POV-Ray : Newsgroups : povray.advanced-users : Bezier spline deformation Server Time
10 May 2025 05:51:02 EDT (-0400)
  Bezier spline deformation (Message 1 to 10 of 23)
Subject: Bezier spline deformation
Date: 14 Mar 2023 07:01:55
Message: <64105423$1@news.povray.org>
while working on C4D->POV converter, I've discovered a strange form
deviation of prism, extruded from bezier spline (see attachment).
I claim, that exported data is absolutely correct (checked many times),
and no any useful info found here:
https://www.povray.org/documentation/view/3.7.0/62/
https://wiki.povray.org/content/Reference:Prism
I'm not sure about collisions, but only wonder how the same data with
the algorithm can produce different results. It seams to me, that
interpretation is different or maybe some additional scaling is applied
to tangents, for example.
Code is below, any ideas ?
camera{	perspective
	location  <0, 0, 0>
	angle 53.130102
   matrix
  <1.000000, -0.000000, 0.000000,
   0.000000, 0.000000, 1.000000,
   -0.000000, -1.000000, 0.000000,
   0.058724, 5.575552, -0.059483>
#declare Extrude = prism { linear_sweep bezier_spline 0, 1.000000, 16
   <1.500000, 0.000000>
   <1.500000, 0.450694>
   <0.450694, 1.000000>
   <0.000000, 1.000000>
   <-0.450694, 1.000000>
   <-1.500000, 0.450694>
   <-1.500000, 0.000000>
   <-1.500000, -0.450694>
   <-0.450694, -1.000000>
   <0.000000, -1.000000>
   <0.450694, -1.000000>
   <1.500000, -0.450694>
   matrix
  <1.000000, 0.000000, 0.000000,
   0.000000, 1.000000, 0.000000,
   0.000000, 0.000000, 0.000000>
   material { mat_default }
object{ Extrude }
Download 'c4d_spline.png' (60 KB) Download 'c4d_test.png' (23 KB)
Preview of image 'c4d_spline.png'
Preview of image 'c4d_test.png'
Subject: Re: Bezier spline deformation
Date: 14 Mar 2023 07:20:10
Message: <6410586a$1@news.povray.org>
And I should say, that for cubic spline I have the same distortion:
camera{	perspective
	location  <0, 0, 0>
	angle 53.130102
   matrix
  <0.999944, -0.000000, -0.010610,
   0.010182, 0.281279, 0.959572,
   0.002984, -0.959626, 0.281263,
   -0.018327, 5.930451, -1.559761>
#declare Extrude = prism { linear_sweep cubic_spline 0, 1.000000, 7
   matrix
object{ Extrude }
Download 'c4d_test.png' (24 KB)
Date: 15 Mar 2023 00:15:00
Message: <web.6411456b122e7e3aa30d213ddabc9342@news.povray.org>
> camera{ perspective
>  location  <0, 0, 0>
>  angle 53.130102
>    matrix
>    matrix
> object{ Extrude }
I'll take a look. Have you tried plotting those same points in another package?
...like AutoCAD or FreeCAD. Did you try adding a tolerance? I doubt it would
matter.
Mike
Date: 15 Mar 2023 03:15:00
Message: <web.64116ff1122e7e3a17bac71e8ffb8ce3@news.povray.org>
Using my curves macro:
#version 3.7;
#include "curve.inc"  //https://ingoogni.nl/download/Curve.zip
#global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 emission 0}}
#declare vT = array[2]{0, 1}
#declare vC = array[13]{
   <1.500000, 0.000000, 0>,
   <1.500000, 0.450694, 0>,
   <0.450694, 1.000000, 0>,
   <0.000000, 1.000000, 0>,
   <-0.450694, 1.000000, 0>,
   <-1.500000, 0.450694, 0>,
   <-1.500000, 0.000000, 0>,
   <-1.500000, -0.450694, 0>,
   <-0.450694, -1.000000, 0>,
   <0.000000, -1.000000, 0>,
   <0.450694, -1.000000, 0>,
   <1.500000, -0.450694, 0>,
#declare Test = CIt(CIlinear(vT), CIbezier3(vC));
//get the points on the curve
#for(T, 0, 1, 0.005)
  sphere{CITget(Test, T), 0.02 pigment{rgb 1}}
//control points
sphere{Test[1][1][0] 0.03 pigment{rgb <1,0,0>}}
#for(i, 1, dimension_size(Test[1][1],1) - 1)
  sphere{Test[1][1][i] 0.03 pigment{rgb <1,0,0>}}
  cylinder{Test[1][1][i-1], Test[1][1][i], 0.01 pigment{rgb <1,0,0>}}
  perspective angle 45
  location  <0, 0, -6>
  look_at   <0, 0, 0.0>
light_source{<0, 0,-3000> color rgb 1}
Date: 15 Mar 2023 03:35:00
Message: <web.641173f2122e7e3a17bac71e8ffb8ce3@news.povray.org>
"ingo" <nomail@nomail> wrote:
Download 'bez_test.png' (29 KB)
Preview of image 'bez_test.png'
Date: 15 Mar 2023 03:47:23
Message: <736a5120-c008-974b-7783-0b76be8983fb@gmail.com>
Thank you for this test, POV leads 2:0 now. It seems that C4D has some
hidden spline rendering magic. I will ask MAXON support now...
YB
Date: 15 Mar 2023 04:03:48
Message: <85b87be3-7ea0-95d9-62fa-0aa3cad0a315@gmail.com>
> matter.
No, I have no them, maybe some online tools...
Also will try to ask MAXON support - they answer very quickly.
YB
Date: 15 Mar 2023 05:55:55
Message: <b44b0560-ea7d-f389-12d8-47cbc7d21017@gmail.com>
On 15/03/2023 10:47, yesbird wrote:
> It seems that C4D has some hidden spline rendering magic.
This is a Matlab version of cubic spline (attached):
fnplt(cscvn( [1.5 0 -1.5 0 1.5; ...
               0 1 0 -1 0] ))
details are here:
https://www.mathworks.com/help/curvefit/cscvn.html?searchHighlight=cscvn&s_tid=srchtitle_cscvn_1
Score is 2:2 now ...
YB
Download 'c4d_spline.png' (22 KB)
Date: 15 Mar 2023 07:15:00
Message: <web.6411a7b7122e7e3a17bac71e8ffb8ce3@news.povray.org>
Cubic splines are hard to compare. What cubic is used by whom?
Inkscape bezier:
Download 'inkscape_bezier.jpg' (108 KB)
Preview of image 'inkscape_bezier.jpg'
Date: 15 Mar 2023 07:30:00
Message: <web.6411abfd122e7e3a17bac71e8ffb8ce3@news.povray.org>
Cubic B-spline using my curve macros
#version 3.7;
#declare Bspl3 = CIbspline3(
    array[7]{
        <0.000000, -1.000000,0>
        <1.500000, 0.000000,0>
        <0.000000, 1.000000,0>
        <-1.500000, 0.000000,0>
  sphere{CIget(Bspl3, T), 0.02 pigment{rgb 1}}
//control points
sphere{Bspl3[1][0] 0.03 pigment{rgb <1,0,0>}}
#for(i, 1, dimension_size(Bspl3[1],1) - 1)
  sphere{Bspl3[1][i] 0.03 pigment{rgb <1,0,0>}}
  cylinder{Bspl3[1][i-1], Bspl3[1][i], 0.01 pigment{rgb <1,0,0>}}
  location  <0, 0, -6>
  look_at   <0, 0, 0.0>
Download 'test4.png' (22 KB)
Preview of image 'test4.png'
