POV-Ray : Newsgroups : povray.advanced-users : Fishtail math ><}}}*> Server Time
5 Nov 2026 21:12:34 EST (-0500)
  Fishtail math ><}}}*> (Message 1 to 26 of 26)
Subject: Fishtail math ><}}}*>
Date: 19 Nov 1999 05:08:04
Message: <8E83722CAseed7@212.120.113.81>
I'm trying to animate the tail of an ASCII-fish. I figured out how to do it
the long way but I'm looking for a short cut.
Concider eleven spheres on a string from the origin to <10,0>.
1. rotate the whole string 5° around the origin.
2. leave the first sphere in its position. rotate the whole string 5°
around the current position of the second sphere.
3. leave the first and second sphere in its position. rotate the whole
string 5° around the current position of the third sphere.
10. rotate the eleventh sphere 5° around the current position of the tenth
sphere.
Now, is there a direct way to calculate the position of a sphere, without
going through the above loop. What will the position of sphere 7 be when
the rotation angle is 5°?
Ingo
Subject: Re: Fishtail math ><}}}*>
Date: 19 Nov 1999 10:55:58
Message: <gXE1OEmQIwaKCy6cD1iiNG2nHd=4@4ax.com>
>sphere.
>Ingo
Will you please explain how you will animate this? Will you change the
value of  5° according to clock, or will you apply steps 1 to
11*clock?
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 11:20:07
Message: <383578A0.390793C0@xs4all.nl>
> do it
> tenth
> sphere.
> without
> when
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
I don't know if I understand your method exactly but I did a similar
thing with a reasonable result using sin/cos-functions. This gives a
nice curve. The position of each sphere is based on its place in the
string _plus_ a clock value. This way the first sphere will move also.
This is easy to avoid by moving the whole string relative to the
translation of this first sphere. Sounds far more complicated then it
actually is 8)
Groeten!
Remco
Date: 19 Nov 1999 11:33:05
Message: <dXs1OOq1xINLNt=bgKiRd2qGA45t@4ax.com>
On Fri, 19 Nov 1999 17:19:44 +0100, Remco de Korte
>actually is 8)
>Groeten!
>Remco
But will this keep the distance between two consequitive spheres
constant? I don't think so, and unless your fish is made of natural
rubber, it's gonna hurt big time :)
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 13:22:23
Message: <8E83C37DBseed7@212.120.113.81>
>11*clock?
I'll vary the angle (1 - 10°) according to the clock. Not steps 1 to
11*clock.
Ingo
Date: 19 Nov 1999 13:23:47
Message: <8E83CA50Eseed7@212.120.113.81>
>>thing with a reasonable result using sin/cos-functions. ........
Exactly the reason why I don't want to use the sin / cos method.
Ingo
Date: 19 Nov 1999 15:45:52
Message: <wLY1OMbzDPA1TyjiGtT0qa19CQA+@4ax.com>
>>11*clock?
>11*clock.
>Ingo
Okay, I'll try to put up a #while loop to do it.
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 15:48:30
Message: <3835B78C.EEB1C568@xs4all.nl>
> Ingo
How much stress will that cause?
And you're not telling me that you've never had to stretch while moving
haven't you?
Anyway, it's probably bad physics for a robot, but it works (for me) in
an image.
If the distance between sphere's really would be the problem you could
easily change your calculations to provide for that. That wouldn't
change the fact that if you had a really 3D-body there still would be
some stretching (inside vs outside of curve).
Remco
Date: 19 Nov 1999 16:16:44
Message: <8E83E29AAseed7@212.120.113.81>
>haven't you?
>an image.
That's true, but it's like YKYHBRTLW You create a motor using every part
..... even the ones that don't show ..... just for authenticity.
Ingo
Date: 19 Nov 1999 16:58:14
Message: <dMc1OCY1+UrtvmpLUIKrpJRSdMCZ@4ax.com>
>>11*clock?
>11*clock.
>Ingo
//try this
#declare Pos=array[11]
#declare i=0;
#while (i<11) #declare Pos[i]=<i,0,0>; #declare i=i+1; #end
#declare i=1;
#while (i<11)
  #declare Pos[i]=vrotate((Pos[i]-Pos[i-1]),<0,0,10*clock>)+Pos[i-1];
  #declare i=i+1;
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 17:52:36
Message: <8E83FDBF4seed7@212.120.113.81>
Peter Popov wrote:
>//try this
>#declare i=0;
>#declare i=1;
>#while (i<11)
>  #declare i=i+1;
>#end
No, I'm afraid that's not what I'm looking for. What I expected to see is
the spheres arranged in a arc, about one quarter of a circle.
mmm, all spheres end up on a circle, the length of the arcsegment between
two spheres is known (1 in this case). The angle between the two vectors
from the spheres to the center of the circle = 10° (when clock=1).The
circle will always go through the origin, where the first sphere is.
With this, I think the radius and centerposition of the circle can be
calculated. Once this circle is known, take the distance frome any sphere
on the x-axis to the origin. Take an arcsegment of the circle with the same
length and put the sphere there.
Would it work? I'll sleep over this and try if I can figure it out
tomorrow.
Thanks Peter for your effort.
Ingo
Date: 19 Nov 1999 19:04:52
Message: <4OM1ONJO3=BUzyt4OW6oH853Ryf2@4ax.com>
>tomorrow.
>Ingo
I got your intentions wrong. This should do what you want, as
described in your original post.
#declare i=0;
#declare i=0;
#while (i<10)
  #declare j=i+1;
  #while (j<11)
    #declare Pos[i]=
    vrotate((Pos[j]-Pos[i]),<0,0,10*clock>)+Pos[i];
    #declare j=j+1;
  #declare i=i+1;
If it doesn't, I'll look at it tomorrow.
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 19:38:49
Message: <3835ED87.8C910B8E@xs4all.nl>
> moving
> >haven't you?
> in
> >an image.
> part
> Ingo
I was obviously missing the point.
I would suggest a recursive macro.
Remco
Date: 20 Nov 1999 04:13:41
Message: <8E8465C1Eseed7@212.120.113.81>
>#declare i=0;
>#declare i=0;
>#while (i<10)
>  #declare j=i+1;
>  #while (j<11)
>    #declare Pos[i]=
>    #declare j=j+1;
>  #end
>  #declare i=i+1;
>#end
Sorry but no, ten spheres end up at <10,0.9,0> and one at <10,0,0>.
Ingo
Date: 20 Nov 1999 07:21:18
Message: <38369190.12D9F64F@my-dejanews.com>
I think there is a more serious problem with the sin cos solution.
The sin cos solution prevents non unique positions along the x axis.  Many
kinds of aquatic animals, maybe some fish, would bend their bodies around so
much that there might be two points of the body at some given x.
Remco de Korte wrote:
> > do it
> > tenth
> > sphere.
> > without
> > when
> > Ingo
> actually is 8)
> Groeten!
> Remco
Date: 20 Nov 1999 07:43:44
Message: <8E8487412seed7@212.120.113.81>
>between two spheres is known (1 in this case)........
Got it, I think:
#declare i=0;
#while (i<11)
   #declare i=i+1;
#declare Angle   = radians(10*clock);
#declare Length  = Pos[1].x-Pos[0].x;
#declare Radius  = Length/Angle;
#declare Lcord   = (Radius/sin(0.5*pi-(Angle/2)))*sin(Angle);
#declare Ccenter = <-0.5*Lcord, Radius, 0>;
#declare i=0;
#while (i<11)
   #if (Pos[i].x=0)
      // do nothing
   #else
      #declare L= Pos[i].x;
      #declare Alpha= L/Radius;
      #declare Pos[i]=
(vrotate(<0,-radius,0>,<0,0,degrees(Alpha)>))+Ccenter;
   #declare i=i+1;
#declare i=0;
#while (i<11)
   sphere{ Pos[i],0.2 pigment {rgb <1,0,0>}}
   #declare i=i+1;
Ingo
Date: 20 Nov 1999 07:48:09
Message: <38369889@news.povray.org>
This just crashed my UVPOV during the creation of the bounding slabs. It
said something about Reallocing Finite to 33...
Date: 20 Nov 1999 08:04:52
Message: <8E84859B8seed7@212.120.113.81>
Ooops, posted it a bit too ethousiastic.
Add after the #declare Angle statement
#if (Angle !=0)
   and before the last #declare i=0
Also the x-coordinate value of Ccenter seems to be not ok yet.
Ingo
Date: 20 Nov 1999 08:52:48
Message: <3836A79B.6502BDE8@xs4all.nl>
> Many
> around so
I don't understand. This is just the thing that makes sin or cos a
reasonable choice, I thought.
I'm obviously missing something very important here. The only thing that
I have to support my choice is a working animation that does what it
should do for me, but, admittedly, is probably not what a hardcore
pov-er would consider realistic.
Remco
Date: 20 Nov 1999 09:27:18
Message: <8E849EBDBseed7@212.120.113.81>
>> Many
>> around so
>reasonable choice, I thought.......
For a simple fishtail you're right. But sometimes it's a sport doing thing
a certain way. Run a 60 frame animation of the below scene (~5 minutes), it
shows what Greg means.
#version 3.1;
global_settings {assumed_gamma 1.0}
light_source {
   < 500, 500,-500>
   rgb 1
   location  <4, 0, -10>
   look_at   <4, 0.0,0.0>
   angle 90
// generates number between min & max
// based on Value between 0, 1.
#macro Vmm(Min,Max,Value)
   (Min+((Max-Min)*Value))
#end //macro
#declare Pos=array[150]
#declare i=0;
#while (i<150)
   #declare Pos[i]=<i/10,0,0>;
   #declare i=i+1;
#declare Angle   = radians(Vmm(-4,4,clock));
#if (Angle !=0)
   #declare Ccenter = <0, Radius, 0>;
   #declare i=0;
   #while (i<150)
      #if (Pos[i].x=0)
         // do nothing
      #else
         #declare Pos[i]=
(vrotate(<0,-Radius,0>,<0,0,degrees(Alpha)>))+Ccenter;
      #declare i=i+1;
#declare i=0;
#while (i<150)
   sphere{ Pos[i],0.3 pigment {rgb <1,0,0>}}
   #declare i=i+1;
Ingo
Date: 20 Nov 1999 11:35:50
Message: <3836CDD1.6CEE9DA6@xs4all.nl>
> axis.
> >> Many
> >> around so
> thing
> minutes), it
> #version 3.1;
> light_source {
>    < 500, 500,-500>
>    rgb 1
> camera {
>    angle 90
> #end //macro
> #declare i=0;
> #while (i<150)
>    #declare i=i+1;
> #end
> #if (Angle !=0)
>    #declare i=0;
>    #while (i<150)
>       #if (Pos[i].x=0)
>          // do nothing
>       #else
>          #declare Pos[i]=
>       #end
>       #declare i=i+1;
>    #end
> #end
> #declare i=0;
> #while (i<150)
>    #declare i=i+1;
> #end
> Ingo
I tried rendering it but I still don't understand.
I admit this doesn't look good, but I didn't know the exact settings for
the animation(clock-values). What I did see was that there's no sin or
cos in your source so that doesn't clarify it to me either.
I'm sorry.
Still, it's not my problem 8)
Ciao!
Remco
Date: 20 Nov 1999 11:59:26
Message: <3836D35A.4D3714B8@xs4all.nl>
Just to make sure I totally misunderstand, render this:
#version 3.1;
light_source {
   < 500, 500,-500>
   rgb 1
   angle 90
#declare yy_off=sin(clock*10*pi/5);
#declare xx=0; #while (xx<=10)
  #declare yy=sin((xx+clock*10)*pi/5)-yy_off;
  #sphere{<xx,yy,0>,.5 pigment{rgb<1,0,0>}}
#declare xx=xx+1;#end
with clock going from 0 to 1 (the number of frames is up to you, I tried
20). Apart from the fact that the distance between the spheres isn't
constant (which is easy to fix) what's wrong with it? I guess this is
not what you're looking for but I don't see what is.
And as for Greg's remark ("The sin cos solution prevents non unique
positions along the x axis.") this shows that there's no problem there.
I didn't say you had to use sin AND cos, just one of them is enough, or
use a clever combination to get more interesting wave-forms (I have a
little program that can illustrate that).
Bye,
Remco
Date: 20 Nov 1999 13:09:35
Message: <8E84C0E1Eseed7@212.120.113.81>
0 to 1.
I think we're talking a bit "langs elkaar heen".
My point with the anim was to illustrate that you can have non-unique x-
values because there are no sin / cos functions.
>I'm sorry.
And I've solved mine :)
There's noting wrong. My main problem was the non constant distances and
that's solved.
SinCos? I've seen it on your page, not tried it yet, but I will.
Thank you, and Peter, for your comments. It helped me solve my problem.
Tsjuus,
Ingo
Date: 20 Nov 1999 14:04:28
Message: <3836F0A7.F9D2B0D4@xs4all.nl>
> for
> 0 to 1.
> x-
Okidoki, and my point was that using sin or cos you can do everything
you want 8)
(as a matter of fact, at school I refused to give any attention to sin
or cos and now it is the part of math I use the most)
Remco
Date: 20 Nov 1999 15:05:09
Message: <u=w2OEGxFsONYadZI3BIQp3IwMJt@4ax.com>
>>#declare i=0;
>>#declare i=0;
>>#while (i<10)
>>  #declare j=i+1;
>>  #while (j<11)
>>    #declare Pos[i]=
>>    #declare j=j+1;
>>  #end
>>  #declare i=i+1;
>>#end
>Ingo
Sorry, that was a typo. it should read
#declare i=0; #while (i<11) #declare Pos[i]=<i,0,0>; #declare i=i+1;
#declare i=0;
#while (i<10)
  #declare j=i+1;
  #while (j<11)
    #declare Pos[j]=  // here was the typo
    vrotate((Pos[j]-Pos[i]),<0,0,10*sin(2*pi*clock)>)+Pos[i];
    //the previous line was modified to make a cyclic anim
    #declare j=j+1;
  #declare i=i+1;
I actually tested it this time :), and it worked.
Peter Popov
ICQ: 15002700
Date: 22 Nov 1999 16:20:40
Message: <3839B2F4.3D337102@my-dejanews.com>
Here's an example of use of the "non sin cos" solution.
Look at "Does a snake's tail move?" in p.b.a, an entry at 1/23/99.
I serially rotated part of the snake's tail relative to the rest of the
snake.  I used sin & cos to rotate the snake.  I did not use, however, sin
or cos to displace body segments a distance along a line normal to the
x-axis. Look at my code included therein......
> > for
> > 0 to 1.
> > x-
> you want 8)
> Remco
