POV-Ray : Newsgroups : povray.advanced-users : Vertex colors rendering Server Time
10 Nov 2025 13:17:45 EST (-0500)
  Vertex colors rendering (Message 1 to 8 of 8)
Subject: Vertex colors rendering
Date: 29 Sep 2025 20:39:08
Message: <68db26ac@news.povray.org>
Working on file converter, I am importing vertex colors from FBX,
but cant figure out why POV-Ray rendering is so much different from
ZBrush. Maybe there is a way to control color distribution and
smoothness ?
Please find images and scene in attachment.
YB
Download 'cube_vc.inc.txt' (2 KB) Download 'scene.png' (29 KB) Download 'scene.pov.txt' (3 KB) Download 'zb.png' (402 KB)
Preview of image 'scene.png'
Preview of image 'zb.png'
Subject: Re: Vertex colors rendering
Date: 29 Sep 2025 21:25:00
Message: <web.68db308787a1b5a91f9dae3025979125@news.povray.org>
> smoothness ?
> YB
You might not want to color by vertex.
Maybe color the entire cube with a gradient and use blend_mode.
https://wiki.povray.org/content/Reference:Pigment_Map
That's all I have - for the moment.
- BW
Date: 29 Sep 2025 21:40:00
Message: <web.68db340187a1b5a91f9dae3025979125@news.povray.org>
> > smoothness ?
> > YB
> - BW
#version 3.8;
global_settings {assumed_gamma 1.0}
#include "functions.inc"
 location <0, 0, -20>
 look_at <0, 0, 0>
 up y
 sky y
sky_sphere {pigment {rgb 1}}
light_source {<0, 50, -50> rgb 1}
box {-5, 5
  gradient x
  pigment_map {
   blend_mode 0 // or 3
   [0, rgb y]
   [0.5, rgb 1]
   [1, rgb z]
  scale sqrt (200)
  translate x*sqrt (200)/2
  rotate z*45
Download 'yesbirdcolorcube.png' (29 KB)
Preview of image 'yesbirdcolorcube.png'
Date: 29 Sep 2025 21:55:00
Message: <web.68db383c87a1b5a91f9dae3025979125@news.povray.org>
OK - I think that also maybe the colors for your vertices are done wrong.
Make your top left and bottom right four vertices white
top right two vertices blue
bottom left two vertices green
#declare model = mesh2 {
vertex_vectors {
  8,
  <-0.20000000298023224,0.20000000298023224,0.20000000298023224>, // 0 Left Top
Rear
  <0.20000000298023224,0.20000000298023224,0.20000000298023224>,  // 1 Right Top
Rear
  <0.20000000298023224,0.20000000298023224,-0.20000000298023224>, // 2 Right Top
Front
  <-0.20000000298023224,0.20000000298023224,-0.20000000298023224>, // 3 Left Top
Front
  <-0.20000000298023224,-0.20000000298023224,0.20000000298023224>, // 4 Left
Bottom Rear
  <0.20000000298023224,-0.20000000298023224,0.20000000298023224>, // 5 Right
Bottom Rear
  <0.20000000298023224,-0.20000000298023224,-0.20000000298023224>, // 6 Right
Bottom Front
  <-0.20000000298023224,-0.20000000298023224,-0.20000000298023224>, // 7 Left
Bottom Front
texture_list {
 8,
 texture{pigment{rgb 1}}
 texture{pigment{rgb z}}
 texture{pigment{rgb y}}
face_indices {
  12,
  <0,1,2>, 0,1,2,
  <2,3,0>, 2,3,0,
  <4,5,1>, 4,5,1,
  <1,0,4>, 1,0,4,
  <5,6,2>, 5,6,2,
  <2,1,5>, 2,1,5,
  <6,7,3>, 6,7,3,
  <3,2,6>, 3,2,6,
  <7,4,0>, 7,4,0,
  <0,3,7>, 0,3,7,
  <7,6,5>, 7,6,5,
  <5,4,7>, 5,4,7,
Download 'cube_scene.png' (23 KB)
Preview of image 'cube_scene.png'
Date: 29 Sep 2025 22:10:31
Message: <68db3c17@news.povray.org>
Thanks for the suggestion, but I would like to keep vertex colors for
more complicated paintings, then trivial gradients.
Increasing number of polygons solves this problem and it looks fine
now, but don't you know how to make colors more saturated ?
Please, look at attachments.
YB
Download 'scene.png' (42 KB) Download 'scene.pov.txt' (4 KB) Download 'model.zip' (2003 KB)
Date: 29 Sep 2025 22:14:00
Message: <68db3ce8$1@news.povray.org>
Thanks, it looks much better !
I've checked it already, but see now any errors, will try again.
YB
Date: 29 Sep 2025 22:34:34
Message: <68db41ba@news.povray.org>
No, now I see that the problem is not in POV-Ray - 3js renders this
cube the same way (attached). Sorry for inconvenience.
YB
Download 'cube.png' (420 KB)
Preview of image 'cube.png'
Date: 7 Oct 2025 23:33:36
Message: <68e5db90@news.povray.org>
> smoothness ?
The reason was in gamma setting, attached image was rendered with
'assumed_gamma = 3'.
YB
Download 'studio.png' (44 KB)
Preview of image 'studio.png'
