POV-Ray : Newsgroups : povray.advanced-users : 3.8.0-beta.2 - illegal instruction Server Time
10 Nov 2025 19:14:25 EST (-0500)
  3.8.0-beta.2 - illegal instruction (Message 11 to 11 of 11)
Subject: Re: 3.8.0-beta.2 - illegal instruction
Date: 10 Nov 2025 06:44:30
Message: <6911d01e$1@news.povray.org>
On 11/10/25 04:52, jr wrote:
> hi,
> William F Pokorny <ano### [at] anonymousorg> wrote:
>> 2) Both the default unix build and the build script jr provided use
>> -ffast-math. There are a number of flaky fails due recent compiler
>> changes to what -ffast-math does. Change that flag to: -fno-fast-math or
>> add the flag -fno-finite-math-only to your CXXFLAGS and try another build.
> in light of yesbird asking whether optimisation should be turned off perhaps, I
> think it would be beneficial if (at least) the build flags for default *NIX were
> appended / updated to include the '-fno-finite-math-only'.  can do ?
No(*), not easily.
It's true I did some github things a year or so ago to get bumped to a
developer with the idea I might do a few quick commits like this, but my
github upgrade from contributor to developer didn't go well. Best I
could tell, I ended up with developer permission to one hidden /
developer only fork / branch about which I know nothing.
None of the automated, github, build, check and release stuff is
currently working. I never understood that set up beyond checking
results of the auto-build-check fails. I have now not used github
itself, except for occasionally commenting on issues posted there, for
more than 5 years.
I cannot help with or support any windows specific development.
The suggested change should be made in at least 3 github branches. The
github support infrastructure is really nice when it's all working - but
even then, the simplest change takes non-trivial 'git / github' time.
My Unix/Linux only yuqk fork is different. The Unix build system itself
is substantially different. I don't even have the --disable-optimiz
configure option YB used(**) to build on his machine, for example.
Lastly, of late, real life is leaving me with much less time for my
POV-Ray hobby :-(.
Bill P.
(*) - You're likely guessing correctly that YB's core issue comes down
to the -ffast-math changes. The --disable-optimize option almost
certainly turns off fast math.
(**) - Completely non-optimized POV-Ray builds are slow. (Though, it is
a workaround for the gnu compiler optimizations breaking the dynamic cpu
detection code issue (fixed in yuqk no matter the compiler optimization
level))
