Greetings !
I am trying to build official beta from this tarball:
povunix-v3.8.0-beta.2-src.tar.gz.
Build is successful, but on runtime I am getting following error:
Illegal instruction (core dumped).
I guess that by default 'configure' turns on support for modern
instructions, that my CPU is not supported, so what is the best way
to control them and avoid this error ?
My present environment is following:
Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Ubuntu 24.04.3 LTS
YB
hi,
yesbird wrote:
> Greetings !
> Ubuntu 24.04.3 LTS
> YB
I published build scripts once or twice, see link. write if further problems.
<news.povray.org/web.660c3b34a01057ea1686e436cde94f1%40news.povray.org>
regards, jr.
Thanks, jr, for the fast reply, I will try it, but this solution looks
like, a hack. I'd prefer 'official' method to control usage of advanced
CPU instructions, via config parameters.
Don't you know, if it's possible ?
YB
> like, a hack.
well, it is for WFP's "yuqk" fork :-).
unsure even what you mean. there are some bits of the source which are
"hand-optimised" for specific CPU types, but the detection & inclusion is
automatic.
either way, I've attached another "hack"[*] </grin>, a beta.2 build script.
[*] anyway, works. </shrug>
regards, jr.
Download 'povray.slackbuild.txt' (1 KB)
> automatic.
Unfortunately results is the same: "no result".
./unix/povray +i./scenes/advanced/biscuit.pov -f +d +p +v +w320 +h240
+a0.3 +L./include
make: *** [Makefile:1089: check] Illegal instruction (core dumped)
YB
>> automatic.
>> script.
> +a0.3 +L./include
> YB
There can be many causes for what you are seeing. Things you might try:
1) Download the latest yuqk tarball at:
https://news.povray.org/povray.binaries.programming/thread/%3C67eba626%40news.povray.org%3E/
Unpack it and run:
./configure -q COMPILED_BY="YB_yuqk" CXXFLAGS="-std=c++17"
make -j4
make check
The yuqk fork ships without any compiler optimizations during
./configure - aside from the cpu specific noise code where it has fixed
some 'gnu compiler broken' cpu detection code.
2) Both the default unix build and the build script jr provided use
-ffast-math. There are a number of flaky fails due recent compiler
changes to what -ffast-math does. Change that flag to: -fno-fast-math or
add the flag -fno-finite-math-only to your CXXFLAGS and try another build.
3) You can try a configure with the defines:
-DDISABLE_OPTIMIZED_NOISE_AVXFMA4 -DDISABLE_OPTIMIZED_NOISE_AVX2FMA3
-DISABLE_OPTIMIZED_NOISE_AVX
Which 'should' turn off any use of the cpu target specific hand
optimized code - but they might not turn off the dynamic cpu detection
code which runs ahead of the hand optimized code (I don't remember).
There is too a -DDISABLE_OPTIMIZED_NOISE_AVX_PORTABLE, but my memory is
fuzzy as to what that means - probably harmless to add it to those above.
4) At a terminal after a illegal instruction problem build, are you able
to run:
./unix/povray --help
If so, try each of:
touch bogus.pov; ./unix/povray bogus.pov -d +p
touch bogus.pov; ./unix/povray bogus.pov -d -p
touch bogus.pov; ./unix/povray bogus.pov -d +p -fn
Bill P.
Many thanks for such a detailed response, I will put these tips to my
'internal storage' ).
The .configure option that helps was '-disable-optimiz'.
Probably I was too lazy to run:
./configure --help
and examine output, instead of disturbing the community, sorry for
inconvenience.
YB
hi,
thanks !
@yesbird
good that you found a work-around.
regards, jr.
Yes, I did with the help of the community, but don't you think that
it would be better to turn off this optimization by default to
preserve other users from similar issues in future ?
YB
hi,
in light of yesbird asking whether optimisation should be turned off perhaps, I
think it would be beneficial if (at least) the build flags for default *NIX were
appended / updated to include the '-fno-finite-math-only'. can do ?
regards, jr.
