more things to type and isn't any clearer or easy to
understand. Moreover, if you need to remember in wich space you defined
each color, you're in for a lot of bugs in your scenes ("Why the h*** is
that sphere white instead of blue???")
> texture attribute.
> the case.
	Maybe, but OTOH you don't need to specify a color where the object is
fully transparent, so their patterns are related. I've never felt the
need to specify transparency independently from color...
		Jérôme
Date: 9 Nov 2000 07:12:59
Message: <chrishuff-EC4E9A.07130309112000@news.povray.org>
In article <3a0a439b@news.povray.org>, "Mark Wagner"
> tracking and collection.  By using the POV_*ALLOC functions, it is
> much easier to track down memory leaks.
But that won't help you figure out if there is a bug in POV_REALLOC().
I can understand working around it using the POV_*() functions, but I
was talking about figuring out where the problem was. Oh, well...there
are a couple places in my work with glows that could use POV_REALLOC(),
I will try to figure it out myself...
And I'll poke around in the "other" spline patch...I think it had
something like a "rational bezier spline".
Date: 9 Nov 2000 07:16:08
Message: <chrishuff-3C31E7.07161309112000@news.povray.org>
In article <3a0a3db8$1@news.povray.org>, "Mark Wagner"
No hurry. :-)
I have plenty of other coding stuff to do(I think I finally got glows to
attach to objects properly!), and plenty of other stuff that I *should*
do...MP+ 0.6a mod 0.1 will have some other new stuff.
Date: 9 Nov 2000 21:33:35
Message: <chrishuff-608913.21334109112000@news.povray.org>
In article <3A0A735E.A48E843C@tapasmail.net>, Jérôme M. Berger
Simplest case: a multicolored transparent ball which is evenly
transparent and has a big color_map. You decide you want to change the
amount of transparency...you have to change every color in the
color_map. If you had it specified in a separate block, you would only
have to change one value. It would also make specifying transparence for
image_maps a lot easier.
It becomes an even better idea when you add blurred transparency, etc.
Other programs do it because they often use image maps that use the
alpha channel to define transparency...but does *tranparency* really
belong in a *color*? Especially in POV, where image maps are relatively
rarely used.
Date: 9 Nov 2000 23:16:10
Message: <3a0b768a@news.povray.org>
Mark, did you ever post a Windows binary? Sorry, but my newsgroup time is
limited and this thread is full of messages...
Grim
