POV-Ray : Newsgroups : povray.advanced-users : Comparing colors specified by byte-value using POV-Ray rgb Server Time
6 Jun 2026 19:26:13 EDT (-0400)
  Comparing colors specified by byte-value using POV-Ray rgb (Message 1 to 7 of 7)
Subject: Comparing colors specified by byte-value using POV-Ray rgb
Date: 28 Apr 2024 09:20:00
Message: <web.662e4bfa5c0f47661f9dae3025979125@news.povray.org>
Continuing with the A* pathfinding project,
(AND perhaps the srgb - rgb thread)
I have an image that I generate by color-filling M$ Excel cells, and
I then want to look at certain colors to determine if it's a walkable path, or
an obstacle.
This works well when I specify colors with all 255's or all 0's, but when I have
intermediate shades, I'm trying to use the <0-255, 0-255, 0-255>/255 value as a
comparison, but the algorithm is just recognizing it all as unwalkable.
I'll probably have to go back on run some tests to see what eval_pigment returns
as an rgb triplet.
I'm wondering if I'm going to have to have to use srgb.
I also was thinking about specifying a narrow _range_ of values to give me a
+/-1 wiggle room in byte values when converted to 0-1, so that'll probably
involve math.inc and a special use of VEq and a threshold.
Has anyone ever come across a situation like this?
I currently have enough worked out where I can randomly place 100 people in the
building and sequentially solve the "maze" to generate a shortest exit-path for
all 100 people.  I'm skipping over 5 pixels of the map at every step to generate
a much smaller "graph" to search, but it still takes about 5 min.
- BE
Subject: Re: Comparing colors specified by byte-value using POV-Ray rgb
Date: 1 May 2024 03:52:18
Message: <6631f4b2$1@news.povray.org>
> an obstacle.
> as an rgb triplet.
Not sure i understand your problem, but yes, eval_pigment does return a
color triplet <red, green, blue> in [0..1] range.
An idea for your comparisons: turn your color into HSV.
- Compare the wanted color with the H value plus/minus intervale (degrees).
- Reject colors that are below a threshold of S and V.
IMHO about srgb (and the current discussion in p.b.tutorials) :
This model is useful for calculating the final pixel color value as a
function of object pigment, light and gamma. But not the other way around...
Kurtz le pirate
Compagnie de la Banquise
Date: 1 May 2024 10:10:00
Message: <web.66324c3a88fdbe37e573981225979125@news.povray.org>
So I fill cells in Excel, copy-paste them into IrfanView to make an image file,
and then POV-Ray looks at those pixels with eval_pigment.
When I'm looking for specific colors to determine if something is floor, wall,
door, etc, it's easy to use the 255 or 0 values and just divide by 255.
When I try it with that last peach color, using if(EvalPigmentColor =
ExcelByteColor/255), it doesn't work.
It's an unwanted extra layer, but a good idea - I think the clarity of doing the
HSV way would simplify things.
Hopefully I'll have some time to try it all out tonight.
Thanks!
- BW
Download 'excel rgb colors.png' (11 KB)
Preview of image 'excel rgb colors.png'
Date: 1 May 2024 12:17:26
Message: <66326b16$1@news.povray.org>
I can tell from that last peach color that there is no sRGB conversion
going on.  <248, 203, 173> is the literal byte value of the swatch
encoded as sRGB, and <0.97, 0.8, 0.68> is straight division by 255.  In
POV-Ray, srgb <248, 203, 173> / 255 should give you the same value as
eval_pigment(), which I predict will be rgb <0.939, 0.597, 0.418>.  Try:
#local Tmp = srgb ExcelByteColor/255;
if(EvalPigmentColor = Tmp)
POV-Ray does not provide conversion back to sRGB, but if you need that,
I have some tools at https://github.com/CousinRicky/RC3-POV-Tools
Date: 1 May 2024 13:02:40
Message: <663275b0@news.povray.org>
ok, ok, I understand better the problem.
I quickly coded a test. The result (of little interest) is attached, but
I think the problem lies in the precision/tolerance of the calculations.
I defined the pigment like this (but you know this) :
#declare pigmentSize = 5;
#declare myPigment = pigment {
 image_map {
  png "excel rgb colors"
  map_type 0
  interpolate 2
 scale pigmentSize
The purpose of the test is to give a greater height for pixels whose
color is peach. Several tries and it didn't work.
I created this macro, which compares the source color with the chosen
color, introducing a "tolerance" variable :
#macro CheckColor(thisCol, targetCol, tol)
 ((abs(thisCol.red*255-targetCol.red)<=tol) &
  (abs(thisCol.green*255-targetCol.green)<=tol) &
  (abs(thisCol.blue*255-targetCol.blue)<=tol) )
Two variables:
#declare TargetColor = rgb <248, 203, 173>; // peach color
#declare Tolerance = 16; // this parameter is very very sensitive
In the image constitution, I retrieve the color of the source image:
 #declare myRGB = eval_pigment(myPigment, <xIndex, zIndex, 0>);
If the color is close to the one defined, I make a higher box:
 box {
  <2*xIndex-steep, 0, 2*zIndex-steep>, <2*xIndex + steep,
0.05*(CheckColor(myRGB, TargetColor ,Tolerance)?10:1), 2*zIndex + steep>
 pigment { color myRGB }
This is where the value of the tolerance variable is important !
With value lower than 16 (about 6%) here, there's no higher box.
The code looks bad :(
This "large" tolerance value causes artifacts to appear elsewhere in the
image.
Maybe it's the wrong way...
Can any of this help you?
Kurtz le pirate
Download 'be.png' (163 KB)
Preview of image 'be.png'
Date: 1 May 2024 13:35:00
Message: <web.66327d1988fdbe37e573981225979125@news.povray.org>
Yes, that's what I was thinking as well.
That's indeed the kind of thing I was looking for.
So you are definitely recognizing the peach color separately from the other
colors.
I'm wondering what it would look like if you took Ricky's advice and expressed
the eval_pigment results as both rgb and srgb-converted values and used those
for your comparison, and output the results to the #debug stream.
(And I still like your HSV idea - I definitely think it's more intuitive and
versatile for how I'll be using color coded information)
- BW
Date: 1 May 2024 14:15:00
Message: <web.6632853588fdbe378177b427f712fc00@news.povray.org>
When I was playing with palettes this is  what I use to gather the colors
#declare Imagemap=pigment{image_map{tga "EarthTopography.tga" gamma 1}}
#declare FnA = function {pigment {Imagemap scale<Imagewidth,Imageheight,1>}}
   a&b are integers 0<= a <Imagewidth 0<= b <Imageheight
    #declare FV=FnA(a,b,1);
    #declare C1=int(FV.x*255+.5);//red
    #declare C2=int(FV.y*255+.5);//green
    #declare C3=int(FV.z*255+.5);//blue
 These integers was used to sort colors into a 256 element palette.
  You may notice that I scale the image function very large and that I rounded
up the fraction that the function returned.
Hope this helps.
Have Fun!
