I'm currently trying my hand at spherical heightfields, but I'm running into
strange problems.
I put a height map (DEM) of the moon around a sphere, based on these forum
https://news.povray.org/povray.binaries.images/thread/%3C38a2dc5b%40news.povray.org%3E
https://news.povray.org/povray.text.scene-files/thread/%3C38A037EB.504C1A6%40inapg.inra.fr%3E/?ttop=444549&toff=750
Everything looks good in the global view, but when I zoom in closer, radial
errors appear at the day-night boundary.
A higher resolution of the DEM does not change anything, and it works fine when
using bump_map.
But the larger the sphere (contained_by), the finer the disturbances?!
Unfortunately, I have no idea what the functions in the script do.
This one in particular puzzles me:
x*x+y*y+z*z + 0.1 - hftext(x,y,z).y * 0.03
Can someone help me with that?
Is there a reasonable tutorial that explains the working of user-defined
functions well?
Or does anyone find the bug in the script that causes the glitches?
doesnt helps me to understand the stuff:
https://www.povray.org/documentation/view/3.6.2/231/
My code used, greatly simplified:
#declare hftext = function {
image_map {
png "moon_dem.png"
map_type 1
#local mResult = isosurface {
function {
x*x+y*y+z*z + 0.1 -
contained_by {
sphere {0,1}
max_gradient 10
threshold 0.95
//threshold 2
color rgb <0.3, 0.3, 0.3>
Thanks,
Martin
Download 'ma_po_error_02_without_sf_small.png' (457 KB)
Preview of image 'ma_po_error_02_without_sf_small.png'
> functions well?
Do you get any messages about a max gradient and/or your isosurface may have
holes?
So, the standard equation for a sphere is sqrt (x*x + y*y + z*z) - Radius = 0
What you're doing with the above equation is using the elevation of the
heightfield to modify the radius at any given point on the sphere.
and yes, your contained by object needs to be large enough to hold the entire
displaced surface, else it will get clipped.
(just curious: try adding the sqrt() around the x y z parts and see if that
helps any)
> pigment {
> image_map {
> png "moon_dem.png"
> map_type 1
> function {
> x*x+y*y+z*z + 0.1 -
> contained_by {
> sphere {0,1}
> max_gradient 10
> threshold 0.95
> //threshold 2
> texture {
> pigment {
> Thanks,
> Martin
Also look at:
https://news.povray.org/povray.binaries.images/thread/%3C5f16dc29%40news.povray.org%3E/
- BE
> strange problems.
> posts:
> using bump_map.
> functions well?
The moon... very good subject. Have you looked at LUNEX ?
Lots of examples and code :
<https://www.phpsciencelabs.com/lunex-for-pov-ray/>
kurtz le pirate
compagnie de la banquise
