POV-Ray : Newsgroups : povray.advanced-users : Bezier spline deformation Server Time
15 Jan 2025 17:02:29 EST (-0500)
  Bezier spline deformation (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Bezier spline deformation
Date: 15 Mar 2023 03:15:00
Message: <web.64116ff1122e7e3a17bac71e8ffb8ce3@news.povray.org>
Using my curves macro:
#version 3.7;
#include "curve.inc"  //https://ingoogni.nl/download/Curve.zip
#global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 emission 0}}
#declare vT = array[2]{0, 1}
#declare vC = array[13]{
   <1.500000, 0.000000, 0>,
   <1.500000, 0.450694, 0>,
   <0.450694, 1.000000, 0>,
   <0.000000, 1.000000, 0>,
   <-0.450694, 1.000000, 0>,
   <-1.500000, 0.450694, 0>,
   <-1.500000, 0.000000, 0>,
   <-1.500000, -0.450694, 0>,
   <-0.450694, -1.000000, 0>,
   <0.000000, -1.000000, 0>,
   <0.450694, -1.000000, 0>,
   <1.500000, -0.450694, 0>,
#declare Test = CIt(CIlinear(vT), CIbezier3(vC));
//get the points on the curve
#for(T, 0, 1, 0.005)
  sphere{CITget(Test, T), 0.02 pigment{rgb 1}}
//control points
sphere{Test[1][1][0] 0.03 pigment{rgb <1,0,0>}}
#for(i, 1, dimension_size(Test[1][1],1) - 1)
  sphere{Test[1][1][i] 0.03 pigment{rgb <1,0,0>}}
  cylinder{Test[1][1][i-1], Test[1][1][i], 0.01 pigment{rgb <1,0,0>}}
  perspective angle 45
  location  <0, 0, -6>
  look_at   <0, 0, 0.0>
light_source{<0, 0,-3000> color rgb 1}
Date: 15 Mar 2023 03:35:00
Message: <web.641173f2122e7e3a17bac71e8ffb8ce3@news.povray.org>
"ingo" <nomail@nomail> wrote:
Download 'bez_test.png' (29 KB)
Preview of image 'bez_test.png'
Date: 15 Mar 2023 03:47:23
Message: <736a5120-c008-974b-7783-0b76be8983fb@gmail.com>
Thank you for this test, POV leads 2:0 now. It seems that C4D has some
hidden spline rendering magic. I will ask MAXON support now...
YB
Date: 15 Mar 2023 04:03:48
Message: <85b87be3-7ea0-95d9-62fa-0aa3cad0a315@gmail.com>
On 15/03/2023 07:11, Mike Miller wrote:
> I'll take a look. Have you tried plotting those same points in another package?
> ...like AutoCAD or FreeCAD. Did you try adding a tolerance? I doubt it would
> matter.
No, I have no them, maybe some online tools...
Also will try to ask MAXON support - they answer very quickly.
YB
Date: 15 Mar 2023 05:55:55
Message: <b44b0560-ea7d-f389-12d8-47cbc7d21017@gmail.com>
On 15/03/2023 10:47, yesbird wrote:
> It seems that C4D has some hidden spline rendering magic.
This is a Matlab version of cubic spline (attached):
fnplt(cscvn( [1.5 0 -1.5 0 1.5; ...
               0 1 0 -1 0] ))
details are here:
https://www.mathworks.com/help/curvefit/cscvn.html?searchHighlight=cscvn&s_tid=srchtitle_cscvn_1
Score is 2:2 now ...
YB
Download 'c4d_spline.png' (22 KB)
Preview of image 'c4d_spline.png'
Date: 15 Mar 2023 07:15:00
Message: <web.6411a7b7122e7e3a17bac71e8ffb8ce3@news.povray.org>
Cubic splines are hard to compare. What cubic is used by whom?
Inkscape bezier:
Download 'inkscape_bezier.jpg' (108 KB)
Preview of image 'inkscape_bezier.jpg'
Date: 15 Mar 2023 07:30:00
Message: <web.6411abfd122e7e3a17bac71e8ffb8ce3@news.povray.org>
Cubic B-spline using my curve macros
#version 3.7;
#declare Bspl3 = CIbspline3(
    array[7]{
        <0.000000, -1.000000,0>
        <1.500000, 0.000000,0>
        <0.000000, 1.000000,0>
        <-1.500000, 0.000000,0>
  sphere{CIget(Bspl3, T), 0.02 pigment{rgb 1}}
//control points
sphere{Bspl3[1][0] 0.03 pigment{rgb <1,0,0>}}
#for(i, 1, dimension_size(Bspl3[1],1) - 1)
  sphere{Bspl3[1][i] 0.03 pigment{rgb <1,0,0>}}
  cylinder{Bspl3[1][i-1], Bspl3[1][i], 0.01 pigment{rgb <1,0,0>}}
  location  <0, 0, -6>
  look_at   <0, 0, 0.0>
Download 'test4.png' (22 KB)
Preview of image 'test4.png'
Date: 15 Mar 2023 08:24:40
Message: <5b92f96f-c8ce-6d16-3d3d-96b290d02a06@gmail.com>
As I was expected, looks like the reason is default location of control
points, no any magic here.
YB
Date: 15 Mar 2023 09:27:50
Message: <6411c7d6$1@news.povray.org>
I see the problem. Your spline is not «stiff» enough.
Try pushing the control points back. That'll make the spline flatter at
the placement points.
Try this :
    <1.500000, 0.000000, 0>,//P
    <1.500000, 0.6, 0>,//C
    <0.47, 1.000000, 0>,//C
    <0.000000, 1.000000, 0>,//P
    <-0.47, 1.000000, 0>,//C
    <-1.500000, 0.6, 0>,//C
    <-1.500000, 0.000000, 0>,//P
    <-1.500000, -0.6, 0>,//C
    <-0.47, -1.000000, 0>,//C
    <0.000000, -1.000000, 0>,//P
    <0.47, -1.000000, 0>,//C
    <1.500000, -0.6, 0>,//C
    <1.500000, 0.000000, 0>//P
Date: 15 Mar 2023 10:50:00
Message: <web.6411da2e122e7e3a17bac71e8ffb8ce3@news.povray.org>
Thanks Alain, I'm aware of that, just tried to show that the POV-Ray
implementation of the Bezier spline is not wrong using yesbird's data and
various implementations.
ingo
