POV-Ray : Newsgroups : povray.advanced-users : Photon mapping calculation limited to 8 threads Server Time
31 May 2025 05:20:38 EDT (-0400)
  Photon mapping calculation limited to 8 threads (Message 1 to 4 of 4)
Subject: Photon mapping calculation limited to 8 threads
Date: 6 May 2024 07:54:42
Message: <6638c502@news.povray.org>
Hi, all !
While rendering large number of images on server with photon mapping
techniques I discovered, that only 8 kernels are used in time of
photons calculation step, while on tracing step all 40 kernels are
loaded.
Is there a way to use more threads for photon calculation to improve
performance ?
Thanks in advance.
YB.
Subject: Re: Photon mapping calculation limited to 8 threads
Date: 6 May 2024 11:05:42
Message: <6638f1c6$1@news.povray.org>
Le 2024-05-06 à 07:54, yesbird a écrit :
> Hi, all !
> loaded.
> performance ?
> Thanks in advance.
> YB.
So, you have one light and 8 target objects, or 2 lights and 4 target
objects, or 4 lights and 2 target objects or 8 lights and 1 target object.
The maximum number of threads used while photon mapping is the product
of the number of light_source by the number of objects with a target block.
To the best of my knowledge : Currently, it is not possible to divide
that process between several threads. The algorithm used is strictly
linear and can't get split between multiple threads.
Date: 6 May 2024 11:17:46
Message: <6638f49a$1@news.povray.org>
Thanks, Alan, I will take it into account.
YB
Date: 17 Feb 2025 18:30:00
Message: <web.67b3c55cd73c9149805ef56b753ea5c@news.povray.org>
Makes sense, thanks for clarifying.
However, POV-Ray 3.7 seems to log this incorrectly. With 16 CPU cores, 1 light
source and 3 target objects, I can clearly see 300% CPU usage during photon
mapping (so 3 cores are used), however, 19 threads instead of 3 threads are
logged.
Render Time:
  Photon Time:      0 hours  2 minutes 53 seconds (173.948 seconds)
              using 19 thread(s) with 456.834 CPU-seconds total
  Radiosity Time:   No radiosity
  Trace Time:       0 hours 11 minutes 12 seconds (672.855 seconds)
              using 16 thread(s) with 10100.757 CPU-seconds total
Thomas.
